How do you transfer oil from 5 gal buckets?
   / How do you transfer oil from 5 gal buckets? #11
Harbor Freight sells a 5 gal pail pump that doesn't suck. I used it to fill my Mahindra with 8 gallons of hydraulic fluid without any issues. Way better than dumping into another container over and over again.
5 Gallon Oil Pump
   / How do you transfer oil from 5 gal buckets? #12
I use a big funnel, cradle the bucket with my right arm with spout up, and pour. No point in wasting time with a pump for 5 gallons.
   / How do you transfer oil from 5 gal buckets? #13
5 Gallon Oil Pump
If it doesn't suck, what good is it? Take it back for a refund.
   / How do you transfer oil from 5 gal buckets? #14
   / How do you transfer oil from 5 gal buckets? #16
I usually just pour from the 5gal bucket into a sizeable funnel over the machine I'm trying to fill. I hardly ever re can fluids unless I'm running out of space and have a clean empty oil jug.
55-Gallon Drum of 50/50 Antifreeze Star Fire Pure Fleet Red Heavy Duty (UNOPENED) (A59076)
55-Gallon Drum of...
KUBOTA SSV65 OPEN STATION CAB (A52706)
KUBOTA SSV65 OPEN...
2019 KUBOTA U35-4 EXCAVATOR (A52706)
2019 KUBOTA U35-4...
LINCOLN PUSHMOWER (A58374)
LINCOLN PUSHMOWER...
500BBL WHEELED...
SEMI AUTOMATIC QUICK CHANGE FOR MINI EXCAVATOR (A58216)
SEMI AUTOMATIC...
