Grid-tied solar
/ Grid-tied solar
My electric installation has three meters. One is total power. One is for geo in the house and one for heat pump in the shop building. The power consumed by geo and the heat pump is subtracted from the total and charged at lower rate during the heating season. If I understand interconnection agreement correctly the coop will install another meter measuring power delivered to the grid. The meters are read once a month. If there is excess compared to total power delivered from the grid it is applied as credit for next month etc. If there is still excess at the end of a year it will be converted to cash at rate 3.5 cent or whatever the wholesale rate is at that time. In other words the solar system should be sized to just cover the consumption for the best ROI.
That sounds logical, but I would get a definite answer about using net-metering and reduced heating rates in combination. Chances are, they won't do anything your state PUC doesn't require them to do.
/ Grid-tied solar #122
I just got a quote for a hardware DIY for a system that would produce about 55000 kWh/ year. $96000 pre-incentive.
180 ea 250W mono panels.
20 kW inverter or add $10000 for 180 micro inverters.
Support structure
disconnect etc.
If their calculation are correct (I doubt they are wrong) the pay back period, assuming constant rate 0.11c/kWh, would be about 11 years.
I think I buy 45 panels and see how it will go.
I agree- "Wow!" Kind of makes me feel a lot less significant with my 20 panel 4kW system! If I were in your shoes, however, buying all that electricity each month I bet our system would be bigger. Please keep us posted as the project moves along. You won't believe the satisfaction that comes at the end of the project when you are making your own power!
Frank
/ Grid-tied solar #123
/ Grid-tied solar #124
There are a multitude of articles although it appears many have been scrubbed for political correctness. Here is but one although most state degredation rates around .08%/yr:
http://photovoltaics.sandia.gov/docs/PDF/IEEE Quintana.pdf
http://www.waset.org/journals/waset/v58/v58-120.pdf
It is possible that modern manufacturing methods have helped diminish early failure rates of panels.
I talked to a researcher from Iowa State University working in alternative energy field few days ago. He said that the certified panels will drop to about 90% of the guaranteed capacity. The way they do it is that the tolerance is always positive. In other words if they rate the panels to 220 W most of them will generate 235-250W. I also asked about the AC efficiency. The current technology is about 77% at the connection to the outlet/grid.
/ Grid-tied solar #125
My system is right around 96%....
Panel ratings are based on Standard Test Conditions. You should be looking at the Nominal Rating when building your system.
/ Grid-tied solar #126
We are just exploring a loan for solar system. Iowa gives zero percent loan for half of the project but it has to be paired with commercial loan for the other half. If the zero interest loan is less than 25K it gets approved quickly.
Here is my system proposal:
92 Hyundai 250W mono panels.
92 Enphase 215 inverters.
1 Energy Management Unit for monitoring via web.
Unirac ground racking system.
Got a quote for 52k shipping, all drawings included + added estimated 3K for incidentals such as cable, concrete etc.
Eligible for 30% federal tax write off and up to 3000 Iowa tax write off.
Unfortunately own installation work can't be added to the total cost of the system unless you own a business that can be billed for the work.
Expected yearly generation 31000 kWh.
Expected payback 11 years assuming constant cost of electric power.
I figured that the loan payment will be about same (expected rate is 5% for 25k therefore effective interest for 50K is 2.5%) what we pay for electric power now so it will not affect our budget any significant way.
Cost of power increased at rate 2.1%/year in past 20 years in Iowa so if the trend continues the power will be 23% more costly after 10 years and 51% after 20 years.
I will talk to an expert at the university to make sure my assumptions are correct before I commit to the project.
/ Grid-tied solar #127
Tim.
The rated power is 250W, nominal power is 228W for the panels I intend to use. Assumed AC efficiency for calculation of power production with Enphase inverters is 80%. I think it is due to high temperatures in the summer. I let the experts to do the calculations of expected production.
/ Grid-tied solar #128
Modern grid tie inverters are in the high 90% range for efficiency. You will find bigger losses in your electrical runs than in the inverters.
As for sizing the array, I initially had 48 x 235W ( 11280W ) panels split between two 5KW inverters. In the heat of the summer they were peaking at ~9KW. So I put up another 8 panels this spring. Now on the hottest days, it is pushing the inverters into a slight surplus, which is dumped as heat. So you can do a quick calculation to see how much the panels are degraded by heat.
Your highest potential for output is in March/April, and Sept/Oct, when the temp is cool and the irradiance is still high. It is important for me to maximize my output though, because I am selling to the grid but am limited to 10K peak output by the terms of the contract.
/ Grid-tied solar
I just learned of another thing to consider about residential energy systems of all types. A fellow in a neighboring town told me the town is putting a value (25%-30% of the installed cost) on his small wind turbine and including that in his property tax evaluation. He says solar PV systems are being valued at their full cost. He is a bit peeved to say the least.
I know real property and personal property tax laws vary considerably around the country, but have any of you run into this issue? I am afraid to ask our local tax clerk :eek: Not really, she is a very nice and helpful person, but I will put it off until I have more info.
For example, if a person installs an outdoor wood boiler, or a geothermal system, are the cost of those included in tax evaluations in your areas?
/ Grid-tied solar #130
I don't know, but I almost do Dave. My county is on the lookout for any improvement or change whatsoever. My heat pump that was taxed for many years goes belly up, they want to know of the replacement so they can tax it at full value. Generally, anything that gets inspected also gets taxes, and the inspection can be thought of as a way to get the change on the tax roles as much as for any other reason. Same for carpet, or most anything, but they feel too silly to call in the carpet inspectors, so we are on our honor. Unless a county chooses to favor certain real property (thinking it is a good thing and wishing to encourage more) they are all mostly pretty hungry for tax revenue.
/ Grid-tied solar
I'm sure it is revenue driven, I just wonder how consistent they are in applying it.
With cutbacks in state spending, lots of tax burdens are going to shift to local towns and counties, so I suppose they will be looking harder for something to tax. We are already over-reliant on property taxes around here.
/ Grid-tied solar #132
I believe that in Tx they will not charge you tax based on the value of your solar system.
/ Grid-tied solar #133
You are correct that in Texas these systems are exempt from property tax, but the legislature recently passed a law which says that homeowners must apply for this exemption every year! If that isn't the stupidest thing I've ever heard, I don't know what is. It's not like it's going to change every year. See: http://www.window.state.tx.us/taxinfo/taxforms/50-123.pdf
My local tax appraisal authority (Dallas County) says they are not putting a value on the systems and won't be enforcing this statute for at least the next five years, in hopes that the law will be changed or rescinded by then.
This subject does bring up another one: If adding a PV array to your house does increase its value, how does that affect the payback calculations? I had an appraisal done on my home for refinancing purposes, and the appraiser assigned a higher value to the array than my original net cost. It could be argued that my payback was immediate (not that I want to start an argument) and my monthly savings are gravy:thumbsup:.
/ Grid-tied solar #134
BillG...
Also not starting trouble, this is just a question. Is it possible that you have recovered its value in the appraisal today...but an appraisal in twenty years will be less complimentary ? The technology at that time may be quite different.
/ Grid-tied solar #135
BillG...
Yes, the technology will be different, but its value as a productive asset should be greater, assuming that electricity prices rise faster than the array's efficiency degrades. The appraiser didn't add value because it looks nice, or because it added square feet to the dwelling; he assigned value to it based on the reduction of operating costs that it provides.
/ Grid-tied solar
BillG...
It is a depreciating piece of equipment for sure. Its value over the years declines, like an vehicle. It seems odd to me to blend an asset of that type with property that changes value with the market.
I have to learn more about the tax laws. I think Maine towns can legally assess personal property (furniture, tools, appliances, etc.) but I am not aware of any that do. That would be the end of those selectmen :) Is a solar pv system an appliance, part of a home's mechanical system, or what?
/ Grid-tied solar
??? Does the appraiser really give hoot really what it produces? I don't know about that idea. It's possible.
/ Grid-tied solar #138
Well, we all know that an appraisal isn't money in your pocket, but I was pleased to find out that he did assign a value to it, and I don't know any other basis he could have been using other than utility cost savings. Has anyone else with a PV system had experience with a property appraisal post-installation?
However, if I was buying a house with a PV system already installed, I would be very reluctant to pay extra for it unless 1) I really understood how it worked, 2) I calculated how much money it could save me, and 3) I had it checked out thoroughly by an informed electrician.
If I was an uninformed buyer I might be more likely to insist that it be removed before closing :eek: ! I'll have to be prepared for that when it comes time to sell this house.
/ Grid-tied solar #139
Thats a pretty good assumption as most buyers are very reluctant to pay for something they dont know. Thats why an investment like pv or geo thermal heating should be done in a Home you intend on having for a long time.
/ Grid-tied solar #140
Those are all good points. While it may seem futile, u could start a spreadsheet tracking past bills without solar and then tracking the difference from solar panels on... If u keep all your bills in a "for when I sell the house" file, it may not take very much convincing.
I don't know if ill ever do it...but I think your move to solar is intelligent. If it ever somehow turned out to have been a mistake... I think it would still be an intelligent one. Did that make sense?
2018 FORD F550 XL 6K LB SERVICE CRANE (A62613)
2018 FORD F550 XL...
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
New 20'x20' All Steel Carport (A62679)
New 20'x20' All...
2021 Peterbilt 389 Sleeper Truck (A62613)
2021 Peterbilt 389...
Kubota MX6000 (A64126)
Wacker Neuson AR14H (A60462)
Wacker Neuson...
