Hose Supplier.
/ Hose Supplier. #1
psj12
Platinum Member
Short OK
KIOTI 551
I need some Hydraulic hose to operate my new grapple. it needs to be 3/8 inch and a working pressure of 2,500 PSI. I would like to use screw on removable ends like Aeroquip. Does anyone know an inexpensive supplier of these items. Since I am running hose from the rear QDs I will need quite a bit of hose.
/ Hose Supplier. #2
DHH has both. But I suggest you use 1/4" hose, it willl be cheaper and is well suited for your grapple.
Where in MD are you-It may cheaper just to get two hoses made locally...
/ Hose Supplier.
I am having the items shipped to OK where my tractor is. I am also looking for adapters from Chinese metric o ring face seal to pipe or JIC.
/ Hose Supplier. #4
Oh Oh, this could be a challenge.. I went through this last winter. Back then I couldn't find anybody that had the chinese face seal connectors. I ended up having my hose cut and JIC connectors installed.
Wedge
/ Hose Supplier. #5
I have a Chinese backhoe and needed a couple new hoses because the original hoses were crimped wrong, hoses not inserted fully. After a lot of messing around with metric and flat face fittings I just welded JIC to my old fitting end. I Ox/Act. welded these.
Club Car Electric Golf Cart (A64912)
Club Car Electric...
46901SFL (A64557)
46901SFL (A64557)
2020 Kodiak 4AP Towable Aerator Tractor Attachment (A66734)
2020 Kodiak 4AP...
Luck Now 425 (A64911)
2013 WACKER NEUSON HF 690 FLAMELESS HEATER TRAILER (INOPERABLE) (A67714)
2013 WACKER NEUSON...
PORTA POTTY (A68842)
