Look for advice on tractor purchase
   / Look for advice on tractor purchase #31
Thanks all for the heads up on scams. Unfortunately, they are pretty common but easy to identify. Does anyone else have some input on the different options available for 5k to 20k? Older, newer, 2wd, MFWD, I'm not sure exactly what I will need to get the jobs done. For example, will a 3000-4000 lbs 30-40 horse tractor clean up a rough steep road with a box blade or drag a 2000-3000- lbs log out of the woods? From everything that I have read on this forum people say get the biggest tractor you can afford. I can get a 4020 for 15K but I think that is too big, cool to have though.
You want 4WD. Hay baler = HP. Think small square bales for horses at most In this HP range.
For the dirt work, weight matters not HP. For the road it depends on how compacted it is. You can help by trying to grade it after a light rain when it’s a bit softened up. You can always drag down hill with the scarifiers then back up hill with them raised to redistribute. Sure it takes longer…but as I say below….compromises.
3000lb log? Not likely. But hey you can cut it into smaller 8 ft pieces and move it.
In your price range there will be compromises.
   / Look for advice on tractor purchase #32
I elected to buy a 1974/MF 40 construction tractor with a front end loader. I went through the rear end and resealed everything and rebuilt the shaky puddin hydraulic pump.I then rebuilt the front end and gave it a tuneup. 12 years of abuse with round bales and endless hours of mowing and maintaining a 1/2 mile drive I finally had to replace the starter. It's a tank and I suspect it will be my last utility tractor.
   / Look for advice on tractor purchase #33
if you happen across a yanmar they are great tractors . as well as a nice condition kubota , ford , newholland …. if you have a hilly terrain i would recommend a 4wd . my farm is hilly and i use 4wd often . it is also a force multiplier when plowing or dragging heavy .. a loader is extremely helpful. on older tractors watch tire and rim condition, some can be pricey if not a common size . although don’t let this be a deal breaker just allow in purchase price. i find the yanmar ym336d a handy small tractor w decent horsepower (36) . i have 2 and run them daily . my big gun is a kubota m5700 , at 62 hp does all i ask of it . but it is big and heavy which can be a disadvantage at times , but usually the weight is helpful. best to have one of each ….watch for grey market tractors they can bs sketchy…
2015 GMC 3500 HD 4x4 Crew Cab Pickup truck (A55973)
2015 GMC 3500 HD...
206320 (A57192)
206320 (A57192)
2011 Toyota Camry Sedan (A56859)
2011 Toyota Camry...
PENDING SELLER CONFIRMATIONS (A57880)
PENDING SELLER...
2014 Chevrolet Express 3500 Cargo Van (A55852)
2014 Chevrolet...
John Deere 690B Excavator with Auxiliary Hydraulics (A57024)
John Deere 690B...
