   / Harbor Freight Tools that don't suck #16,291
I'm off to Menards for these anchors in 1/2bolt x 20thd x 2-deep.
Anyone know off hand the bolt length needed? Would 3-inch or 2-3/4 work?
Took some measurements, 3-inches is the way to go!
   / Harbor Freight Tools that don't suck #16,293
Here's a HF Don't Suck. The $60 ATV Cargo Carrier.
It's just right for my Focus Wagon. That's a light car, 2768 lbs and front wheel drive, so a heavier carrier hanging out the rear could make it unstable.
20210719_191611rcargorack-jpg.706803
I made the adapter to mount its 2" stinger into the 1.25" receiver on the Focus, using a HF ATV hitch accessory welded below a spare ball mount.
20210722_161529rrhitchadapter-jpg.706804
This works great for light bulky loads. I'm about to use it today.
Recommended!
   / Harbor Freight Tools that don't suck #16,294
I think that a lot of the maligning of HF stuff is from people who are incapable of doing repair or modification. Those of us who can will look at something and say 'it's a good starting point, but it needs a gusset here... or this needs to be sleeved...' and it's good.
Cali, I highly doubt that you could build that from scratch for $60, and the way that you intend to use it will serve you for years.
   / Harbor Freight Tools that don't suck #16,295
Recommended!
Should get a pic of mine. I mounted one of those on the back of my ATV for hauling deer out of the woods. As I aged, I found it harder and harder to pull a fair sized doe ,or even worse a nice buck, up onto the front of my 4 wheeler. This cargo carrier sits low enough to make that chore a little easier. I even made the reciever foldable so that it didn't drag the ground it wasn't loaded.
   / Harbor Freight Tools that don't suck #16,296
Excuse my off topic post but I thought it may be important to mention this. I learned a lesson at HF today. I bought a Bauer 20V Li 4.5" grinder off of the return discount table. Got home, put in a battery and while it did run, it vibrated badly and if I turned the arbor by hand, I could feel a "clunk". I just assumed that it would work. I won't denigrate HF because if I understand their policy, I have five days to return it. Going forward, I will be checking the arbor movement, etc., on any return power tool. A couple of years ago, I bought the same model grinder off of the discount rack and it has served me well.
   / Harbor Freight Tools that don't suck #16,297
Delta Executor puede manejar largas sesiones de juego sin bloqueos ni caídas de rendimiento. Esto hace que Delta Executor APK sea ideal para jugadores que ejecutan scripts durante largos periodos sin querer reiniciar el programa.
reported
   / Harbor Freight Tools that don't suck #16,300
A while back I posted that in each project I verify my $12 HF click torque wrench, comparing it with my ancient Indestro beam torque wrench. This guy found his 50yo beam torque wrench is more accurate than his more expensive Icon or Tekton modern click wrenches..
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2016 Volvo EC220EL (A55272)
2016 Volvo EC220EL...
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
Deere 310L (A53317)
Deere 310L (A53317)
2003 Big Tex 10PI...
CASE IH MX220 MAGNUM TRACTOR (A57192)
CASE IH MX220...
