Good morning!!!!
   / Good morning!!!! #191,021
Looking for recommendation for a larger rotary cutter for the L5030. Mowing 100 acres with a 5 ft one is slow. I suggested an 8 ft pull behind to my brother, and my sister said NO!.
I am very happy with the Landpride FDR3690 mower. Not a shredder, but a 3 spindle mower with smaller fre swing blades on a crossbar, sort of a mini shredder. I use it to cut in the pastures.
The 90” cut would be as much as a 30hp tractor could do, you would probably want a smaller one to cut high or thick grass. I use it with 60hp, so nothing fazes it.
   / Good morning!!!! #191,022
68 outside this AM, heading to lower 80's. In ketchup mode.
Storm came through Sunday night and knocked over two trees. One by the koi-less pond, the other on the back pasture fence line. Monday was a hard day of labor. Not what we had planned.
Still no open pool. Just don't have a mastery of time. Today is sort of shot too. Day jobs, paper work and wife packing for in-law visit. Now in-laws are yapping about staying till October and not selling their house. FIL was in emergency room again last week. They just don't get how inconvenient they are making it for everyone else.
Not much else on the agenda today, or for the week. Just trying to keep it all under control.
Hope all have a good day. Be safe.
   / Good morning!!!! #191,023
Good Morning!!!! 63F @ 5:00AM. Sunny to partly cloudy. High 89F. Winds S at 5 to 10 mph.
I think that's maybe why the previous owners of the new house left the washer and dryer, Kyle. And I plan to do the same when I sell. I know I've never cleaned the dryer vent line since I moved here some fourteen years ago. And I don't plan to clean it before the house goes on the market. But I should probably clean the one at the new house since most of the other maintenance items there were left undone for what appears to be a long time.
Took the string trimmer up to the mail box and cut down all the grass growing in the gravel. Then tried it on the loop road but the thistles had grown head high and the stalks were too tough for the string. I thought about going after them with the bush hog, but it's a road and really needs to be clean down to the dirt. Besides, the box blade was already on the tractor, so that's what I used. Took about three laps to get it cleaned up, and the first one was r-e-a-l-l-y slow because I couldn't tell what was road and what was weed. To one side was a steep bank and a long drop, another steep bank on the other side going up. So I stuck to the up side on that first lap and gradually worked toward the drop off to widen things up. Today I'll follow up with a good dose of RM43 to keep the weeds from coming back. Hope never to have to do that job again.
Got the remaining five buckets of bullet alloy loaded in the van, then moved the van closer to the office trailer so I can load all the junk from under it. Then got the sprayer mounted on the Kubota side-by-side. I was supposed to grease the wheel bearings on the little trailer, but forgot. Instead I just called it a day. BBQed chicken breasts for dinner and managed not to burn them too badly for a change.
Hope everyone's week gets off to a perfect start!
   / Good morning!!!! #191,025
Flowers are coming out
   / Good morning!!!! #191,027
L5030 is 50HP, 44 PTO HP. Not sure this would work on 3-4 ft high grass and weeds, that gets mowed once a year. Would love to have 90 " cut. Think an 8 ft dual spindle rotary is too much.
Bush hog 2107 is 7 ft with dual spindle, think that might do the trick.
bush hog 2208 is right at 45 PTO HP for 8 ft mower (3pt). pull type goes down to 30 HP.
   / Good morning!!!! #191,030
Those POE camera's are pretty easy to get going, hard part is running the cable.
Do you need foundation drain with stem wall? Radon system?
The issue with the cheap Amcrest camera was that it wanted to use their software, and there wasn’t an included utility to set it to a fixed IP or select the port used for video. It worked instantly out of the box using their soft ware. The detective work was required in getting it to play with Blue Iris.
No foundation drains, the finished floor will be well above grade, the vapor barrier and heat-crete insulation panels for the radiant floor heat will provide a more than adequate radon barrier.
Corn Grinder (A57454)
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2017 International ProStar Truck, VIN # 3HSDJAPR4HN677698 (A57453)
2017 International...
2009 Kubota RTV1140 (A57148)
2009 Kubota...
2017 Mitsubishi Mirage G4 Sedan (A56859)
2017 Mitsubishi...
LMC 2-Row Planter BYJ-2F  Stainless Steel Fertilizer Boxes, Ground-Driven (A56436)
LMC 2-Row Planter...
