hobby farm tractor
/ hobby farm tractor #31
Why not another Kubota?
Sorry for the link to a competing forum, but I was a member of MTF before I found TBN. But anyway, I made a thread with many of my project pics with my 2013 Kubota and to this day I have only had to make ONE repair after all that work. The weld on the loader joystick failed and the joystick fells off, so I replaced it.
Other than fluids, filters, tires and battery this Kubota has been absolutely trouble free. It starts in minus 40 not plugged in, never ever fails me. I'm a believer in Kubota reliability. There's no doubt why reefer motors on transports, and many small Caterpillar machines, etc use Kubota engines.
/ hobby farm tractor #32
My AGCO/Masseys have very easy hook up on PTO splines. They are chamfered to allow easy slide-on.
Don’t know if smaller ones are like that.
I know Kubota didn’t have that feature.
My little Kubota's do.
/ hobby farm tractor #33
We are looking to replace an older Kubota 3710 for our 40 acre hobby farm (photo below) with another used tractor. We use the bucket a lot, cultivator and mowing deck attachments (for pastures and gardens), but hooking them up to the PTO is a real pain. Looking for advice on replacement tractor. The mid-mounted permanent mower decks sound great but then you sacrifice ground clearance. I don't pretend to be mechanically gifted and appreciate any advice.
if you get a deere,kubota,or massey ,you wont have any problems..if you buy a cheaper chinese or indian tractor,you will most likely have problems for getting parts for warranty work...your choice...
/ hobby farm tractor #34
Your machine is at -40, with no block heater, and you decide that’s when you want to start and run your open station tractor outside?😮
/ hobby farm tractor #35
That's what it's for....snow blowing the driveway and moving snow with the loader.
I have 0W40 Petro Canada synthetic engine oil in all my diesels and they start no problem.
The only ones I run in winter are the 55 Allis, the Kubota B2620 and the Kubota RTV-X1100C with the Boss plow. They are more reliable starters than some of my vehicles, LOL
/ hobby farm tractor #36
Is that because it's a gear transmission and you want a HST? Or is hooking the PTO most of the problem?
It's a lot cheaper to buy a quick hitch for the 3 point hitch and maybe a new driveline for the PTO vs. selling this and buying another tractor.
For quick hitches, I like Pat's since it moves the implement 4" farther back and I have more room to attach the PTO. I hook up the lower links by just backing up to the implement and lifting the 3 point hitch. It locks onto the pins of the implement without getting off (most times :) )
Instead of the turn buckles for the 3 point hitch, I upgraded to Adjustable stabilizer bars. They hold the 3 point arms in place (give or take a little).
I would also, buy a new seat and a canopy for your tractor, spend money fixing that one up vs. spending on trading it.
If OP is concerned about the 3pt hookup, I agree completely about Pat's Quick Hitch. It's a wonderful piece of equipment.
/ hobby farm tractor #37
The only shortcoming of the Pat's QH is it puts the implement about 2 inches further back from the tractor. You may need to add an extension to your top link, particularly if you use a hydraulic top link.
I agree hooking up a pto can be a pia, but if you keep the splines coated in anti-seize lubricant it is easier. In the case of a mower it is also important to keep the blades far enough up and off of the ground so you can manually turn the mower shaft to align it with the tractor. I park my bush hog on 6x6 blocks to accomplish that.
/ hobby farm tractor #38
When I think of a large purchase like a tractor, I want something that will last the long haul. I bought my tractor with the intentions on having it until I die. So with that said, I wanted something that I knew parts support would still be there decades down the road. I did a LOT of research. I spoke to tractor mechanics, I spoke to service centers, and I spoke to owners. What I learned from the service centers and mechanics at independent shops was that brands like TYM, Kioti, Branson etc., they had a LOT of issues with parts support. One service center said they had Kioti's sitting in the back lot waiting months on parts. I also seen some of these off-brand tractor dealers open shop and then close down within a few years. So I had no faith in these little dealers selling the Korean tractors. The one thing I heard over and over was if you wanted a long term reliability, then you needed to look at Deere and Kubota. They sell more tractors than anyone else, for every 1 Korean tractor, there were 500 JD or Kubota tractors sold. So years down the road, chances are you'll find a part for these tractors before you'll find one for the lesser known tractors. That was important to me. Another isse I had with the Korean tractors was I felt they used inferior steel in their construction. I see far more steel related issues in these tractors than what I do in JD or Kubota. The parts support is getting better with the Korean tractors but I am not just talking about today's parts supply, but also the parts supply for them 30 years from now. While there will be ten's of thousands of old used JD's and Kubotas around, there won't be near as many of the off-brand Korean tractors out there.
I also wanted no part of the whole emissions world they put on these tractors. I have dealt with the emission issues on my diesel trucks and it was costly. So with my tractor, I wanted a bare bones, no emissions, all mechanical tractor that didn't need all of these sensors to run properly.
I chose a Kubota L2502 and it's an awesome tractor that does everything I could ask for on my 20 acres. And as many of these that are sold, I should be able to find parts for it even 30 years from now.
We all have different opinions and this one is mine...
I agree completely.
/ hobby farm tractor #39
FWIW, I'd throw Yanmar into the mix for consideration.
I've had great luck with my 2008 EX-3200 (32hp) which i bought used over 10 years ago. I use it for logging, snow plowing, brush hogging and grading for ~80 acres of mostly wooded land. While I take care of my equipment, I treat this tractor like a rented mule. (Like all guys after they buy their first compact utility tractor, i wish i bought more power. As a result, i'm always pushing it to the limit) Other than one leaking seal on the FEL cylinder, its been rock solid without any problems. While mine was the co-branded Cub Cadet/Yanmar, its my understanding that it was entirely built by Yanmar. its also my understanding that in that era, Yanmar was building the mid-size JD's (24hp-40hp) at the same factory in GA; only difference was 20% price premium for green paint.
( JD tractors that Yanmar builds/has built:
My local Cub Cadet dealer still carries the Yanmar line....the only thing i've needed are fluids and filters and they always have whatever i need on hand.
Regarding the PTO, I saw someone mentioned doping up the splines with anti-seize. I've been doing the same thing for years and i never have any trouble hooking up drive shafts.
/ hobby farm tractor #40
To OP. KEEP WHAT YOU HAVE. Unless something is severely broken you will not be able to get a better new tractor. Talk to a dealer about getting a hydraulic top link and consider Pat's three-point attachments to make three-point hook-ups easier. Be happy with the uncomplicated diesel power you have - don't even think that a new tractor with all the required emissions stuff will make life easier.
NORAM 65E MOTOR GRADER (A62129)
NORAM 65E MOTOR...
(15) Polyethylene Road Bed Protection Pads (A60463)
(15) Polyethylene...
2010 Deere 318D (A60462)
2010 Deere 318D...
2022 KAUFMAN 4X2 2 CAR TILT GOOSENECK TRAILER (A59906)
2022 KAUFMAN 4X2 2...
2010 Case 580N (A60462)
2010 Case 580N...
DEUTZ MARATHON...
