Harbor Freight 180
/ Harbor Freight 180 #1
lutt
Platinum Member
Pocahontas, Arkansas
Kubota ZG 22, John Deere 4200 4wd/ 420 loader, 4 wd,08 polaris 700 ranger crew
Now, don't go thinking I'm promoting these welder a. I'm a Lincoln man, I have a AC/DC red that I do about all my welding with. A couple trips ago out at work, my wife was at the local auction house and called me up, she asked if I was still wanting a mug welder. I said that yes, if cheap enough. Well, 125 dollars later I was owner of a new 180 Chicago electric mig. I welded on my bucket hooks with it this evening, using .30 flux core wire. I don't know how long it will last, but I won't be using it daily either. She will burn plenty hot enough. I'll keep you guys up dated when it breaks or I find any faults with it. Who knows, it may outlast me! LUTT
/ Harbor Freight 180 #2
Congrats! Can't go wrong for the price!
Sent from my iPhone 5s 64Gb using TractorByNet
Thanks, that's what I thought! LUTT
/ Harbor Freight 180 #4
Your weld looks pretty good to me. :thumbsup:
/ Harbor Freight 180 #5
What flux-core did you use? Bucket hooks shouldn't be welded on with the general purpose flux-core that most of those machines come with. Kind of like you wouldn't weld them on with 6013.
/ Harbor Freight 180 #6
What should they be welded on with?
/ Harbor Freight 180 #7
I bought the same welder off Craigslist for $150. The owner had it for 3 weeks and had welded with it 1 time. Included a 10' cord. So far I have welded a few things and it has performed flawlessness. Easy to weld with and so far so good. It has DC output on flux core. At the price you can't go wrong. Eventually I will get a larger Lincoln but for now it will suffice. Nothing wrong with these welders.
/ Harbor Freight 180 #8
lutt,
Nice find on the welder ! ! :thumbsup: Looks to me like it does a great job. I also have a mig welder, and will be changing to flux core wire. The price of argon / carbon dioxide is getting to be too expensive here. Let me know how the flux core works for you. :cool2:
Dave
As far as I know, it's just a all position wire, there is really not much info on there brand of wire. I will do some research. Thanks LUTT
Thanks, that's good to know, it's a smooth running machine when you get it right. I know I'm proud to have it. Specially for a quick weld fix and the like. LUTT
lutt, Nice find on the welder ! ! :thumbsup: Looks to me like it does a great job. I also have a mig welder, and will be changing to flux core wire. The price of argon / carbon dioxide is getting to be too expensive here. Let me know how the flux core works for you. :cool2: Dave
Thanks, I also don't like the added expense of gas. But, I made a extension cord out of some 12-2, so I can weld outside. Argon and outside don't mix! LUTT
/ Harbor Freight 180 #12
I haven't had a problem welding outside. I just put up a pallet covered with a tarp to block the wind if it is over about 3 mph and no more problem. :2cents:
Dave
/ Harbor Freight 180 #13
You're right, it's DC. I edited it out of my comment. :eek:
The user manual has apparently been revised since I looked it up a couple years ago. I almost bought one back then, and the user manual then said AC.
2023 John Deere Z960M Zero Turn (A63116)
2023 John Deere...
2021 Takeuchi TL10V2-2 Track Loader with 76in Tooth Bucket (A63118)
2021 Takeuchi...
2023 Kubota U48-5 Compact Excavator with Angle Blade and Hydraulic Thumb (A63118)
2023 Kubota U48-5...
2013 Felling Trailers T/A Side Dump Flatbed Trailer (A56857)
2013 Felling...
2017 INTERNATIONAL PROSTAR + 122 6X4 T/A SLEEPER TRUCK TRACTOR (A59911)
2017 INTERNATIONAL...
159116 (A60430)
159116 (A60430)
