Need help with pumping septic
/ Need help with pumping septic #41
How bad is the bridge? Most of the septic pump trucks are just single axle medium duty trucks. And if they won稚 cross the fire department probably won稚 either.
Perhaps the fire department would not need to cross the bridge.
They usually carry LOTS of hose!
/ Need help with pumping septic #42
Does Riddex really work? Have heard both ways on this.
I've never put anything in my tank, but I've heard of people applying activated dry yeast. Experts have told me there should be enough natural bacteria from human waste.
/ Need help with pumping septic #43
What about buying rigid pipes & quick coupler banjo fittings and put special couplers are the ends that fit the septic company’s hoses? You lay them down all connected & ready to go and they come & make the short connections to pump it out, especially with the truck on the downhill side.
/ Need help with pumping septic #44
I thought he said the bridge was on the uphill side? I could be wrong.
/ Need help with pumping septic #45
I know! Get the fire dept to bring their hose and pump it! You're welcome!
:D
/ Need help with pumping septic #46
From what I gather, the OP stated that the bridge is on the downhill side. I’d be overly concerned if it was on the uphill side and the river/creek/brook is above the septic field & house!
/ Need help with pumping septic #47
That makes more sense. Photos would clear up a lot of misconceptions.
/ Need help with pumping septic #48
Can't you find an operator with smaller equipment? Maybe do it in two pumping sessions. Like a small pickup that handles porta-potties? Messing with poop would be the last thing I would feel like doing. How would you clean the equipment? Do you have a thousand gallon tank and truck to transport the material?
Curious on your thoughts about getting fire fighting equipment to your buildings.
I do it every 2 weeks and it is the nastiest job I can imagine. I致e repaired my own septic system, cleaned many many grease traps, horse poop, etc. Been there, done that.
I live in a 24 ft tincan camper that leaks, stinks, and so small I bump something every time I move. It has a black tank and I gotta empty it.
I bought one of those 55 gal plastic barrels, cut it in 1/2 and reassembled. Built a lifting kit so, I can pick the barrel up with my bh, drop it in the hole I must dig, empty the tank and take it to my neighbor.
That痴 not your solution but, it痴 mine and it痴 miserable. 3 more months!
Good luck
/ Need help with pumping septic #49
Hello all-
I have 1000 gallon septic tank but my problem is that we have a fairly small bridge on our property that no septic truck companies are willing to cross. They used to years ago, but as time goes by most of the companies have gotten rid of their smaller trucks. Additionally as time goes by, there seems to be more worry about getting sued for this or that so they are unwilling to attempt crossing our bridge anymore. I have called just about every company around. I have come to the conclusion that it would be easier just to pump it myself. I do have a company who is willing to pull his truck up to the bridge and then I will pump it into his truck. The bridge is about 300 feet from the septic tank. Luckily, it is a downhill run. Probably goes down 5 or 10 vertical feet.
My question Is what type of pump should I buy and what size hose. I could get an electric sewage ejector pump or I could buy a gas powered trash or semi trash pump.The electric pumps are in the neighborhood of 1/2hp, 25 feet max head, 80 gallons per minute, 2 inch discharge, handles soft solids up to 2 inches.
For a gas pump, Harbor freight offers three different options, Ranging from 158 to 380 gallons per minute. They do not specify horsepower ratings on the engine but they look like they range in size from roughly 5 to 8 hp. The smaller gas powered pump has a 2 inch inlet and outlet. The larger pumps have 3 inch inlets and outlets. They are designed to pass hard solids from five eights to three-quarter inch diameter.
I am willing to buy any equipment necessary but I do not want to buy unnecessarily oversized equipment. I understand I will need to use a muck rake to break up the scum layer and to lift up solids from the bottom.
Any advice on pump sizing or other thoughts would be greatly appreciated.
As a last thought, please just accept it as a given that pumping the tank myself is our last option. Reinforcing the bridge really is not an option (it is 90 feet long). I do not want to petition a town for sewer hook up (there is none). And I understand that there are germs in poop.
Thanks!
-Jay
Good luck with a tiny trash pump and a tank 2/3 filled with solids. There's a reason why the honey truck uses a giant vacuum tank and pump.
Talk with your local farmer with a liquid manure pump/tank, he might be will to cross that bridge...if he fits. Then what are you going to do with a thousand gallons of human crap that you might be breaking some local laws dumping in the fields somewhere?
Sorry but it sounds like it's time to fix that bridge.
/ Need help with pumping septic #51
Maybe just put in a new tank beside the old one. Then you would be good for another 20 or so years? Might be cheaper in the long run and less of a headache than trying to figure out getting the old one pumped out.
/ Need help with pumping septic #52
What a crappy discussion.
You are however fortunate as around here it is mandatory to pump every 2 years subject to serious fines.
I owned a house that had a regulation septic system that I had pumped for the first time after some 20 years and that was due to poor flushing action.
Turned out to be blocked by a rag and other objects.
(J cloths simply don't dissolve like paper)
The pumper man said my septic was like about one that was 2-3 years in usage.
The secret is low flush loos, showers vs baths and no garbage shredders.
Also only using white TP as colors don't dissolve well.
Also greases should not be flushed, better to collect in a container and dispose via trash collection in the compostable bin if U have local 3 bin collection system.
/ Need help with pumping septic #53
Pumped every 2 years. Yeiks. A proper system may never need to be pumped.
/ Need help with pumping septic #54
We collect all our grease and food scraps and give it to our birds at the feeders. Grease is high energy and helps our birds stay warmer during the winter.
Ideally, having a grey-water system would help the septic system immensely. The only thing going to the septic would be from the toilet and everything else would drain elsewhere.
/ Need help with pumping septic #55
Culvert fill with gravel next to the bridge??
/ Need help with pumping septic #56
How much land do you have? How close are and how well do you get along with your neighbors? Are the authorities well aware of your predicament? I won't tell you what to do, but years ago when I had more energy than money I did some surreptitious sanitary engineering.
/ Need help with pumping septic #57
DITTO !!!!
/ Need help with pumping septic #58
We only have a 500 gal tank (installed by the PO, don't know why she put in such a small one), and we have it done every 2 years. I find it hard to believe that anyone can go 20 years or more without destroying their leachfield.
Your advice is all good. A graywater drywell system (if legal where you live) is another alternative, at least for laundry water. Don't overdo it, from what I've been told, too little water going into the septic is as bad as too much.
/ Need help with pumping septic #59
Go rent a ground water trash pump, and long discharge hose. We just pump it into the flower bed, the flowers bloom like mad. Surprising the smell was gone in no time.
/ Need help with pumping septic #60
All the septic tank needs is a constant supply of poop. The water is just the means to get it there without clogging your pipes. Hooray for poop!
