Grappling fun - A Picture Thread....
/ Grappling fun - A Picture Thread.... #1,281
Burying them around here doesn't work out because they were already on top of solid rock.
/ Grappling fun - A Picture Thread.... #1,282
My experience is it takes a bunch of fires to get a big stump to burn and if there's very many on the pile you can't get it to burn at all. On my recent land clearing I burnt all the stumps smaller than about 12" and hauled off the rest.
I only put one big ole stump on the pile at a time. And yeah it takes a few burns to 'bury' it. But I can't legally burn huge fires. Limited to 3ft by 3ft by law but I measure that as size of fire not pile. :D The regs aren't clear. :laughing: After a day burn the stump is a good base for the next few lights.
I quit burning, just too much work. Either I bury them (when I rent an excavator to take out key stumps I'll just dig a hole where they were and drop them back down) or I dump them elsewhere (now that I have a tractor that has more grunt, and a grapple!).
Maybe you have too big of equipment. You must not be wrestling big evergreen stumps with a BX sized tractor!
/ Grappling fun - A Picture Thread.... #1,283
Having to big of equipment isn't possible. I had to fight several big ones pretty hard with a 15,000 pound CTL. I couldn't turn the some of the big ones over with my tractor. Loading all of the big ones was a hopeless effort with the tractor. I had to use my backhoe to dig as much dirt as possible off as possible before the CTL would load them.
/ Grappling fun - A Picture Thread.... #1,285
Now you're talking! I'm humbled with only my little BX beast.
I know the feeling. I've never had that small a tractor but the big ones kicked my L3240s butt.
/ Grappling fun - A Picture Thread.... #1,286
Here's a picture from today's grappling adventures (pretty sure that this trunk was right around 2k lbs; I moved an even bigger tree trunk, but the tractor really struggled; one side of the trunk (a "Y") was kind of sliding on the ground- since I can't say that it was truly dead-lifted I can't claim it as a grapple trophy!):
:shocked: No words. :shocked:
Travis
/ Grappling fun - A Picture Thread.... #1,287
Doing some thinning and off to the burn pile. I used to carry a grapple full down to the pile until I seen the use of a trailer here on TBN. Welding a hitch on the back of my Farmi has saved me miles of back and forth with my tractor.
/ Grappling fun - A Picture Thread.... #1,290
Yep, I have been known to load the 8x16 deckover, then hook on and pull it to the burn pile. :D
/ Grappling fun - A Picture Thread.... #1,291
Igland Sundown GR 40 Grapple, same as a Frostbite, just not as expensive.
/ Grappling fun - A Picture Thread.... #1,293
You must have photoshopped that grapple load! Wise people know that narrow grapples simply cannot carry such wide loads.
Wise people know that one should never rely on the width of their grapple to compensate for an off center lift ;) .
So far its been a great logging/general purpose grapple. The extension teeth and rock plate are a must for it though.
/ Grappling fun - A Picture Thread.... #1,294
And wise people know that a single lid like that can't "hold down" a load like that.
/ Grappling fun - A Picture Thread.... #1,295
I think what the photo isn't showing very well are the red teeth extensions that are underneath the bottom hackmatack tree. The have also been drying out for 2 years.
/ Grappling fun - A Picture Thread.... #1,296
Same here. If I were to bury a stump, I would need a case of dynamite to blast out a hole to put it in.
/ Grappling fun - A Picture Thread.... #1,297
Can you post or PM me a closer photo of those teeth and how they attach? Thanks!
/ Grappling fun - A Picture Thread.... #1,298
Sure, You can see here in this photo, they simply bolt to the grapple. There are holes in the lower 2 tongs of the grapple itself, the teeth have corresponding holes that are also recessed to get the bolthead out of harms way. There are locknuts underneath.
/ Grappling fun - A Picture Thread.... #1,299
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=513042"/>
That grapple must have a good under bite to grab loads with
/ Grappling fun - A Picture Thread.... #1,300
That's what they guy who cleared the land and built the house we bought did, and for the last 20 years, I have been filling [usually after falling into] the sinkholes that developed when the stumps rotted away and left previously flat land unsupported.
Once early on, as I was walking over to look look closer at what looked to be a new 6-8" hole in our grassy yard, I fell in with one leg all the way to my hip joint- luckily I was young and more flexible in those days, but what a shocker it was anyway.
Now that we have a [little] tractor to move them with, we put them on the burn pile instead [of leaving them in the woods].
They do take a while to burn though- some of the cedar stumps [pieces now] in our burn pile are left over from up to 3 or 4 burns over the past 5 or so years.
Utility Cart (A59231)
UNUSED WOLVERINE TD-13-36R STUMP DIGGER (A62131)
UNUSED WOLVERINE...
Case SV280B (A60462)
2019 John Deere 4044M (A62177)
2019 John Deere...
UNUSED WOLVERINE SWDB-11-84W HYD DOZER BLADE (A62131)
UNUSED WOLVERINE...
Sunflower Yard Art (A61569)
Sunflower Yard Art...
