Good morning!!!!
/ Good morning!!!! #62,881
Good Morning!!!! 62F @ 5:45AM. 0% Precip. / 0.00 in. Sunny. High 76F. Winds ENE at 15 to 25 mph.
Winds are howling outside this morning; lots of crashing and banging going on with stuff on the back porch. Red Flag fire warnings up until this evening.
First Vegas, now Tom Petty. Another Wilbury crosses over. When it rains, it pours...:frown:
Got the right side pushrod tube seals replaced yesterday, and the left side apart and cleaned. Found a through hole in one head for the valve cover stud cracked. Smoothed it up and applied epoxy to seal it, hopefully it won't require a weld repair to stop the leak.
/ Good morning!!!! #62,882
...now Tom Petty. Another Wilbury crosses over. When it rains, it pours...:frown:
Doubt if too many folks remember (or even heard of) The Traveling Wilburys...
/ Good morning!!!! #62,883
Ron, what kind of things can you use that metal lathe for?
I bet you took mechanical drawing in high school and were hooked...?
Do you use a digital micrometer a lot with that?.
I did take drawing plus wood and metal shop. I am a toolmaker by trade. But spent most of my working years doing infield troubleshooting all aspects of the machines the company built.
Can turn just about anything that is round. When I first bought the lathe I did custom threading for rifle barrels to firing mechanisms. Later was racing go karts. Made custom parts for the clutches and axels.
Still make parts for tractor and other equipment.
I also have a Bridgeport milling machine. Let’s me make just about anything that will fit in the machines. The are not big machines and take longer to get job done. But I can do it myself.
I do not have a digital micrometer. I am old school. I do need a magnifying glass to read verniers now.
/ Good morning!!!! #62,884
64° and cloudy this morning, going up to 82° today. Chances of scattered showers expected through Saturday. I hope they are more than just scattered, as we really could use some rain here. The ground is like asphalt.
Hard to imagine anyone didn't know about The Traveling Wilburys, Roy. Talk about a super group.
When it's still this fresh on everyone's minds, it's often hard for people to see a perspective like that, Eric. Emotion will most times cloud that logic. 50+ dead is a big number. Unfortunately, that happens about every 3 months here in St. Louis, with a murder about every other day. Very few seem anywhere near as appalled about that. Most of it is black kids killing other black kids in poverty-stricken inner city neighborhoods. I don't understand why that's any more acceptable than what happened in Vegas. We seem to have a serious problem in our modern world with respect for the life of another. Fixing that will not be easy.
/ Good morning!!!! #62,885
70F and sunny @ 11:15, high today of 80F.
Heard on the weather yesterday evening that we're experiencing the driest summer on record ... worst since 1872 or something like that, ever since they started keeping records. The well is still functioning ok ... but we've been careful not to place too much demand on it at once. Guess that points to it being a recharge rate issue.
Spent most of yesterday moving wood chips (and eating dust) Have most of it done, just one pile left to go.
Have so much firewood at this point that I decided that I'm going to just burn all the smaller, odd-sized pieces and use the ashes in the compost pile ... as soon as we get some rain so I burn it safely.
Managed to get the Simplicity running again yesterday. Has a periodic problem where starter drive does not want to kick out and engage the flywheel. Shot some PB Blaster on the shaft and let it sit a couple of days and that freed it up. Good to have that back in the fleet.
Shop called last night and said the wife's car was done, so we ran out and picked it up. Noticed on the way home she has an intermittent tail light ... so I'll need to see if I can figure out what's going on there. Ended up being a different model than what they originally thought, so it took a different O2 sensor and power relay for the ECM (and there was only one relay, not two) ... so it was about $70 cheaper than what they had originally estimated ... which was a bit of welcome news.
Probably spend today finishing up moving wood chips.
/ Good morning!!!! #62,886
46 and 76 later. Dryyyyy.
RS, good to see you back here.
Got several little things crossed off the list yesterday...today may be a repeat.
Bow season opens Saturday...man is it getting harder to pull that bow each year. Acorns are falling.
Looks like our last hummingbirds are gone for the winter. Haven't seen any since 9/30.
Thanks ... good to be back.
I haven't seen any hummers here for several weeks ... I need to take down the feeder, clean it out, and put it away until next year.
/ Good morning!!!! #62,887
70°F and no rain
Brush cutter needs a bit more attention before I lend to neighbor.
PO items came in late, so I retrieve today. The USPS tracking system could use some work.
Be safe
Have a great day
/ Good morning!!!! #62,888
Hello All!
Finally broke down and bought a new laptop and got it setup enough (so far) to get here... Still got stuff to do to get back to 100%.
Be well all!
David
/ Good morning!!!! #62,889
I remember them quite well.
45-75 today. Low humidity, feels great.
Washed my house,decks and garage yesterday, that 1:8 bleach/water mix in my power sprayer does so much nicer job than the old power wash method, much quicker also.
/ Good morning!!!! #62,890
Good evening all. Been finishing up the wiring and drywall around the door in the pantry and started muding. Not good at it but it will be good enough for inside the pantry. Wife is getting moms room ready and cleaning her bathroom so I hope to finish that Wed.
Ron, About half way through my senior year I started thinking about the Navy Machine Shop School, until I found out about the math requirements. Math was my week spot so... i have been dreaming about lathes and mills ever sense. Got a 6 x 18 craftsman lathe but have not finished fixing it.
Drew Thanks about Mom, hope so too.
Have a good evening. Ed
/ Good morning!!!! #62,891
That's easy RS, you just have to mow your lawn more often than once every six months and the supply of PB Blaster will be safe. :D:dance1:
/ Good morning!!!! #62,893
wow, how did I miss these guys. What an amazing collection of talent
Particularly liked them recording in the kitchen playing drum sticks on the SubZero outside and inside shelves.
this is long, 24 minutes, but I couldn't turn it off. Cranked up the speakers and really enjoyed the music.
Music you can, mostly, understand the words to. Dylan and Roy Orbison together. Amazing.
The True History Of The Traveling Wilburys - YouTube
I bet PJ knows how to play this stuff
/ Good morning!!!! #62,894
Yes, good CL write up RNG...thanks!
Just back from town after running out of chainsaw oil. Fortunately it has all been used on wood and not wasted lubricating my clothing this year :)
While there I enquired about pure Argon shielding gas as I have bought a new welding machine that does both stick and HF start Tig. They stock it, but not in an ideal cylinder size. I'm sure I will get through plenty of gas while trying to learn TIG, so think I will take my time and look at a few more places before making a decision as it's expensive to swap suppliers later.
You're starting to get serious about that welding. Have fun. Remember, cleanliness is next to Godliness when it comes to Tig welding.
Love me some Wilburys. I can't find it, but there was a skit on SNL that all the actors did slurry speech versions of them. It was hilarious with Dylan's fill in talking with Petty's fill in.
/ Good morning!!!! #62,895
RS, how are you feeling?
Went to watch my oldest daughter's volleyball game yesterday. They were out matched. The other team's school has a long history of championship volleyball.
I left my vuvuzela at home. :)
/ Good morning!!!! #62,896
... That's easy RS, you just have to mow your lawn more often than once every six months and the supply of PB Blaster will be safe. :D:dance1:
If all you guys would send me a little rain so it would grow I just might ... :laughing:
/ Good morning!!!! #62,897
Doing better now that it's cooled off a little, thanks.
I wuz dying during that six day stretch of 90+ days though.
Cooler temps on on the way ... :thumbsup:
/ Good morning!!!! #62,898
Yah, I heard about record heat up there as high as Michigan.
/ Good morning!!!!
I just got back from Florida. It was hotter in Michigan than Florida. We had a real nice trip, went all over Fla and Georgia. I had the trip planned, then the hurricane came in, but we missed any problems. My folks are ok, they didn't have power for a couple of days, but no real damage.
Don, sorry about your dad. Sounds like a great guy.
Have a good one!
Wacker Neuson VP1550AW Vibratory Plate Compactor (A59228)
Wacker Neuson...
2002 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A59228)
2002 Bobcat 863...
2020 FREIGHTLINER M2 26FT STAKE BODY (A59905)
2020 FREIGHTLINER...
2021 CHEVROLET LCF 4500 16FT BOX TRUCK (A59905)
2021 CHEVROLET LCF...
30in Hydraulic Pallet Forks Mini Skid Steer Attachment (A59228)
30in Hydraulic...
Honda utv cart (A56859)
Honda utv cart...
