Homemade Ballast
/ Homemade Ballast #1
thekkfan
Triad Area, NC
'17 Kioti NX5510HC, '65 Ford 2000
Thought I'd share my pickle barrel ballast I made yesterday. I know there's been many posts about these. I like this one in particular since its plastic, tall and narrow. Took 10-3/4 80lb bags to fill. I can store chains in the top and the lid still seals.
/ Homemade Ballast #2
Nice job. What did you use for the metal frame? Something pre-made or did you fabricate something?
/ Homemade Ballast
/ Homemade Ballast #4
Thanks. Let us know how it works out for you. I have some barrels and have been wanting to make one, but am welder-less right now and hadn't found a way without it. As long as yours stays together, looks like a solution.
/ Homemade Ballast #5
Thanks. I used a quick hitch adapter and a cat1 26" drawbar links below. Both cheaper than TS and never left the house! Tied the two together with rebar, and have additional rebar coils inside.
Amazon.com : RanchEx 12863 Adapter for Cat 1 Quick Hitch (SKU 12851), Inside Width 2-13/16" : Garden & Outdoor
Amazon.com: Koch Industries 43123 Drawbar with 11-Holes and 26-Inch Spacing, Black: Home Improvement
Nice design. I like the way it puts the weight centered on the lift arms and close behind the tractor. I was doing some work in a barn around some center posts and that would have been a real advantage. As it was, I got the job done with a Titan ballast box, which was a lot better than the box blade I had been using.
/ Homemade Ballast #6
Actually bolts and nuts work... Welder is just tool of convenience...
Dale
/ Homemade Ballast #7
Dale
Trying to couple two pieces of metal that are going to pick up >800 lbs just seems like a welder job to me. :laughing:
I'll give this a try though.
/ Homemade Ballast #8
So the only thing holding the bottom links to the top link is concrete?
2014 Nissan Sentra Sedan (A64557)
2014 Nissan Sentra...
2015 DITCH WITCH FX25 VACUUM TRAILER (A63276)
2015 DITCH WITCH...
2016 Kubota SSV75 Compact Wheel Loader Skid Steer (A64553)
2016 Kubota SSV75...
2025 8in Channel Tooth Bucket Mini Excavator Attachment (A64553)
2025 8in Channel...
2007 International CE200 School Bus (A64194)
2007 International...
2022 JOHN DEERE 333G SKID STEER (A65053)
2022 JOHN DEERE...
