Got a "Piranha" toothbar from BXpanded
   / Got a "Piranha" toothbar from BXpanded #51
Would this fit on a 7100HST? I would think the bucket is the same size.
   / Got a "Piranha" toothbar from BXpanded #53
Has anyone used both the Piranha and a conventional toothbar on the same tractor, digging in the same soil, so a real comparison can be made?
Bruce
   / Got a "Piranha" toothbar from BXpanded #55
I have a tooth bar and the racket rake. This looks like it would clear small trees and brush better.
Do you make for that will fit a 72 inch bucket.
   / Got a "Piranha" toothbar from BXpanded #56
Yes that is what I want to know too. It looks almost as good as a ratchet rake for ripping out brush and small saplings, but how long will it last digging in the dirt and when it encounters rocks.. If someone could use it for a while digging in rocky soil and report back..If it is good steel it should work ok. If it is soft, well not so much...
James K0UA
I knocked down the wall in the picture with the hoe and moved it with the FEL and piranha buried the rocks with the FEL .
other picture is after backfilling the hole.
   / Got a "Piranha" toothbar from BXpanded #57
Well that looks good, I cant see any damage on your bar, I am a cautious person, when something new comes on the scene I like to sit back and wait for a while and see how it goes, but I need a toothbar, and that looks good and offers what looks like nearly the function of the ratchet rake of being able to grub out brush and small saplings too.. I think it would work for that anyway. If I may suggest one thing, on your install, to get two more nuts and maybe a washer or 2 and cover the rest of the threads on those bolts before they are "booger'd" beyond repair by rocks and ordinary wear. Just tighten them against the existing nuts by the "double nutting " technique with 2 wrenches. and they should stay. That way if you need to take it off you wont have to fight with ruined threads.
Thanks for reporting back.
James K0UA
   / Got a "Piranha" toothbar from BXpanded #58
Thanks for the tips guys.. I believe mine can handle the slicing into the base of my hills OK. I'm not going but a few feet in and that would be about 2ft of so high on average. It will be a long drawn out summer project that will continue on till the day I roll over..;)
My projects materialize over a great deal of time. I don't like upsetting nature all at once. It's more of an evolution of sorts.
I will most likely have some dig out the drive. There will be enough collateral damage work to keep the Kubota busy.
My buddy down the street has a Bobcat. We have already talked of swapping out each others work and or equip.
   / Got a "Piranha" toothbar from BXpanded #59
To those that have the Piranha, do you know if you would be able to loosen the bolts/nuts and "spin" the toothbar up into the bucket if you wanted to? Sort of laying back inside the bucket, rather that removing it altogether. Hope I'm asking that in a way that makes sense...
1993 20ft. Custom Deck Over Equipment Trailer (A56857)
1993 20ft. Custom...
2004 Mack CV713 Granite Fuel and Lube Truck (A59230)
2004 Mack CV713...
Kubota M4700 4WD 51HP Utility Loader Tractor (A56857)
Kubota M4700 4WD...
John Deere S350 (A60462)
John Deere S350...
(INOP) 2016 CATERPILLAR 259D SKID STEER (A52709)
(INOP) 2016...
2008 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2008 INTERNATIONAL...
