Homemade Ballast
/ Homemade Ballast #1
thekkfan
Triad Area, NC
'17 Kioti NX5510HC, '65 Ford 2000
Thought I'd share my pickle barrel ballast I made yesterday. I know there's been many posts about these. I like this one in particular since its plastic, tall and narrow. Took 10-3/4 80lb bags to fill. I can store chains in the top and the lid still seals.
/ Homemade Ballast #2
Nice job. What did you use for the metal frame? Something pre-made or did you fabricate something?
/ Homemade Ballast
/ Homemade Ballast #4
Thanks. Let us know how it works out for you. I have some barrels and have been wanting to make one, but am welder-less right now and hadn't found a way without it. As long as yours stays together, looks like a solution.
/ Homemade Ballast #5
Thanks. I used a quick hitch adapter and a cat1 26" drawbar links below. Both cheaper than TS and never left the house! Tied the two together with rebar, and have additional rebar coils inside.
Amazon.com : RanchEx 12863 Adapter for Cat 1 Quick Hitch (SKU 12851), Inside Width 2-13/16" : Garden & Outdoor
Amazon.com: Koch Industries 43123 Drawbar with 11-Holes and 26-Inch Spacing, Black: Home Improvement
Nice design. I like the way it puts the weight centered on the lift arms and close behind the tractor. I was doing some work in a barn around some center posts and that would have been a real advantage. As it was, I got the job done with a Titan ballast box, which was a lot better than the box blade I had been using.
/ Homemade Ballast #6
Actually bolts and nuts work... Welder is just tool of convenience...
Dale
/ Homemade Ballast #7
Dale
Trying to couple two pieces of metal that are going to pick up >800 lbs just seems like a welder job to me. :laughing:
I'll give this a try though.
/ Homemade Ballast #8
So the only thing holding the bottom links to the top link is concrete?
Unverferth Ripper Stripper (A64126)
Unverferth Ripper...
2022 Mac Trailers 48ft. T/A Walking Floor Trailer (A64556)
2022 Mac Trailers...
2023 JOHN DEERE 310P BACKHOE (A65053)
2023 JOHN DEERE...
Ground Protection Mats (A64194)
Ground Protection...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
2021 Kubota SVL75-2 Track Loader (A63689)
2021 Kubota...
