Grapple Grapple clamp preasure
/ Grapple clamp preasure #1
dirt clod
panama city and altha florida
Kubota L3300, m5700, case 580se
I got one of andy tatro's grapples. It clamps down fine for brush. The property I have was left with a bunch of junk and a few buildings in need of demo. If I try to pickup something other than brush it does not have enough clamping power to hold it. Items like loose roofing tin it will not crush into the bucket. acts like the bypass valve on tractor is opening, but I'm running higher than stock preasure. Tractor has plenty of lifting power.Also I have problems with it getting locked up when I drive into brush with it fully open, if it gets bumped back a little more open it gets past the centerline and jams. I know this is a great product and Andy is a great guy to deal with as such I'm not complaining about the product.
Anyone have ideas on the like of clamp preasure and locking up?
It has a 2"x6" cylinder should I go up to a 3"?
/ Grapple clamp preasure #2
A larger cylinder will help, but are you sure the bottom of your bucket is not bowing?
/ Grapple clamp preasure #3
I don't think I have seen any pics of a Tatro Grapple, but the geometry on some designs dosn't leave much available force at the tines/teeth. Do you have any pictures of your installation? If you do, and can tell me the pressures and cylinder size you are working with, we can probably calculate the available force out at the tips of the grapple teeth.
It wouldn't have the preasure to do such. It will not crunch into old sheet metal enough to hold it!
/ Grapple clamp preasure #6
Quinton,
What kind of valve are you using to control it? Sounds like there's not enough pressure to make the cylinder work to me, so I'd check the valve too. Is it a diverter valve you have or a true third function solenoid valve?
You know I have Andy's bucket grapples (two) on my 72" bucket. That's my tractor on his home page in the lower left corner with the dual red grapples. Also in the right top corner on the 3rd "Grapple Pics" page with that giant log in it. I have tons of pics using the grapples.
(Ron, I know you've seen some of those before in other threads.)
I've heard of them going back too far and locking up, but I've never had it happen to me. Not only that, mine have plenty of holding/crushing power so I don't know what to tell you other than check the valve controlling it. Heck, it might be the cylinder too if it's got a leaky "O" ring seal? Do you have a pressure gage to check your system?
Put a guage on cylinder. When I'm closeing the grapple the other port on the cylinder builds preasure up as the cylinder closes. Could it be the selector valve I'm useing?
Another weird thing is if switch around the hoses on the grapple cylinder it acts like it is stuck once it shuts it will not open. Any ideas????????
I've talked to Andy , he's not sure what the problem is. I do know its not a problem with his product though. He has been very helpful.
/ Grapple clamp preasure #8
OK, It sounds like the valve controlling the grapple has a Regenerative circuit built into it, common on loader control valves. Read more about that HERE.
-OR- the seals in the cylinder could be bad allowing the fluid to bypass them.
You need to be more descriptive please:
Where did you place the gauge?
How are you controlling the grapple, Diverter-Solenoid Valve-or separate spool valve?
What pressures did you see?
Testing the cylinder seals is messy, but easy: Remove one hose from the cylinder, the operate the control valve to pressurize the other hose and see if any fluid comes out of the open port on the cylinder, then repeat test for the other port (switch hoses) If you get any fluid from the open port then the seals are bad internally causing your problems.
kennyd many thanks. It makes sense why it is doing what it is.
I did check the cylinder no blow by at all.
my post on the selector valve and how I installed...... http://www.tractorbynet.com/forums/hydraulics/120482-selector-valve.htm
I thought others used a selector valve on these tractors ok?
Any ideas on what I should do?
Install some sort of tank inline to cut down on the volume of fluid?
/ Grapple clamp preasure #10
OK, now I remember...you used that 3 position diverter.
I have no idea what to say except this:
If it is the regen circuit that's causing the problem then you need to figure out how the activate the joystick without hitting the regen...
Like on my JD-the regen is at the far right of the travel only, so if I don't move the stick all the way right then it does not go into regen mode. There is even a lockout at the linkage to keep it from going into regen if I want to lock it out completely.
I am not sure how the Kubota (Husco) valves deal with this...but there must be a way?
Thanks again. Just got done doing a search for what you was saying. One person posted that they swapped the selector valve from the curl/dump valve to the raise/lower valve and this worked. I have not found a setting for a non- regenerative curl/dump on my joy stick. I have never looked for this before though. Its a LA480 loader. One of these two should fix it.
/ Grapple clamp preasure #12
I just did a search for "regen" in the Kub forum...
It seems that the Husco valves have the regen on the first part of the joystick travel-then there is a detent or stiff spot to overcome if you keep pushing right to get out of the regen. This is exactly opposite of mine.
Think your valve has that?
Kubota offered the 4 way valve on some models for a little more money.
I don't know if it was offered for my 98 model, either way it only has the 3 way. Swapped the selector valve to the loader arms and it has good preasure. I put a old metal gas can under it and the claws went all the way through it.:D Thanks for your help, it was getting stressful. And I got this to make life easier:rolleyes: .Sure it will now.
/ Grapple clamp preasure #14
Great, glad you figured it out...
IMHO, This was a big mistake Kubota made for a long time using those 3-way valves. Lot's of people later bought snowblowers or front blades only to find out later they needed to upgrade (replace) the valve to get them to work...
/ Grapple clamp preasure #15
glad you got it figured out.
I have a Tatro grapple on my bucket along with a WR Long valve kit on the FEL and it has tremendous pressure. Maple trees, huge rocks...nothing falls off the bucket:)
Was cleaning up some property this morning. When moving old fridges it would either squish the door in when clamped or punch into the sheetmetal a few inches.:D
/ Grapple clamp preasure #17
Well those pictures sure proved you got it working!
/ Grapple clamp preasure #19
nice work dirt clod:)
I see you have the same issue with the grapple hoses. I had a **** of a time figuring out a way to secure them while leaving the play in the movement of the grapple opening and closing. I ended up getting hydraulic hose wraps that fit both hoses into one wrap and then tied them off with HD zip ties.
/ Grapple clamp preasure #20
OK, now you've got me wondering what's wrong with my grapple. I also have very little clamping pressure. It is a Tatro grapple and I love it, but it has little clamping force. I thought it was the 2x6 cylinder. I am running the grapple off my dealer installed rear remote. It is a Factory Remote. Any ideas?
I'm stupid when It comes to hydraulic jargon. The tractor is a Kubota M4800. I have a Bushhog M346 Loader that was installed by the dealer. The tractor has an open center hydraulic system (I don't know what this means?).
Chris
