Grappling fun - A Picture Thread....
/ Grappling fun - A Picture Thread.... #1,301
Now that we have a [little] tractor to move them with, we put them on the burn pile instead [of leaving them in the woods]..
We have a perpetual burn pile that we stack on year around and burn in the fall/ spring and don't worry how many burns it takes before the stumps are gone.
/ Grappling fun - A Picture Thread.... #1,303
Added a second grapple to the family...
/ Grappling fun - A Picture Thread.... #1,305
I really like the teeth extensions you can get for this grapple. I really like mine
/ Grappling fun - A Picture Thread.... #1,307
So far its been a great logging/general purpose grapple. The extension teeth and rock plate are a must for it though.
I like really your grapple xc !! I am wondering why the extension teeth are a must. What kind of troubles did you have w/o them ?? Thanks.
Another toy for Luke. That will be good for moving some of those big rocks around with too.
gg
/ Grappling fun - A Picture Thread.... #1,308
Xc, I think we have the same grapple but I think/thought it is maybe 50% bigger than the frostbite I have seen. (Or maybe my memory sucks!)
Gordon, you are exactly right, I hope to use it mostly for rock. I have considered putting two rows of 3/8 chain between the bottom forks to act as a basket for smaller rocks. I know you can get a piece of flat steel to go between the lower fork tips but was thinking chains might be more versatile and less obstructive when grubbing. Any thoughts?
/ Grappling fun - A Picture Thread.... #1,309
That is asking a lot :D
Try the chain thing - cheap enough. Might want some cross chains. Maybe that is what you meant by a basket. I am just guessing but I think something with spaced out teeth would be better than a smooth plate. Teeth seem to catch on irregular small rocks pretty well. Seems like the plate would work if you could get under them w/o just pushing them forward or on roundish rocks. Then again maybe it would be fine. Duh !
gg
/ Grappling fun - A Picture Thread.... #1,310
Yeah, I do remember their being a GR40 and a GR20. The one I have is a GR40. Perhaps the frostbite is a GR20? I'm not sure. But I do really like this grapple for logs and brush
/ Grappling fun - A Picture Thread.... #1,311
That makes more sense. I remember thinking, "it looks like a toy for a subcompact" when looking at the Frostbite. :confused3:
/ Grappling fun - A Picture Thread.... #1,312
gg
We'll, they are a must for me anyway. I really like the little bit of extra reach. they also slightly angle up which makes it that much easier to lift up larger logs with support from the bottom, and makes it feel that much more like a 3rd hand. It's also a good sacrificial tip when they wear out. Like the blade on a front end loader. I believe the teeth were $150 for the set. But its still a great grapple without them. And for me to say it's "a must" is really just an opinion based off what I do with the grapple myself. And I doubt you'd wear the bare grapple out very fast. Unless you are moving A LOT of large rocks
/ Grappling fun - A Picture Thread.... #1,313
Don't get me started on rocks! :confused2:
/ Grappling fun - A Picture Thread.... #1,314
I intend on building a mean one not for a subcompact but for a full size backhoe. And it'll have a heck of a bite force. The idea for the design was to save cost. Here's one I saw at the NFMS, but I like the more C shaped one better.
/ Grappling fun - A Picture Thread.... #1,315
Thanks xc - I was trying to get a read from you on what those teeth added. I have very little experience with mine so I am naturally open to improving features. I was wondering if the teeth were meant to be used when the rock plate was mounted to give you some teeth/tines to work with. How much extension do they give you. It is hard to tell from the pic ??
This is what the Frost Bite looks like. Probably bigger than you remember Luke. Certainly very similar to the Sundown units. The Frost Bite is a little beefier than the Igland in places, like the cylinder back-up plate and the QA plate. Also, I think the frost Bite lid joints are bushed better. Pretty similar though. Mine cost $1495 including SSQA plates and he "threw in" the rock plate which I did not mount.
The Frost Bite comes as a grapple unit with a left and right bolt-on mounting plate. There are 3 different plates available; SSQA, John Deere, and Euro/ISO. It weighs 359 lbs including the SSQA plate. The opening is 42" and the bottom tines are spaced at 29". It is a pass-by grapple. It has two male 1/2" ISO-B hydraulic QD crimp-on hose end connectors on the 3/8" hoses. The quality is very good.
I just put mine together and got the hydraulic QD's matched up ( changed the tractor from M/F 3/8 ISO-A to F/F 1/2" ISO-B) yesterday morning and used it during the afternoon so I don't have much experience yet but so far I like it quite a bit.
gg
/ Grappling fun - A Picture Thread.... #1,316
Thanks xc - I was trying to get a read from you on what those teeth added. I have very little experience with mine so I am naturally open to improving features. I was wondering if the teeth were meant to be used when the rock plate was mounted to give you some tines. How much extension do they give you. It is hard to tell from the pic ??
gg
I think the teeth add about 6 inches. (I'm guessing as I'm not with the tractor today) I can't really use them and the rock plate together as they use the same mounting holes. I could, but I don't think it would be a good setup. The teeth, I think, are good for timber/very large rocks without rock plate/and finger tip picking up. Medium sized rock picking would have no use for the teeth. I only have a dozen or so rocks to move, most of my work is timber/brush/firewood/scrap metal related
/ Grappling fun - A Picture Thread.... #1,317
gg
Yup, same dimensions. I must have cortical rust setting in...
Mine is an auction find. No plate or model on it. Just the Igland sticker. Not sure how it compares to the current model but probably very similar. Every bushing is greasable....
/ Grappling fun - A Picture Thread.... #1,318
Lucky find at the auction - good for you !!!
I have never seen an Igland Unit but have heard they are very good. I was making my comparison with units branded SunDown which I have seen. But the differences were not earth shattering.
gg
/ Grappling fun - A Picture Thread.... #1,319
gg
On my sundown unit, the little stainless nameplate says sundown GR40 but also says Igland with the Igland logo along with their address in Norway. Though it's made in Lithuania.
/ Grappling fun - A Picture Thread.... #1,320
That little rip saw one looks interesting, but I could not find model/pricing on a quick search.
