Headlight Replacement
/ Headlight Replacement #1
nuvz
Laramie, WY
Yanmar 2010D
I had a headlight bulb burn out on my 2010D. When I took it out, I found it to be a rare breed. It is an oblong bulb with a notched flange... 25/35/watt. Like nothing readily available. I took it out to the John Deer dealer & he tried, but failed. My question is this, Has anyone converted their headlights to halogens? At least the bulbs are available!
/ Headlight Replacement #2
I've heard that a Yamaha(?) motorcycle has a bulb that will replace yours. Check your local motorcycle dealer.
/ Headlight Replacement #3
I've also bought them at Massey Ferguson dealers.
Eugene
/ Headlight Replacement #5
Went to Yahoo to find the Yamaha part number took 40 mins (arrggh). Anyway, here is what was posted sometime back for a replacement bulb for a YM2000. May fit a 2010. Yamnar parts dealers may have the exact bulb in stock as well.
Yamaha part # 21V-84314-00-XX
/ Headlight Replacement #6
Why not just try one of the dealers on this board? They always have them in stock. There is more than one . Different models use different bulbs. All the other bother isn't really needed.
/ Headlight Replacement #7
<font color=blue>took 40 mins (arrggh)</font color=blue>
Man was that a noble deed. Most of the time it takes so long to get in that I just forget about it. The internet hasn't bread patience in me.
Chris
/ Headlight Replacement #8
I replaced my headlights with halogon driving lights (Blazer brand) They fit almost perfectly with no modifications. I kept the OEM lights, and can easily put them back to original if I want. The halogens are a lot brighter, and I am very pleased. They were about $18, probably cheaper than one bulb.
/ Headlight Replacement #9
Thank you for your info!! I got my bulb at the local Yamaha Dealer, & even though your number wasn't the correct one, He dug one out that was in the bin right next to the number you gave and it was just right. Cost a whole $3.17. The correct number was 102843140XX. Thanks Again!!
/ Headlight Replacement #11
Man! Those Yamaha replacement bulbs are going to make some people as <font color=red>mad</font color=red> as the JD replacement keys did on the old club. /w3tcompact/icons/shocked.gif There go the profits. /w3tcompact/icons/sad.gif
Chris
/ Headlight Replacement #12
I agree in general Pennwalk, as I too chase down alternative less expensive parts occasionally. Realistically, the profits on a lightbulb or key would'nt motivate most folks to walk across the room to pick up a cup of air to breath it.
I always try to not take our parts guys for granted, and also refrain from flaunting any savings in thier face. We are lucky to have a few dedicated parts folks here that basically will offer free advise to anyone and offer hard to find parts to those that need them. You can't beat that!
/ Headlight Replacement #13
I certainly am not trying to send business away from our loyal parts guys or dealers. I think they're great, especially one that can send me oil filters in 2-3 days. I use Yanmar parts when something needs replaced. I just tried to give the guy an option other than converting his headlights to halogen And one of these days maybe I need to order a key, since I only have one, even though I drive by a JD dealer every day and he probably has one that "will fit".
CAT CB-334E Smooth Drum Roller (A61166)
CAT CB-334E Smooth...
Kubota M6060 Tractor (A61166)
Kubota M6060...
2019 GENIE S-60XC' TELESCOPIC BOOM LIFT (A62129)
2019 GENIE S-60XC'...
10 TON HYD JACK (A62131)
10 TON HYD JACK...
30 Yard Roll Off Dumpster (A61165)
30 Yard Roll Off...
UNUSED WOLVERINE QC5-26-2DG QUICK ATTACH (A62131)
UNUSED WOLVERINE...
