Help with PTO speed
/ Help with PTO speed #1
Anonymous Poster
Epic Contributor
Can someone tell me which way to move the PTO shift lever to operate the Pto at 540 rpm on my YM2700? I've finally got my Howse finish mower attached and lined up thanks to Bird's help connecting the PTO shaft and Don Black's advice to lengthen the lift arm linkage. Now if I can figure out which way to shift to 540 rpm I'll be cutting grass as soon as the current monsoon is over.
thanks, Marc.
I don't know about that model, but whichever one is slowest is it.
/ Help with PTO speed #3
Quite a few of the greys have 300 rpm (or slower) pto gears so the lowest is not always 540
/ Help with PTO speed #4
On my 186D 540 is down and 1000 is up. Is that the way they all are?
Chris
/ Help with PTO speed #5
I have seen greys with as many as 21 PTO speeds. A fair amount of the Shibaura's have 8. US models will typically only have 540 and 1000. You can rent (or borrow) a hand tachometer and find out exactly what gear you should be in, just make sure it is rated for the RPM you are testing.
YM2700 pto 1st gear: both levers forward. 2nd gear: front lever back, rear lever forward. 3rd gear: front lever forward. rear lever back. 4th gear: both levers back.
1st 467 rpms
2nd 587 rpms
3rd 951 rpms
4th 1200 rpms
Danny
Parker Equipment Co
danny,
Thanks for the reply. I was going to ask what the other shift lever in the back was for, but now I know thanks to you. I just finished cutting my grass and only shifted the front lever to the lowest speed but still don't know what it was. I was operating with the front lever forward so I was either 467 or 951. I can hardly wait till morning to check the back lever to see what position it's in.
Thanks,
Marc.
/ Help with PTO speed #8
Remember though, that those rpm settings are also dependent on your engine speed.
Soundguy
KL480 Ventrac tiller
SKID STEER PLATE GRABBER (A62613)
SKID STEER PLATE...
2015 Ford F-250 Pickup Truck (A61567)
2015 Ford F-250...
AMADAS SPC4 - 4R COTTON STALK PULLER / CHOPPER (A64276)
AMADAS SPC4 - 4R...
2014 International Durastar 4300 S/A Dump Truck (A61573)
2014 International...
213324 (A64279)
213324 (A64279)
