How Low?????
/ How Low????? #1
Eddie
Platinum Member
North Alabama
YM2020 & Allis Chalmers 6060
I recently had my radiator recored, flushed the engine and installed a 50-50 mix of antifreeze and water. To what temperature will this protect my YM1700?
Thanks
/ How Low????? #3
Be very careful. The YM1700 has no water pump and relies on natural convection (thermosyphon) to circulate the coolant. You should use only as much antifreeze as is absolutely necessary to protect your engine from freezing coolant. Ideally, just water works best for cooling in engines without a waterpump. The higher the concentration of antifreeze, the more this natural circulation is inhibited. I live in western MD, and use a 30% antifreeze, 70% water mix in my YM1110D's which don't have water pumps. In Alabama, I would certainly use 30% antifreeze or less.
/ How Low?????
I used it doing some mowing, some tilling and some landscaping after I installed antifreeze and it didn't act like it wanted to over heat. I won't be using it any more until spring, I'll probably change it out then.
/ How Low????? #5
Ditto on the 30/70 mix.. no more than 30% a.freeze.. or just enough to get past the lowest expected cold point.. otherwise it wont circulate good.
Soundguy
2016 Chevrolet Tahoe (MPV), VIN # 1GNSCBKC8GR280685 (A61165)
2016 Chevrolet...
BUNDLE OF APRROX (45) 3'X30' METAL SHEETS (A62131)
BUNDLE OF APRROX...
2022 Forest River R.pod Towable RV Trailer, VIN # 4X4TRPV28NR208064 (A61166)
2022 Forest River...
2020 Inifiniti Q 50 Sedan (A61569)
2020 Inifiniti Q...
KBH Tender Trailer (A63118)
KBH Tender Trailer...
2024 Freightliner M2 106 Grapple Truck (A61568)
2024 Freightliner...
