grapple hydraulic setup 1026r
/ grapple hydraulic setup 1026r
I got in a rush tonight because my back was hurting and the welds look awful. I overheated my welder too. I'll just have to try again tomorrow.
I also sent back my 1/4in hydraulic fittings to get 3/8 because only 8 of my fittings I ordered fit!!!
/ grapple hydraulic setup 1026r #43
Thanks swick1. I've posted a few lines in the Welding forum and I've been shopping around for a stick welder. However, I'll have to add a new circuit with a 50amp breaker and 6ga. wire in my garage as most of the recommended welders are 240v. What are you welding with?
As far as expenses are concerned I have about $416 in the cut metal. It took almost a whole 4x8 sheet of 3/8 mild steel.
The cylinder and fittings to the quick connect were about $150.
The bolts nuts and washers were about $30
I have used about 7lb of welding rod and half a knotted wire wheel as well as a grinding wheel and die grinder stone so that's about $15
The steel tubing was $80
The paint and primer was $18
John deere quick tachometer parts were $78
So my total cost not counting labor was $737
I probably spent $50 in fuel to get everything together and I've got about 30 hours in it. If I were doing this commercially I could cut my costs by about $50. Even with a better welding setup with jigs and everything it would still take a day to build so I don't think anyone could cover their costs by selling this for less than $900. That doesn't count overhead either so a better number would be closer to $1100.
I'm using a Lincoln ac only buzz box. I wish I had dc capability. 220v 50a
This is the only picture I have of it.
/ grapple hydraulic setup 1026r #46
There is a lot of good talk about buzz boxes in the Welding forum. I'm shopping for a welder right now, but I'll have to wait a month or so until my new grapple is paid for. It's nice to look back at your work and know you built it. You should be proud. Nice job!
/ grapple hydraulic setup 1026r #47
Nice grapple...My question is did you come in under the cost of a pre-built unit or about the same? I saw a post on here about a http://www.markhamwelding.com/content/view/33/56/ and it was about 1k so not sure how much you have in this but it looks like a fun build.
I just bought that unit... now known as North American Implements. The 60" light grapple... to my door was $1240.00 and that was with a special discount. Shipping was $311 the grapple was $929. Without the discount, the grapple was $1129 plus shipping.
Tonight was 3 hrs of welding and grinding.
Note to self: its much faster to quit when your welds start looking bad than to press on and have a mess to clean up later.
/ grapple hydraulic setup 1026r #49
Are you changing the hose ends to 3/8 (#6 JIC) female swivels?
If so, I would use 2404-06-06 QC to hoses, grapple cylinder , 2501-06-06 hoses to grapple cylinder.
2706LN-06-06 Bulkhead fittings with a bracket similar to picture two in post #28 for tractor side QCs to hoses.
Six fewer fittings to do the same thing. Part numbers are from D.H.H.
/ grapple hydraulic setup 1026r #50
Pardon me for dumb questions but at 1026 Deere is approximately 25 hp. The grapple your building looks heavy enough for a 40+ hp machine. If I were building a grapple for my 4110 ( 21hp ) I would use 1 1/2 or 2" square tubing with an 1/8" wall. This is strong enough with a few gussets to withstand the abuse of the above machines. A 22' stick costs roughly 46 dollars. For $125. to include a scrap of sheet for the back plate the majority of the frame work would be complete. I would segment the grapple hooks with tubing and add 3/8" x 1 1/2" metal to the bottom side for additional strength at the welds and act as a contact for the brush / material your moving. The lazer cut pieces are top shelf in looks and durability but spendy for individuals like me who enjoy fabricating out of our steel surplus pile.
Like the thread indicates if your going to copy an existing design down to the lazer cut pieces your not gaining anything but welding experience. Fab shops have the equipment and get better material prices than single one time buyers. Many good comments and information exchanged.
Thanks Zebrafive. I placed my order this afternoon and everything should be here by wednesday. I'll use this weekend to prepare my electrical system. I'm going with a footswitch and no relay that I found at the auto parts store. The switch is used for a remote start and it's waterproof so it should work great. I found a perfect mounting point under my brake pedal to mount the switch, so i still have access to almost all of my controls and I won't have to worry about the joystick that was becoming a pain in the rear! I finished welding last night.
One consideration of my design was that I wanted to be able to put it on a bigger machine when I get one, but thanks for the info. I agree with you. If it turns out to be too cumbersome I can always build another one :)
/ grapple hydraulic setup 1026r #53
That is a good idea. I tend to " overbuild " in some cases. Just thought for the size it could be lighter to increase the capability.
I will be quiet now and read !
We'll see what happens after testing, but my calculations say it could be made from 1/4" mild steel and still endure the loads it will be subject to. That would reduce weight by about 80 lbs.
/ grapple hydraulic setup 1026r #55
What did you calculate total weight to be?
350lbs without hydraulics for the one I built. About 400lbs all together.
By the way, I didn't get to do anything this weekend since our electricity just came back on and now I've got a lot of yard cleanup work to do :-(
Hydraulic fittings are delayed for 2 weeks, I guess this gives me time to paint and do electrical.
Here's where we are today... trying to paint this afternoon.
/ grapple hydraulic setup 1026r #59
Wow, that grapple looks like you bought it swick1! I was wondering were did you mount your diverter valve on your lil' deere?
I haven't yet! I was planning on putting it on top of my right loader arm and building a shield over it.
2004 INTERNATIONAL 4300 4X2 S/A  UTILITY BODY (A66091)
2004 INTERNATIONAL...
LEEBOY 8515B PAVER (A67714)
LEEBOY 8515B PAVER...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61573)
2021 Mercedes-Benz...
LOT OF SCRAP IRON AROUND CEDAR TREE (A63291)
LOT OF SCRAP IRON...
Unused 2020 Kodiak 4AP Towable Aerator Tractor Attachment (A66734)
Unused 2020 Kodiak...
Wheel Loader Root Rake (A68134)
Wheel Loader Root...
