HELP needed- JD 770 not starting
/ HELP needed- JD 770 not starting #1
RonnieSue
jd 770
My 1996 JD 770 tractor is not starting. i get no lights or anything. checke battery-it's good. i checked the fuses and after pulling them all-it did start. then, a few days later the same exact thing happened. i quickly tried the check the fuses again and this time it didn't help.
any suggestions would be greatly appreciated. i'm in the middle of a big project....thank you
/ HELP needed- JD 770 not starting #2
Welcome to TBN
"get no lights" .. so the starter is not turning the engine over..
Remove and clean all the battery cable connections. Let us know if the engine will then turn over with the starter.
/ HELP needed- JD 770 not starting #3
I suspect bad battery cable or battery connection. Clean and tighten all battery connections and check where ground cable attaches to frame.
battery cables should not move by twisting with your hand
thanks....i am having first cup of coffee now. then going out to check battery cables. i'll let you know results~
You guys are all terrific! Saved my bacon today. Hubby went out and removed battery-disconnected, cleaned and took all the crud off the battery cables, reconnected them and....my green baby started right up and worked like a champ all day long.
thank you all so much for your quick and accurate responses!
/ HELP needed- JD 770 not starting #6
Great to hear that. Thanks for letting us know.
Unused 2023 Monroe-Tufline DS1120T 10ft. Hydraulic Box Scraper Tractor Attachment (A66734)
Unused 2023...
2022 CASE CX145DSR EXCAVATOR (A65053)
2022 CASE CX145DSR...
2003 Toro Workman 2110 Gas Utility Cart (A66734)
2003 Toro Workman...
2006 FRAC TANK 500BBL WHEELED (A68842)
2006 FRAC TANK...
2013 WINSTON AP22024AL-DC T/A 24FT TRAILER (A66091)
2013 WINSTON...
2012 . Tri Axle Crude Trailer (A67714)
2012 . Tri Axle...
