Greasing suggestion needed
/ Greasing suggestion needed #1
rthrbhntg
Delaware Co NY
Kubota MX5100
Any advise on after how many hours to grease the pto shaft and best methods for a mx5100?
/ Greasing suggestion needed #2
i grease my mowers after every use.. that includes the telescoping frive shafts and joints and yokes.. pushes dirt out.. good lub for a high stress area..
/ Greasing suggestion needed #3
My Woods RD7200 mower suggest 25 hours. I adhere to that.
/ Greasing suggestion needed #4
I grease about every 10 hours of mowing use, Which where I live is only 2 or 3 times a year at most. When I mowed 7 acres at another location, I greased every mowing session.
James K0UA
/ Greasing suggestion needed #5
Were you referring to the PTO stub on the back of the tractor? If so, a cleaning to get the grit off and a very light coat of grease once in a while is enough. You don't want gobs of grease hanging off and attracting dirt. I use the rubber cover it came with most of the time to keep it clean when I'm not using the PTO.
Sean
/ Greasing suggestion needed #6
Sean
Ditto that
Charlie
2006 International 7600 T/A Flatbed Truck (A64194)
2006 International...
2001 FREIGHTLINER FLD120 6X4 T/A DAY CAB TRUCK TRACTOR (A67147)
2001 FREIGHTLINER...
2014 Kia Sorento SUV (A64557)
2014 Kia Sorento...
REDDICK 300 GALLON SPRAYER (A64278)
REDDICK 300 GALLON...
JOHN DEERE Z515E ZTRACK ZERO TURN MOWER (A65054)
JOHN DEERE Z515E...
1998 INTERNATIONAL 2674 6X4 T/A VACUUM TRUCK (A66091)
1998 INTERNATIONAL...
