HELP needed- JD 770 not starting
/ HELP needed- JD 770 not starting #1
RonnieSue
jd 770
My 1996 JD 770 tractor is not starting. i get no lights or anything. checke battery-it's good. i checked the fuses and after pulling them all-it did start. then, a few days later the same exact thing happened. i quickly tried the check the fuses again and this time it didn't help.
any suggestions would be greatly appreciated. i'm in the middle of a big project....thank you
/ HELP needed- JD 770 not starting #2
Welcome to TBN
"get no lights" .. so the starter is not turning the engine over..
Remove and clean all the battery cable connections. Let us know if the engine will then turn over with the starter.
/ HELP needed- JD 770 not starting #3
I suspect bad battery cable or battery connection. Clean and tighten all battery connections and check where ground cable attaches to frame.
battery cables should not move by twisting with your hand
thanks....i am having first cup of coffee now. then going out to check battery cables. i'll let you know results~
You guys are all terrific! Saved my bacon today. Hubby went out and removed battery-disconnected, cleaned and took all the crud off the battery cables, reconnected them and....my green baby started right up and worked like a champ all day long.
thank you all so much for your quick and accurate responses!
/ HELP needed- JD 770 not starting #6
Great to hear that. Thanks for letting us know.
John Deere 5420 Tractor with Quicke Loader (A64047)
John Deere 5420...
12' International Disc (A64119)
12' International...
2018 International HX620 Quint Dump (A62613)
2018 International...
Kuhn FC400RG (A60462)
2025 Intersate Fabrique 12' x 6' Dump Trailer (A62613)
2025 Intersate...
1762 (A58375)
1762 (A58375)
