How many cement blocks
/ How many cement blocks #1
1930
Platinum Member
Brandon/Ocala Florida
Kubota B6100E Kubota L 2501 Kubota T1460
I know there's online calculators but they confuse me.
Plus I'm out in the middle of the woods and the Sun is overhead and I can barely see the screen of this phone.
Can anyone here tell me how many standard cinder blocks it would require to build a 30 by 40 building with 8 ft walls?
I'm not looking for dednutz accuracy I understand that you have to account for Windows and Doors I'm just looking for a rough estimate
/ How many cement blocks #4
A standard CMU (regular block) is .8 square feet...
total SF 30x8 =240 x 2 = 480
40x8 = 320 x 2 = 640 + 480 = 800 / .8 = 1000 blocks
did this in my head no guarantees...
/ How many cement blocks #5
Actually an 8x8x16 is .89, BUT since at the corners when using running bond you gain a half block every course (end of block). Your .8 is probably reasonably close.
/ How many cement blocks #6
Actually, it would go the other way and make the effective area larger. But that would depend on the size of the building. I would just calculate the number of blocks in each dimension and then multiply those. 12 blocks high, 22 blocks wide, 30 blocks long. 2 x (22+30) x 12 = 1248 blocks less the doors and windows.
/ How many cement blocks #7
Technically...a standard CMU (regular block)...actually measures 15 5/8" X 7 5/8"...allowing for a 3/8" mortar joint at the bottom and one end...so...
15.625 X 7.625 =119.14 / 144 = .823 SF/CMU (actual)....
Obviously you add for breakage and subtract for openings...
Another factor is if the lintel/ tie beam is formed and poured in place the top course of block is not needed...otherwise the top course will not be standard blocks but "knock-out" blocks that allow the webbing to be removed for the concrete tie beam...precast units would be required over any window or door openings...
/ How many cement blocks #8
True, but when you add the joints they are 8x8x16 therefore .89 actual for count. Unless of course you install them without mortar. :giggle:
Thank-you for the replies
/ How many cement blocks #10
I don't want to be a smart a#s but did you have math in school??
New Three Point Hitch Trailer Mover (A65579)
New Three Point...
(10) 6 Bar 20' Continuous Fence Panels (A66408)
(10) 6 Bar 20'...
2022 EZ-GO ELITE...
New/Unused Wolverine 84in Quick Attach Smooth Bucket (A65583)
New/Unused...
2016 JOHN DEERE 7210R TRACTOR (A64280)
2016 JOHN DEERE...
2025 JOHN DEERE 333P SKID STEER (A65053)
2025 JOHN DEERE...
