How hot does it get inside a storage container?
/ How hot does it get inside a storage container? #21
I see problems getting things in and out. What's goes in first, come out last. I'd rather have something with the long side open than the narrow end.
I have a 20' one-time-use container with double doors at both ends. Easy access from either end so there is no first-in, last out.
/ How hot does it get inside a storage container? #22
I thought the tool of choice would be a battery powered angle grinder with a good thin blade.
I'd prefer a flexvolt angle grinder.
My 2 containers on my farm were cut into with a hacksaw. Fortunately not everything was taken. Now there are huge boulders in front of doors.
They get very hot!
Andy
/ How hot does it get inside a storage container? #23
Use the cool white reflective paint they sell for mobile homes on the roof and it will run a little cooler. Installed vents in my 40 footer. They get very hot if not vented.
/ How hot does it get inside a storage container? #24
I'm tinkering with a couple mini fans I bought and some small surplus solar panels. I went over yesterday but needed to start on rebuilding a loader cylinder on my backhoe.
those move minuscule amount of air so may also try this at a later date.
I also have some white paint purchased for the whole container.
It was just an idea... the thought of getting everything undercover sooner rather than later was appealing. I'll have to wait a while longer though...
I have a 16x16 foot shed started, down near the house where I can put power to it. That's just big enough for the tractor and winch on one side if I use a shoe horn, and the bush hog and tiller on the other. Hopefully the ATV will squeeze into the middle, although it'll be a PITA to move it in and out every time I want to use the tractor. Of course the implements get evicted when I bring the TO home... which will happen as soon as I get a shelter for it.Then I need room for the BH and snowsled, and it would be really nice to have the harrow and plow undercover also. And as everybody knows, if there's ever any empty space it will soon fill up.
/ How hot does it get inside a storage container? #26
Hey all, I just bought a new (one-tripper) 40' high cube container to store my tractor and skid loader in. I wanted double doors (doors on both ends) so I had to buy a new one. Kinda pricey, but hey, it looks brand new. It came with 4 small vents, one in each corner in the upper sidewall. I can fit the tractor with a set of pallet forks in one end and the skid loader with pallet forks in the other end and still have about 6' of space in the middle for some shelves to store misc stuff.
I wanted to get the equipment away from the rodents and the hail. I think this will do the job.
Tim
Oh, PS It gets plenty hot in there on these 100deg days here in Tejas.
/ How hot does it get inside a storage container? #27
I had planned on putting vents on mine, after it rained in there from condensation, but after moving it to the shade, I have no indication that has happened again. Mine is rusting (Hey it was free) and maybe that makes for some extra ventilation.[/QUOTE]
I had a 40' aluminum one for storage of scaffolding and left over construction materials in Richmond B.C. where it rained a lot. It would also rain inside constantly from condensation, except under where I had a car-top boat stored so I put other stuff up there and the problem sort of went away. Keeping the sun off of the actual roof seemed to be the cure.
/ How hot does it get inside a storage container? #28
Tim
Doors in both ends would be nice. I have been using a container for several years. I now have two. No rodents and bugs is the best feature.
/ How hot does it get inside a storage container? #29
I personally ended up attaching 2 40 foot containers together I cut out the centers which left me a nice big 16 x 40 itç—´ been 90+ degrees here in Michigan for the last two weeks my shipping containers are cooler on the inside then the outside. I installed two big side vents. Plus I raised my shipping containers above the ground. They are also stored in a wooded area which I cleared. So it does give it some shade I was very concerned about the ventilation and heat as well. But mine turned out absolutely perfect. I sealed the roof because the containers leave about a quarter inch gap. When you attach them together. I did not seal the floor. What I did is I ended up installing some medal gutter grades which will keep the mice and critters out but will let the cool air from the ground enter the container.
/ How hot does it get inside a storage container? #30
Just watched a video where someone claims just using cool white roof coating lowered the inside temps 20 degrees during the hottest part of the day.
/ How hot does it get inside a storage container? #31
I checked mine when I was sitting in it with a infrared thermometer. The walls were 60 deg Celcius. (140 F) A blast of heat hits you when you open the door. Petrol containers expand to half their size again. I have to leave the lids slightly loose.
I will be fitting a glass sliding door with security screens so I can leave them open in the summer. My containers are dark green.
/ How hot does it get inside a storage container? #32
I have 2 40’s and a 20. The small vents are not enough. If you even cut one 4x4 inch hole in the top of a door and another down low and cover it with a screen and dryer vent cover, you will greatly reduce humidity.
I have rigged up a 5.8 amp draw radiator fan and will be installing it on a 40 that I’ll be storing my tractor in. I’ll use 2 silver panels and a couple of batteries. I bought a temp switch on amazon. I figure I want it running Until temp is under 90F.
/ How hot does it get inside a storage container? #33
Cut vents in the lower 1/4 of doors. Solar power vent in roof on far end keeps it bearable. As mentioned above. a 40 ft was on 500 more than a 20 ft for me. and a Hi top or hi cube is also worth the extra $150 over standard.
/ How hot does it get inside a storage container? #34
Have you considered one of those carport sheds? I have two 18 x 21 with 6 ft. walls. paid $900 for the first one and $1100 for the second one last year. The second one I opted for enclosed side walls, the first one is open all the way around. I have an antique pick up, boat and trailer, two riding mowers, tiller and dump cart under the open shed. I have two riding mowers, two push mowers, 8n ford and room for my mule and four wheeler in the new one. I really want a 30 x 40 metal building on a slab but just can't seem to get it done. I bought a 20 ft single use shipping container about five years ago and put plenty of shelving in it. I open it every day on sunny winter days and of course summer. I gets pretty friggin hot in there. The only ventilation is four little vents on the corners. I considered painting the top with the white mobile home roof coating but that is for another day.
(2) UNUSED 9.5-16 TIRES W/ 6 LUG RIMS (A64280)
(2) UNUSED 9.5-16...
2017 Dodge Grand Caravan Van (A61574)
2017 Dodge Grand...
2021 Ford Transit 350 HD Reefer Box Van (A64194)
2021 Ford Transit...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2019 CHEVROLET...
John Deere 6400 (A64126)
John Deere 6400...
(APPROX. 128) 1"X6"X8" PONDEROSA PINE (A64281)
(APPROX. 128)...
