Hose Supplier.
/ Hose Supplier. #1
psj12
Platinum Member
Short OK
KIOTI 551
I need some Hydraulic hose to operate my new grapple. it needs to be 3/8 inch and a working pressure of 2,500 PSI. I would like to use screw on removable ends like Aeroquip. Does anyone know an inexpensive supplier of these items. Since I am running hose from the rear QDs I will need quite a bit of hose.
/ Hose Supplier. #2
DHH has both. But I suggest you use 1/4" hose, it willl be cheaper and is well suited for your grapple.
Where in MD are you-It may cheaper just to get two hoses made locally...
/ Hose Supplier.
I am having the items shipped to OK where my tractor is. I am also looking for adapters from Chinese metric o ring face seal to pipe or JIC.
/ Hose Supplier. #4
Oh Oh, this could be a challenge.. I went through this last winter. Back then I couldn't find anybody that had the chinese face seal connectors. I ended up having my hose cut and JIC connectors installed.
Wedge
/ Hose Supplier. #5
I have a Chinese backhoe and needed a couple new hoses because the original hoses were crimped wrong, hoses not inserted fully. After a lot of messing around with metric and flat face fittings I just welded JIC to my old fitting end. I Ox/Act. welded these.
2018 Ram 1500 Crew cab (A59230)
2018 Ram 1500 Crew...
Kubota Zero Turn Lawnmower (A65579)
Kubota Zero Turn...
2022 EZ-GO ELITE...
New/Unused CFG Industrial NT18K Mini Excavator (A65579)
New/Unused CFG...
2000 GMC W3500 Cab and Chassis Truck (A59230)
2000 GMC W3500 Cab...
2009 V.E. ENTERPRISES 130BBL VACUUM TRAILER (A65643)
2009 V.E...
