How much can a John Deere 4440 pull?
   / How much can a John Deere 4440 pull?
Gravity wagon does have brakes on it. Ground is relatively flat the rolling 'hills' or slopes I'm talking about are all gradual and you can see over all the 'hills'
   / How much can a John Deere 4440 pull? #12
Is your JD4440 2-WD or 4-WD ?
Very limited tractor capability to brake a wagon on even a slight slope, if 2-WD.
   / How much can a John Deere 4440 pull? #14
You must have a "very thick belly pan" on that Ford tractor.
3x6 runners, cab and all are 3/8 thick tubing. Belly pan is 3/8" plate. We wanted weight.
   / How much can a John Deere 4440 pull? #15
3/8 plate weighs 15.3 per #s per sq foot so an 4 X 8 sheet weights 489.6#s belly pan plus the attaching frame/hardware. That still requires a lot for weight for liquid ballast & FEL to achieve 13,600 #s total weight.
Pallet of UV Solid Hardwood Flooring (A55758)
Pallet of UV Solid...
Krause Dominator 4850-18ft (A57024)
Krause Dominator...
2009 IC Corporation PB105 School Bus (A55852)
2009 IC...
2014 Toyota Corolla Sedan (A55853)
2014 Toyota...
2016 HINO 268 26FT BOX TRUCK (A52141)
2016 HINO 268 26FT...
2011 Toyota Camry (A55758)
2011 Toyota Camry...
