Help me design an electric log splitter
/ Help me design an electric log splitter #21
I found a 22 gpm logsplitter pump on ebay from dbhwholesale
22 GPM 2-Stage MTE Logsplitter Pump Features:
Made in the USA
Built to OEM Specifications to Take On the Toughest Splitter, Press or Baler Applications
2-Bolt "A" Mounting Flange for Universal Interchange with Other Brand Pumps
Proven Reliability
Outstanding Performance
Performance:
22 GPM Low Pressure to 500PSI
6.0 GPM Hi-Pressure to 3,200PSI
12HP Gas Engine Recommended (10HP Electric)
2-Stage Hi/Lo pumps feature an internal unloading valve that diverts high-volume flow at minimum pressure when high-pressure flow is required. The pumps are designed to direct couple to gas engines or AC electric motors that turn up to 3600 RPM. The unloading feature assures that a small, efficient motor can be utilized effectively.
/ Help me design an electric log splitter #22
From the Dalton Hydraulic web site a 5 HP electric motor is recomended for the 16 gpm log splitter pump.
16 GPM 2-Stage MTE Logsplitter Pump Features:
Made in the USA
CAST IRON Housing
Redesigned 4-Bolt 4F17 Mounting Flange for Universal Interchange with Other Brand Pumps
Proven Reliability
Original equipment replacement for Speeco, MTD and Ramsplitter logsplitters.
Performance:
16 GPM Low Pressure to 500PSI
5 GPM Hi-Pressure to 3500PSI
8HP Gas Engine Recommended (5HP Electric)
MTE 2-Stage Hi/Lo pumps feature an internal unloading valve that diverts high-volume flow at minimum pressure when high-pressure flow is required. The pumps are designed to direct couple to gas engines or AC electric motors that turn up to 3800 RPM. The unloading feature assures that a small, efficient motor can be utilized effectively.
I actually picked up a 3 phase 7.5HP 3600RPM TEFC motor today for 100 bucks. Industrial salvage yard, guaranteed to work or money back. If I use this motor I will need a phase converter or a phase converting VFD. I am hoping to find an affordable VFD, as that way I could slow down the motor and set trip points. I wonder if the 7.5HP motor would run the 22GPM MTE pump well?
/ Help me design an electric log splitter #24
,,,Yes.
2007 FREIGHTLINER CL120 6x4 T/A DAY CAB TRUCK TRACTOR (A59914)
2007 FREIGHTLINER...
275 Gallon Cage Tanks, Koser Safe, with 2" outlet (A62679)
275 Gallon Cage...
2019 GMC Canyon SLE 4X4 (A62679)
2019 GMC Canyon...
2017 Chevrolet Silverado Pickup Truck (A62613)
2017 Chevrolet...
2020 PETERBILT 367 (A65643)
2020 PETERBILT 367...
2011 Ford F-750 Water Truck, VIN # 3FRPF7FA5BV653152 (A65563)
2011 Ford F-750...
