Quick Hitches HARBOR FREIGHT QUICK HITCH
/ HARBOR FREIGHT QUICK HITCH #1
AZ1500D
Kingman,AZ
Yanmar 1500D
I have a Yanmar 1500d with 3point hitch. Probably Cat-0. Any suggestions on using the quick hitch with my setup?
/ HARBOR FREIGHT QUICK HITCH #2
My cousin bought one of those in CAT I. It would fit one of his implements. That's it. He would probably sell it to you cheap. :D
/ HARBOR FREIGHT QUICK HITCH #3
Tractordata says your 1500 has a cat 1 - 3 pt.
If it is the HF quick hitch would work.
Check the attached chart. If you have 20" width you may be Cat 0. 26-27" Cat 1
/ HARBOR FREIGHT QUICK HITCH #4
I have one that I use. I have a cat 1 tractor though. I did have to do some grinding on the hooks so it would fit my tiller. I removed about an 8th of an inch on both sides. I got it on sale for 79 dollars so I figured since it was so cheap I'd give it a shot. It's worth that at least.
/ HARBOR FREIGHT QUICK HITCH #5
His problem is his implements, not the hitch. I have had mine 20 yrs before the I-Match came out. Fits most of mine, but some of my older attachments have had some modifications to make fit (not because of the hitch). The hitch has the same dimensions as an I-Match or any other brand.
/ HARBOR FREIGHT QUICK HITCH #6
/ HARBOR FREIGHT QUICK HITCH #7
/ HARBOR FREIGHT QUICK HITCH #8
Don't wast your time and $$$ like FOOT said attachments for the most part won't fit and will need changing some easy but some not so easy. I would sell ya mine for a bargain if you were closer,get a set of Pat's like I did fit all with no troubles,just a little longer but worth the $$$
/ HARBOR FREIGHT QUICK HITCH #9
I bought one a few years back as the price was too good to pass up. Once I tried to hook up my attachments, I realized quickly that I should have passed it up and back it went. None of my implements would fit and I was unwilling to make any "modifications" to them. Seems to defeat the purpose of a quick hitch IMO.
I would suggest checking out the Pats system or something similar. Bit more pricey, but well worth it for me and you will have it for a long time.
/ HARBOR FREIGHT QUICK HITCH #10
You will need to look at your implements and use and see if the HF will work for you. I couldn't live without mine. Yes, the hooks were not forged exactly square and it took 10 minutes with a grinder to fix them. My box blade and boom pole are quick hitch compatible and work directly. I built my own trailer receiver/draw bar so it fits perfectly also. My log splitter requires the HF adjustable hook to be moved and I still have to get off the tractor to connect the top pin, but it's still a lot easier. My Chinese snowblower needed a good bit of work, but it was screwed up from the start and didn't work exactly right with the original 3 point hitch either.
/ HARBOR FREIGHT QUICK HITCH #11
I want to try a HF quick hitch, cheap enough, but with the limited lift capacity of my JD 3005, every inch further back the impliment moves reduces lift abilities.
/ HARBOR FREIGHT QUICK HITCH #12
I bought a county line from TSC that worked fine with my newer implements but would not on some of the older ones. A few minutes of thinking and adjusting and all fit now and I could not be happier. It has not come off the tractor in over 4 years now. I also made a hitch receiver to fit it with a draw bar set up that works great. I had looked at the Pat's units and did not see the point in it. All I do is back up to the implement needed and it's hooked up and off I go. With the Pat's you still need to get off and hook up so why bother?
/ HARBOR FREIGHT QUICK HITCH #13
I bought one about a year ago. It is advertised as Cat 1.
It meets the Cat 1 center to center distance between lift pins and top link pin = 18 in.
It meets the Cat 1 lift link spread = 26". The HF is a little over 27" allowing some clearance.
It meets the Cat 1 top link pin diameter = 3/4".
It did not meet the Cat 1 lift link pin diameter supposed to be 7/8". The holes were 3/4" so I drilled out to 7/8" which is what the B21 lift pins are. That took about 3 minutes.
It works with my Cat 1 implements - Land Pride rotary cutter, Land Pride tiller, and Bush Hog box blade.
/ HARBOR FREIGHT QUICK HITCH #14
All the cheap ones are about the same... Harbor Freight, TSC, Northern Tool. I've had several & all required a bit of work. Had to grind a few lift hooks out a bit. On all of em I weleded a 1-2" extension to the back of the top hook so the QH frame wouldnt hit on some of the implement frames.
One of the QHs got welded to a SSQA plate so I could mount or carry 3pt implements on my loader. The lift hooks on that QH is also the mount & pivot for my converted truck snow plow. Chain goes up to a separate pin in one of the toplink adjustment holes.
I love my Quick Hitches. Although I doubt I'd be half as excited if I didn't have TnT. You do have to modify some of your implements to fit at times, especially older stuff. But if you have the skills, its worth it.
/ HARBOR FREIGHT QUICK HITCH #15
Is there no such thing as a draw bar that slides in to the hitch and pin spot or do you have to use the 3 point system.. I have a kabota b26 and i jut want to tow a trailer around the ranch.
/ HARBOR FREIGHT QUICK HITCH #16
I have an inexpensive one I bought from AgriSupply. Mine came with 3/4 bottom pins but it isn't a problem. Also the bottom pin hooks are huge so I use Cat1 to Cat2 to Cat3 bushings on all my bottom pins for a tighter fit. I also bushed up most of the top pins to Cat2.
Ended up modding most of my stuff to work on it and didn't actually set the top link height to Cat1 specs. Doesn't matter as all my stuff is fitted to the hitch now and for the most part I like using it. My landscape rake I have to lengthen the top link to hook up then shorten it back up to use the implement. Most implements require a different top link setting so it's no big deal. Most I used the bolt for the supports instead of the top pin location.
I didn't even attempt to make my brush cutter work with it because I would need a longer driveshaft plus that top link needs to float.
/ HARBOR FREIGHT QUICK HITCH #17
There are lots of posts on modifying the HF QH including probably 3-4 of mine. Mine works great since modifying the QH a little. All my implements are newer QH compatible so that was not a problem. Easy to make the float function from some 1 1/2 X 1/4 flat bar. If you do not have mechanical skills and a welder you will probably unhappy with the HF one. I saved a bundle.
Ron
/ HARBOR FREIGHT QUICK HITCH #18
I love my quick hitches. It makes hooking up easier and unhooking a breeze. Like the guys have said you need to have QH compatible implements or modify the implements to work. Also with all QH's you need to put bushings on the lift arm pins and top link pin of the implement to Cat3.
Here is a video I made comparing the HF QH to an imatch.
/ HARBOR FREIGHT QUICK HITCH #19
Here is a video of an imatch in action.
Width is the problem. I can squeeze out 23". Everything else is sized Cat 1. The HF QH takes the lowers in at 28"
I'm looking at different lowers. Then I probably would have to reverse the rear tires to gain the width opening.
Mabey i'll just keep looking.
Thanks to all who answered.
2022 Ford F-250 Knapheide Service Truck (A66736)
2022 Ford F-250...
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
SARLO (A64557)
SARLO (A64557)
2014 MAC FLAMELESS HEATER  (INOPERABLE) (A68842)
2014 MAC FLAMELESS...
Unused 2022 Continental Belton Auger Tractor Attachment with Bits (A66734)
Unused 2022...
Year: 2015 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: 83,704 Plate: Body (A61573)
Year: 2015 Make...
