Help me design an electric log splitter
   / Help me design an electric log splitter #21
I found a 22 gpm logsplitter pump on ebay from dbhwholesale
22 GPM 2-Stage MTE Logsplitter Pump Features:
Made in the USA
Built to OEM Specifications to Take On the Toughest Splitter, Press or Baler Applications
2-Bolt "A" Mounting Flange for Universal Interchange with Other Brand Pumps
Proven Reliability
Outstanding Performance
Performance:
22 GPM Low Pressure to 500PSI
6.0 GPM Hi-Pressure to 3,200PSI
12HP Gas Engine Recommended (10HP Electric)
2-Stage Hi/Lo pumps feature an internal unloading valve that diverts high-volume flow at minimum pressure when high-pressure flow is required. The pumps are designed to direct couple to gas engines or AC electric motors that turn up to 3600 RPM. The unloading feature assures that a small, efficient motor can be utilized effectively.
   / Help me design an electric log splitter #22
From the Dalton Hydraulic web site a 5 HP electric motor is recomended for the 16 gpm log splitter pump.
16 GPM 2-Stage MTE Logsplitter Pump Features:
Made in the USA
CAST IRON Housing
Redesigned 4-Bolt 4F17 Mounting Flange for Universal Interchange with Other Brand Pumps
Proven Reliability
Original equipment replacement for Speeco, MTD and Ramsplitter logsplitters.
Performance:
16 GPM Low Pressure to 500PSI
5 GPM Hi-Pressure to 3500PSI
8HP Gas Engine Recommended (5HP Electric)
MTE 2-Stage Hi/Lo pumps feature an internal unloading valve that diverts high-volume flow at minimum pressure when high-pressure flow is required. The pumps are designed to direct couple to gas engines or AC electric motors that turn up to 3800 RPM. The unloading feature assures that a small, efficient motor can be utilized effectively.
I actually picked up a 3 phase 7.5HP 3600RPM TEFC motor today for 100 bucks. Industrial salvage yard, guaranteed to work or money back. If I use this motor I will need a phase converter or a phase converting VFD. I am hoping to find an affordable VFD, as that way I could slow down the motor and set trip points. I wonder if the 7.5HP motor would run the 22GPM MTE pump well?
   / Help me design an electric log splitter #24
,,,Yes.
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
ATV (A59231)
ATV (A59231)
TUGGER TRAILER (A55745)
TUGGER TRAILER...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2016 Ford F-150...
2015 CATERPILLAR 930M LOADER (A58214)
2015 CATERPILLAR...
2015 WESTERN STAR 4900 GLIDER TANDEM AXLE DAY CAB (A59575)
2015 WESTERN STAR...
