3-Point Hitch hitch wont go down
/ hitch wont go down #1
arl242
Tipton, MO
NH TD 5050
I have a 492 MF and it just recently got to where the 3 pt hitch will not go down. When the tractor is off it goes down due to a small seal leak. As soon as i start the tractor the hitch goes up, even when it is in the down position. I have checked the oil level and it appears fine, even though its hard to see on the stick. Any suggestions?
/ hitch wont go down #2
Try turning the little knob sticking out from under the seat counterclockwise.
/ hitch wont go down #3
Offhand, it sounds like a linkage problem. Follow the linkage path to the pump. Disconnect the attachment point and see if you can manually move the actuator. If it is frozen in the LIFT position then something is amiss on the inside of the system.
If that makes no difference, then it must be an internal issue with the pump. Maybe time for a rebuilt one.
I don't have anything under the seat that I am aware of, except the seat adjustment lever
/ hitch wont go down #5
If it has draft control push the draft control lever all the way down
Draft control is down, I have tried every position on the controls. I will start with gwdixon advice, thank you all for the help!
2012 John Deere 135D Excavator (A65579)
2012 John Deere...
2016 Ford Escape SUV (A64557)
2016 Ford Escape...
2018 SolarTech Silent Messenger Towable Solar Message Board (A64553)
2018 SolarTech...
Rolling Cart Base (A65640)
Rolling Cart Base...
2023 SolarTech Silent Advisor FD-304 Towable Solar Speed Limit Board (A64553)
2023 SolarTech...
ROANOKE S/A LOOSE LEAF TRAILER (A63291)
ROANOKE S/A LOOSE...
