How do you transfer oil from 5 gal buckets?
   / How do you transfer oil from 5 gal buckets? #1
FatTire
Colorado
Kubota L5740, Unimog 404 w/ snowblower, Deere 620i UTV, MX5100 (sold)
What is your preferred method for transferring engine oil or hydraulic fluid from 5 gallon pails when doing a fluid change? Drill pump? Hand/bulb pump? Pour into a smaller container? If using a pump, do you use a separate one for each fluid type, or do you try to clear it out when done?
   / How do you transfer oil from 5 gal buckets? #2
Hand pump types are made that will fit a 5 gallon bucket. They can pump pretty darn thick products such as self leveling urethane caulking or heavy and light width oils. Buy mine at local Napa auto parts store. For oils I will use the pump on different products. I just pump a bit to make sure its flushed out from the last product that I used.
   / How do you transfer oil from 5 gal buckets? #3
I use a 1 gallon can like this :
   / How do you transfer oil from 5 gal buckets? #4
I pour into a smaller container. I little research and I found these products which we started using at the plant years ago. The color coding was nice for the various lubricants. They bought the pump/hose models and the jugs.Oil Storage & Transfer Containers - Lubrication Engineers Probably high dollar stuff but it was way better than our old system of scrounging for a funnel etc etc.
   / How do you transfer oil from 5 gal buckets? #6
We've talked about this before on TBN....
   / How do you transfer oil from 5 gal buckets? #7
I bought the Pittsburg 5 gallon pail pump from Harbor Freight for $15. Had it for a couple years and works good. Could be me but it’s a little messy. Seems I’m dribbling oil everywhere. Only issue and I knew about from the reviews is it had aluminum metal shavings inside. Cleaned and flushed it and used a paint strainer the first few times just in case.
I recently saw this post about a pail tipper and think it’s a good way. Just pour what you need into a qt./gal oil can. Seems simple and easy https://www.tractorbynet.com/forums/parts-repairs/258905-anyone-have-pail-tipper-5-a.html#top
With my luck of the Irish, I’d try the MossRoad method and I’d get the one bucket that was overfilled and the oil would come gushing out when I took the cap off
   / How do you transfer oil from 5 gal buckets? #8
Just roll it over? OMG I've been doing it the hard way for 20 years!!!! :)
   / How do you transfer oil from 5 gal buckets? #11
Harbor Freight sells a 5 gal pail pump that doesn't suck. I used it to fill my Mahindra with 8 gallons of hydraulic fluid without any issues. Way better than dumping into another container over and over again.
5 Gallon Oil Pump
   / How do you transfer oil from 5 gal buckets? #12
I use a big funnel, cradle the bucket with my right arm with spout up, and pour. No point in wasting time with a pump for 5 gallons.
   / How do you transfer oil from 5 gal buckets? #13
5 Gallon Oil Pump
If it doesn't suck, what good is it? Take it back for a refund.
   / How do you transfer oil from 5 gal buckets? #14
   / How do you transfer oil from 5 gal buckets? #16
I usually just pour from the 5gal bucket into a sizeable funnel over the machine I'm trying to fill. I hardly ever re can fluids unless I'm running out of space and have a clean empty oil jug.
1459 (A57192)
1459 (A57192)
2017 JOHN DEERE 470G LC EXCAVATOR (A60429)
2017 JOHN DEERE...
2019 Bobcat T590 Compact Track Loader Skid Steer (A59228)
2019 Bobcat T590...
2022 FORD F-250 STV CREW CAB TRUCK (A59823)
2022 FORD F-250...
GIYI SF60-60" HYD SIDE SHIFT FORKS (A60430)
GIYI SF60-60" HYD...
Hays LT-1 Tender (A61307)
Hays LT-1 Tender...
