How much can a John Deere 4440 pull?
   / How much can a John Deere 4440 pull?
Gravity wagon does have brakes on it. Ground is relatively flat the rolling 'hills' or slopes I'm talking about are all gradual and you can see over all the 'hills'
   / How much can a John Deere 4440 pull? #12
Is your JD4440 2-WD or 4-WD ?
Very limited tractor capability to brake a wagon on even a slight slope, if 2-WD.
   / How much can a John Deere 4440 pull? #14
You must have a "very thick belly pan" on that Ford tractor.
3x6 runners, cab and all are 3/8 thick tubing. Belly pan is 3/8" plate. We wanted weight.
   / How much can a John Deere 4440 pull? #15
3/8 plate weighs 15.3 per #s per sq foot so an 4 X 8 sheet weights 489.6#s belly pan plus the attaching frame/hardware. That still requires a lot for weight for liquid ballast & FEL to achieve 13,600 #s total weight.
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
2008 Komatsu PC55MR-3 Midi Excavator (A55851)
2008 Komatsu...
2017 Bobcat T770 Compact Track Loader (A55314)
2017 Bobcat T770...
2016 Ford F-450 Pickup Truck (A51692)
2016 Ford F-450...
2012 International 4300 Reefer Truck (A57024)
2012 International...
2003 MACK RD688S MIXER TRUCK (A55745)
2003 MACK RD688S...
