Harbor Freight Tools that don't suck
/ Harbor Freight Tools that don't suck #16,281
Anyone have any experience with the harbor freight brand oil based uv leak detector fluid you use with the hf Braun brand uv light?
Lol uv lights all hf Braun brand uv lights and any brand at any store up north are sold out apparently everyone's buying them to search for these things locals call "yooper stones" on the beaches up here. They do have a massive surplus of oil based uv leak finder oil everywhere here hough. Meanwhile I just want to find one uv light somewhere to check for hydraulic leaks and actually see newer hydraulic fluid in a sight glass 😂.
/ Harbor Freight Tools that don't suck #16,282
It looks like these are cheaper on Amazon. Hmm...
I got the Dawnroad version that's going for $60 now, I've only used my lowish torque 1/2" Bauer impact on it but it's held up fine so far (if you try really hard you can apparently shear the roll pin). Just watch the reviews as per normal on the bamazons... :)
/ Harbor Freight Tools that don't suck #16,283
dunno if it’s been posted already, but those cheap orange picks there are a great asset. I have a nice set of USA made channellock picks that I use for O rings and precision work of that sort, but the HF ones are great for pulling seals, cleaning grooves, basically anything you’d need a small tool that you can beat the snot out of like that. I keep a set around all the time, and they’ve been surprisingly hard to break.
I definitely recommend splurging on icon or something else for impact sockets- my Pittsburgh set got rounded off and beat up after a while. Good to keep in the truck though.
/ Harbor Freight Tools that don't suck #16,284
Those cheap orange handled picks certainly are nice to have around as is the 6 in 1 (I think it's called that) screwdriver.
I have 10 year old Pittsburgh impacts and those have been great, I have yet to ruin one after years of beating on them. Maybe the newer ones are not as good?
/ Harbor Freight Tools that don't suck #16,285
Thanks for that. I don't mind shearing a pin, I seem to end up modifying the cheaper tools to be better unless total junk. :D
/ Harbor Freight Tools that don't suck #16,286
To be fair I was using them hard as an ag mechanic at the time. For a DIYer or shade tree guy there’s nothing wrong with em.
/ Harbor Freight Tools that don't suck #16,287
This little hf central machinery electric 5 ton log splitter works as well as my other Ryobi brand 5 ton I use down state I bought this one for up north to make kindling for wood stove and split softer wood for campfires sure beats previous more dangerous methods I used and I'm comfortable with the kids using it so they get off there screens and do something. Takes aw32 hydro fluid or dexron 2 but not recommended to mix both and comes out of box filled adequately, has recommended fluid changes every 100 hrs and will take about a gallon.
/ Harbor Freight Tools that don't suck #16,288
I've got a set in it's original metal case from about 30 years ago. I haven't ruined any of those either. They're tough as nails. I did however wear out my Ingersoll-Rand 1/2" air impact wrench of the same vintage. And break a 1/2" Craftsman Breaker Bar using the same sockets.
/ Harbor Freight Tools that don't suck #16,289
I got a thumbnail sized UV light with some reading glasses I bought. It came with a UV sensitive card as well. It shows how effective the glasses are in filtering "BLUE" light. The small UV light is very bright but eats up it's battery pretty quick. It's still fun to play with. :cool:
/ Harbor Freight Tools that don't suck #16,290
I did that with mine at first, then put in some concrete anchors. Just find them, blow them out when ready to use it.
Bruce
I'm off to Menards for these anchors in 1/2bolt x 20thd x 2-deep.
Anyone know off hand the bolt length needed? Would 3-inch or 2-3/4 work?
/ Harbor Freight Tools that don't suck #16,291
Took some measurements, 3-inches is the way to go!
/ Harbor Freight Tools that don't suck #16,293
Here's a HF Don't Suck. The $60 ATV Cargo Carrier.
It's just right for my Focus Wagon. That's a light car, 2768 lbs and front wheel drive, so a heavier carrier hanging out the rear could make it unstable.
20210719_191611rcargorack-jpg.706803
I made the adapter to mount its 2" stinger into the 1.25" receiver on the Focus, using a HF ATV hitch accessory welded below a spare ball mount.
20210722_161529rrhitchadapter-jpg.706804
This works great for light bulky loads. I'm about to use it today.
Recommended!
/ Harbor Freight Tools that don't suck #16,294
I think that a lot of the maligning of HF stuff is from people who are incapable of doing repair or modification. Those of us who can will look at something and say 'it's a good starting point, but it needs a gusset here... or this needs to be sleeved...' and it's good.
Cali, I highly doubt that you could build that from scratch for $60, and the way that you intend to use it will serve you for years.
/ Harbor Freight Tools that don't suck #16,295
Recommended!
Should get a pic of mine. I mounted one of those on the back of my ATV for hauling deer out of the woods. As I aged, I found it harder and harder to pull a fair sized doe ,or even worse a nice buck, up onto the front of my 4 wheeler. This cargo carrier sits low enough to make that chore a little easier. I even made the reciever foldable so that it didn't drag the ground it wasn't loaded.
/ Harbor Freight Tools that don't suck #16,296
Excuse my off topic post but I thought it may be important to mention this. I learned a lesson at HF today. I bought a Bauer 20V Li 4.5" grinder off of the return discount table. Got home, put in a battery and while it did run, it vibrated badly and if I turned the arbor by hand, I could feel a "clunk". I just assumed that it would work. I won't denigrate HF because if I understand their policy, I have five days to return it. Going forward, I will be checking the arbor movement, etc., on any return power tool. A couple of years ago, I bought the same model grinder off of the discount rack and it has served me well.
/ Harbor Freight Tools that don't suck #16,297
Delta Executor puede manejar largas sesiones de juego sin bloqueos ni caídas de rendimiento. Esto hace que Delta Executor APK sea ideal para jugadores que ejecutan scripts durante largos periodos sin querer reiniciar el programa.
reported
/ Harbor Freight Tools that don't suck #16,300
A while back I posted that in each project I verify my $12 HF click torque wrench, comparing it with my ancient Indestro beam torque wrench. This guy found his 50yo beam torque wrench is more accurate than his more expensive Icon or Tekton modern click wrenches..
2009 Kubota RTV1140 (A57148)
2009 Kubota...
Kubota SVL 75-2 (A60462)
Kubota SVL 75-2...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A59228)
2025 Kivel 48in...
Crown RM6025-45 4,500 LB Stand-On Electric Forklift (A59228)
Crown RM6025-45...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2001 CATERPILLAR 621F MOTOR SCRAPER (A60429)
2001 CATERPILLAR...
