Good morning!!!!
/ Good morning!!!! #191,021
Looking for recommendation for a larger rotary cutter for the L5030. Mowing 100 acres with a 5 ft one is slow. I suggested an 8 ft pull behind to my brother, and my sister said NO!.
I am very happy with the Landpride FDR3690 mower. Not a shredder, but a 3 spindle mower with smaller fre swing blades on a crossbar, sort of a mini shredder. I use it to cut in the pastures.
The 90” cut would be as much as a 30hp tractor could do, you would probably want a smaller one to cut high or thick grass. I use it with 60hp, so nothing fazes it.
/ Good morning!!!! #191,022
68 outside this AM, heading to lower 80's. In ketchup mode.
Storm came through Sunday night and knocked over two trees. One by the koi-less pond, the other on the back pasture fence line. Monday was a hard day of labor. Not what we had planned.
Still no open pool. Just don't have a mastery of time. Today is sort of shot too. Day jobs, paper work and wife packing for in-law visit. Now in-laws are yapping about staying till October and not selling their house. FIL was in emergency room again last week. They just don't get how inconvenient they are making it for everyone else.
Not much else on the agenda today, or for the week. Just trying to keep it all under control.
Hope all have a good day. Be safe.
/ Good morning!!!! #191,023
Good Morning!!!! 63F @ 5:00AM. Sunny to partly cloudy. High 89F. Winds S at 5 to 10 mph.
I think that's maybe why the previous owners of the new house left the washer and dryer, Kyle. And I plan to do the same when I sell. I know I've never cleaned the dryer vent line since I moved here some fourteen years ago. And I don't plan to clean it before the house goes on the market. But I should probably clean the one at the new house since most of the other maintenance items there were left undone for what appears to be a long time.
Took the string trimmer up to the mail box and cut down all the grass growing in the gravel. Then tried it on the loop road but the thistles had grown head high and the stalks were too tough for the string. I thought about going after them with the bush hog, but it's a road and really needs to be clean down to the dirt. Besides, the box blade was already on the tractor, so that's what I used. Took about three laps to get it cleaned up, and the first one was r-e-a-l-l-y slow because I couldn't tell what was road and what was weed. To one side was a steep bank and a long drop, another steep bank on the other side going up. So I stuck to the up side on that first lap and gradually worked toward the drop off to widen things up. Today I'll follow up with a good dose of RM43 to keep the weeds from coming back. Hope never to have to do that job again.
Got the remaining five buckets of bullet alloy loaded in the van, then moved the van closer to the office trailer so I can load all the junk from under it. Then got the sprayer mounted on the Kubota side-by-side. I was supposed to grease the wheel bearings on the little trailer, but forgot. Instead I just called it a day. BBQed chicken breasts for dinner and managed not to burn them too badly for a change.
Hope everyone's week gets off to a perfect start!
/ Good morning!!!! #191,025
Flowers are coming out
/ Good morning!!!! #191,027
L5030 is 50HP, 44 PTO HP. Not sure this would work on 3-4 ft high grass and weeds, that gets mowed once a year. Would love to have 90 " cut. Think an 8 ft dual spindle rotary is too much.
Bush hog 2107 is 7 ft with dual spindle, think that might do the trick.
bush hog 2208 is right at 45 PTO HP for 8 ft mower (3pt). pull type goes down to 30 HP.
/ Good morning!!!! #191,030
Those POE camera's are pretty easy to get going, hard part is running the cable.
Do you need foundation drain with stem wall? Radon system?
The issue with the cheap Amcrest camera was that it wanted to use their software, and there wasn’t an included utility to set it to a fixed IP or select the port used for video. It worked instantly out of the box using their soft ware. The detective work was required in getting it to play with Blue Iris.
No foundation drains, the finished floor will be well above grade, the vapor barrier and heat-crete insulation panels for the radiant floor heat will provide a more than adequate radon barrier.
/ Good morning!!!! #191,031
The 90” FDR might be just the ticket then. It cuts knee high vegetation effortlessly, I think that my L6060 is 53 PTO hp.
/ Good morning!!!! #191,034
66°F and .74 inches rain. Hoping for a dry day.
Didn’t get hot tub refilled.
Really nice HH at neighbors. Plenty good eats.
Off to Kona this morning to pick up my tractor 🤞
Prayers for all
Be safe
Have a great day
/ Good morning!!!! #191,035
60°F and clear skies this morning, only going up to 79° today.
Storms that blew through this weekend left behind some cool air. Can't complain about that. They also left behind some destruction. We only had a few limbs down here and there. After passing through here, a couple of tornadoes spun up just north of Carlyle and damaged some businesses along IL-127. They are just across a field from my Wife's ex-inlaws. Their place only had minor damage, but a nearby repair shop was pretty much leveled.
Springtime in the Midwest.
Planted a bunch of new raspberry and blueberry bushes last week, and today will be a bunch of apple, peach, nectarine, and plum trees. Wife wants to start the orchard over again, so here we go. Back is going to love me tonight.
Took off an additional day this weekend to have a longer four day weekend. Glad I did. Got weathered out on two of them.
Also need to get my golf clubs out and cleaned up, as I'm playing in a work-related tournament this coming Friday. Haven't swung a club yet this year. Should be ... interesting.
Couldn't get TBN to open earlier, then later it opened for a few minutes and crashed, then wouldn't open again. Hoping this posts.
Good morning, gents.
/ Good morning!!!! #191,036
Good Afternoon Dennis,
some things not working right on TBN. can't search, can't create new post.
Dennis, I think I got it straightened out. I also sent a PM to Muhammad explaining what happened, he said he might be able to change those posts back to Scott_vt.
Anyways, I’m back again as Scott_vt !😉
/ Good morning!!!! #191,037
Unless this is an under $40 Amcrest that I haven't seen, you can set the IP. it uses DHCP by default, so you have to figure out what ip it came up on, but then you can log in and set the IP and other items including ports. I think i do use one of their utilities to find it initially, but you don't have to. I have a new one in a box, I'll try it later.
I saw a video where someone used the heat-crete panels to install their radiant, might have been RR builders.
/ Good morning!!!! #191,039
Today was a run around day. Teeth cleaned, chipotle, Lowe’s, groceries, DQ.
Still can’t find 300 ft tape, or 100 ft steel tape. Bought another 100 ft today. Have looked everywhere except its hiding place. Last I remember using it was in the yard. Searched truck, barn, garage, basement, mudroom multiple times.
/ Good morning!!!! #191,040
Good (Wednesday) morning. Overnight Low of 7.8C and it's presently 10.0C, somewhat overcast & calm.
Hardware store trip resulted in getting the correct type of 'weather stripping'... naturally the "brush type" was what I required and was, of course, the most expensive. The "rubber type" was more prolific but deteriorates and leaves a mess when eventual replacement is needed. You get what you pay for, eh?
A Mate stopped by to borrow my inspection camera... I haven't used it in over 7 years but it's one of those "I HAVE IT" tools. Fortunately, I took the 4 AA batteries out of it all those years ago.
A thread from Ibrahim described that TBN was down for maintenance, causing all of your 'posting woes'.
It's 'into town day' for groceries. But first I'll attend a Veteran's Coffee gathering.
2018 Isuzu FTR Landscape Dump Truck (A59230)
2018 Isuzu FTR...
2018 CATERPILLAR 313FL EXCAVATOR (A60429)
2018 CATERPILLAR...
2016 Case CX55B Midi Excavator (A60352)
2016 Case CX55B...
2022 Ligchine Spiderscreed Concrete Screed (A59228)
2022 Ligchine...
2019 Ram 1500 Crew Cab Pickup Truck (A59230)
2019 Ram 1500 Crew...
2013 TEXAS PRIDE LAY FLAT HOSE TUGGER TRAILER (A58214)
2013 TEXAS PRIDE...
