Quick Hitches HARBOR FREIGHT QUICK HITCH
/ HARBOR FREIGHT QUICK HITCH #21
I bought a county line from TSC that worked fine with my newer implements but would not on some of the older ones. A few minutes of thinking and adjusting and all fit now and I could not be happier. It has not come off the tractor in over 4 years now. I also made a hitch receiver to fit it with a draw bar set up that works great. I had looked at the Pat's units and did not see the point in it. All I do is back up to the implement needed and it's hooked up and off I go. With the Pat's you still need to get off and hook up so why bother?
Does it hook up the PTO or do you just use implements that don't require a PTO?
/ HARBOR FREIGHT QUICK HITCH #22
/ HARBOR FREIGHT QUICK HITCH #23
Out of the eleven implements I have only three need to hook up to the pto shaft bxm32 chipper, bushhog, and rotter tiller.
SPARTAN XBC173072-72" HYD BRUSH CUTTER (A65056)
SPARTAN...
AGT Top Cat Brush Cutter (A64047)
AGT Top Cat Brush...
Unused 2023 Monroe-Tufline DS1144T 12ft. Hydraulic Box Scraper Tractor Attachment (A66734)
Unused 2023...
DIGGIT 72MM MULCHING HEAD (A65056)
DIGGIT 72MM...
VANTAGE 38' FRAMELESS ALUM DUMP TRAILER (A64278)
VANTAGE 38'...
2016 Ford Escape SUV. (A66738)
2016 Ford Escape...
