   / Harbor Freight Tools that don't suck #16,281
Anyone have any experience with the harbor freight brand oil based uv leak detector fluid you use with the hf Braun brand uv light?
Lol uv lights all hf Braun brand uv lights and any brand at any store up north are sold out apparently everyone's buying them to search for these things locals call "yooper stones" on the beaches up here. They do have a massive surplus of oil based uv leak finder oil everywhere here hough. Meanwhile I just want to find one uv light somewhere to check for hydraulic leaks and actually see newer hydraulic fluid in a sight glass 😂.
   / Harbor Freight Tools that don't suck #16,282
It looks like these are cheaper on Amazon. Hmm...
I got the Dawnroad version that's going for $60 now, I've only used my lowish torque 1/2" Bauer impact on it but it's held up fine so far (if you try really hard you can apparently shear the roll pin). Just watch the reviews as per normal on the bamazons... :)
   / Harbor Freight Tools that don't suck #16,283
dunno if it’s been posted already, but those cheap orange picks there are a great asset. I have a nice set of USA made channellock picks that I use for O rings and precision work of that sort, but the HF ones are great for pulling seals, cleaning grooves, basically anything you’d need a small tool that you can beat the snot out of like that. I keep a set around all the time, and they’ve been surprisingly hard to break.
I definitely recommend splurging on icon or something else for impact sockets- my Pittsburgh set got rounded off and beat up after a while. Good to keep in the truck though.
   / Harbor Freight Tools that don't suck #16,284
Those cheap orange handled picks certainly are nice to have around as is the 6 in 1 (I think it's called that) screwdriver.
I have 10 year old Pittsburgh impacts and those have been great, I have yet to ruin one after years of beating on them. Maybe the newer ones are not as good?
   / Harbor Freight Tools that don't suck #16,285
Thanks for that. I don't mind shearing a pin, I seem to end up modifying the cheaper tools to be better unless total junk. :D
   / Harbor Freight Tools that don't suck #16,286
To be fair I was using them hard as an ag mechanic at the time. For a DIYer or shade tree guy there’s nothing wrong with em.
   / Harbor Freight Tools that don't suck #16,287
This little hf central machinery electric 5 ton log splitter works as well as my other Ryobi brand 5 ton I use down state I bought this one for up north to make kindling for wood stove and split softer wood for campfires sure beats previous more dangerous methods I used and I'm comfortable with the kids using it so they get off there screens and do something. Takes aw32 hydro fluid or dexron 2 but not recommended to mix both and comes out of box filled adequately, has recommended fluid changes every 100 hrs and will take about a gallon.
   / Harbor Freight Tools that don't suck #16,288
I've got a set in it's original metal case from about 30 years ago. I haven't ruined any of those either. They're tough as nails. I did however wear out my Ingersoll-Rand 1/2" air impact wrench of the same vintage. And break a 1/2" Craftsman Breaker Bar using the same sockets.
   / Harbor Freight Tools that don't suck #16,289
I got a thumbnail sized UV light with some reading glasses I bought. It came with a UV sensitive card as well. It shows how effective the glasses are in filtering "BLUE" light. The small UV light is very bright but eats up it's battery pretty quick. It's still fun to play with. :cool:
   / Harbor Freight Tools that don't suck #16,290
I did that with mine at first, then put in some concrete anchors. Just find them, blow them out when ready to use it.
Bruce
I'm off to Menards for these anchors in 1/2bolt x 20thd x 2-deep.
Anyone know off hand the bolt length needed? Would 3-inch or 2-3/4 work?
2020 Kinze 3505 High Speed 6/11 Planter (A56436)
2020 Kinze 3505...
T-POST PULLER (A52708)
Great Dane Van Trailer (A56435)
Great Dane Van...
CATERPILLAR CB-224C DOUBLE DRUM ROLLER (A52707)
CATERPILLAR...
Deere 35P (A53317)
Deere 35P (A53317)
2014 Ford Taurus Sedan (A56859)
2014 Ford Taurus...
