Hinged mower deck
/ Hinged mower deck #1
g0liath
Ottawa, Ontario
Kubota B2920, MF 35 Diesel
Just wondering if anyone has done or seen or thought of converting their 2 blade 48" or so mower deck from a fixed one piece deck to a hinged or articulated mower deck?
What I'm trying to solve is the issue of uneven ground. I feel the mower would do better if one or both mower compartment/blade could move up/down independent of the other as your mowing across different terrain? Example: ditches that have a high side and then flat, etc..
Anyhow been thinking about this for a while and can't seem to find much/any information online. Thanks.
/ Hinged mower deck #2
Welcome to TBN
Interesting concept. Any thoughts how you would power the two blades? Hope you get some good ideas how to do that.
When I mow a ditch, I run one side of the deck in the ditch. Going back, keep that side in the ditch and don't overlap the mower cuts.
/ Hinged mower deck
I think you might still be able to use the current belt drive and pulley system as long as the angles aren't too crazy.
I do the same thing as you for the double pass, issue I have is that guaranteed, you're digging into the ground one direction or both because of the angles your cutting. That's what I'm trying to avoid. Thanks and I appreciate the feedback!
/ Hinged mower deck #4
A pic or two of what ground you are trying to mow and how your deck digs in would help to better understand. I have a 54" deck w/three blades.
A pic of your mower deck will give us some idea what you want to hinge. Am thinking you will end up with a skipped strip of non-mowed grass. But interesting idea.
2022 EZ-GO ELITE...
2026 VR59 59in Vibratory Roller Skid Steer Attachment (A64553)
2026 VR59 59in...
2022 CATERPILLAR D8T HIGH TRACK CRAWLER DOZER (A65053)
2022 CATERPILLAR...
2017 INTERNATIONAL 4300 4X2 S/A 26FT NON CDL BOX TRUCK (A67147)
2017 INTERNATIONAL...
2006 GMC Savana 3500 Box Truck (A61573)
2006 GMC Savana...
2007 JOHN DEERE 450J LGP CRAWLER DOZER (A63276)
2007 JOHN DEERE...
