hauling tree trunks
/ hauling tree trunks #1
marks
San Luis Obispo, CA
JD 870
In order to avoid unnecessary lessons from the school of hard knocks, I've been reviewing the many close-call experiences shared in the safety forum. Here's my situation: I'm a new guy with a JD 870 and a 420 FEL, there's several 6' lengths of a 3' diameter tree trunk (approx 500# ea.) that must be moved several hundred yards. In order to avoid damage to the asphalt driveway and the dirt utility road, I'm hoping to obtain ideas as to the next best method of transporting these logs?? One thought is to load them into my pickup and then pull them out of the bed with the FEL and a chain.
/ hauling tree trunks #2
I have good luck by wrapping a chain around the log and chaining it to the bucket, making sure the chain is as tight as posssible so that it is real snug against the bucket without any play in the chain.
/ hauling tree trunks #3
</font><font color="blue" class="small">( One thought is to load them into my pickup )</font>
HOW are you going to load them into th truck? 6' long by 3' dia. is not going to fit in your bucket, and rigging them with chains and lifting is not going to be easy to balance. i usually use a nylon strap and cinch it around the log( it gets tighter as u pull) if u are concerned about digging in use some kind of a skid plate.
/ hauling tree trunks #4
marks unless that is an old nasty pickup without a tailgate don't do it you'll end up tearing up the truck and if you have a tailgate it won't be for long. Use your FEL as suggested by the previous poster just chain them in the bucket one at a time tightly and transport them low and slow.
Steve
/ hauling tree trunks #5
<font color="blue"> there's several 6' lengths of a 3' diameter tree trunk (approx 500# ea.) </font>
Mark,
Are you sure about that weight?
If they are truly 3' diameter and six feet long, my quick mental calculation says that would be about 36 cubic feet.
Now I don't remember density of wood, but somehow I think it is more than 20 lbs per cubic foot, especially when green and/or wet. At 20 lbs per cu. ft. that would be over 720 lbs. You could be looking at more than that if it is a dense wood.
I've attached a pic of how I carry large pieces sometimes...but this piece was not six feet long...and was willow, which is on the light side... /forums/images/graemlins/smile.gif
I would probably do it like this (toothbar helps) if the loader was able to lift those log pieces.
/ hauling tree trunks #6
Use the 3 pt hitch with a caryall... or a piece of metal roofing under the chained log and pull, a slight bend on the metal prevents it from digging in. You can pull it on the grass/lawn and hardly leave a mark.
/ hauling tree trunks #7
I'm thinking along the lines of Henro, but I calculate about 42 cu.ft of wood (1.5 x 1.5 x 3.14159 x 6) and wood is about 50 #/cu.ft or about 2000 lbs. of wood in each piece. Some woods are lighter and some woods are heavier, and all depends on the amount of moisture in the wood. A tree trunk is probably pretty high in moisture.
I'd cut these pieces into three or four pieces and reduce them to a size that one would slide into your FEL bucket.
/ hauling tree trunks #8
What will happen to logs when they arrive at their destination?
Have you considered just rolling them along with the bucket as the distance isn't that far?
Egon
/ hauling tree trunks #9
An old trick for moving large rocks and such is to use a car hood as a skid platform. Cut some holes in the front of the hood to hook a chain through and drag it away. Guess I should say that a hood from the junk yard is recommended. /forums/images/graemlins/crazy.gif
MarkV
/ hauling tree trunks #10
</font><font color="blue" class="small">( I've attached a pic of how I carry large pieces sometimes )</font>
Hey Bill - is that some kinda new, top secret PHD counterbalance that's under development over there at Henro Labs ? /forums/images/graemlins/grin.gif
/ hauling tree trunks #11
I was wondering the same thing... seems like a lot of FEL weight for such a light rear ballast, even with loaded tires.
Yippee!
/ hauling tree trunks #12
I'm almost thinking it's designed to drill angled holes. /forums/images/graemlins/laugh.gif
Egon /forums/images/graemlins/grin.gif
/ hauling tree trunks #13
<font color="blue"> Hey Bill - is that some kinda new, top secret PHD counterbalance that's under development over there at Henro Labs ? </font>
I think you may be confusing me with the Junkman... /forums/images/graemlins/shocked.gif
I thought the same thing too...normally I have something like my box blade on the back. The tires are filled, and the Rhino PHD is a couple hundred pounds...but still...more weight on the back would certainly be better...
Picture was taken in 2003 I think...beyond my recollection if the back end felt light or not...I don't think it did, but from this distance I would not bet on it. /forums/images/graemlins/blush.gif
/ hauling tree trunks #14
I think the best suggestion was an old car hood...AKA stoneboats....before FEL's and tractors for that matter, farmers used to make and use stone boats for rocking their fields and for moving large logs for resawing or building.
/ hauling tree trunks #15
</font><font color="blue" class="small">( seems like a lot of FEL weight for such a light rear ballast, even with loaded tires. )</font>
I think he just screws it in the ground to keep it from tipping forward. /forums/images/graemlins/grin.gif /forums/images/graemlins/shocked.gif /forums/images/graemlins/grin.gif
2005 LEDWELL LW40ADC - 40' ALUMINUM FEED TRAILER (A63290)
2005 LEDWELL...
2014 INTERNATIONAL DURASTER 4300 EXT CAB DUMP TRK (A62130)
2014 INTERNATIONAL...
AUCTION STARTS HERE @ 9AM (A63276)
AUCTION STARTS...
2014 Freightliner 105' Bucket Truck (A63118)
2014 Freightliner...
2007 MACK CXN (INOPERABLE) (A63569)
2007 MACK CXN...
Arrow Quip EF8 Two Bow Alley Kit (A64047)
Arrow Quip EF8 Two...
