Good morning!!!!
   / Good morning!!!! #40,062
I'm not close to 65 or know what SSDI stands for.
that's because Whipper keeps you so young!
56 degrees with the temps dropping throughout the day. Forecast clear until next Monday.
I need to call a trucking company to get a load of stone delivered to firm up the area between the barn and the new shed. I used to call mostly stone with a little dirt "dirty 3/8" or whatever but there are new names now. Buppies, what should I ask for? Eventually I will probably topcoat it with topsoil and plant grass but this winter, it will be a mucky mess back there if I don't put down stone now. Need smaller stone vs larger, easier to push wheeled equipment through.
Oh JD, where are you? You can come back and say hi. We can compare your burn pile experiences with David's/MFW...who we STILL haven't heard from.
We have MIA's....where is the new groom, where is Larro?
   / Good morning!!!! #40,063
40 this morning quite breezy and high of 48 later today. Clear sailing thru weekend so far
Drew in my neck of woods I would use 21A pug mill stone. If you want something that is cleaner use 57s good for concrete and less dirt
   / Good morning!!!! #40,064
Y'all do know that jdgreen is back under a new name?
I hope you start to feel better soon and that your surgery was successful
Also think your analogy may be correct and good detective you would make
   / Good morning!!!! #40,065
thanks. This is the place that's going to be delivering it. what about that "crush and run" stone? Or the number 67? This is pretty wet and muddy right now, need some larger stone first but i don't want the construction entrance stuff for sure.
Double A Hauling, Inc Washington, NC Rock & Gravel
they don't seem to have 21A pug mill stone.
   / Good morning!!!! #40,066
It is called other names I will call quarry this morning and see if they know what it is called in your neck of the woods maybe birth crush and fun. 357s not to large may help stabilize sub grade. Number ones would be good as well but base ball size. Undercut your sub grade with tractor box blade perhaps down below surface 5in or so prior to adding stone
   / Good morning!!!! #40,067
#5 stone first then crusher run which looks to be our 21A. If you send me area square feet I can tell you how much stone at what ever depth you chose
   / Good morning!!!! #40,068
Wngsprd hope wife is feeling better mine is now sick with sore throat as is son sore throat and chest congestion
   / Good morning!!!! #40,069
Good morning all. December seems to be carrying on where November left off, with more warm and wet windy days and nights.
Still really soggy out. Making ruts feeding hay already.
I'm getting that stuck in a winter rut feeling too, particularly when lifting out round bales. Keep expecting it will dry up soon and give chance to move a few to better ground, but each time I wait until the next day, it only seems to get wetter, so no option other than to make a bit of a mess. A good hard frost would be much appreciated.
Amazing...members here create all kinds of hype regarding a stupid boat and an aquarium ...
I haven't a clue about disability rules and regulations. It did cross my mind that SS Disability could be a good name for a steam ship, but perhaps a little too flippant in the circumstances...
   / Good morning!!!! #40,070
Thanks for your concern. I hear her in the bedroom now, coughing a good bit. If her cold runs a course like mine, it will be Sunday or Monday before she is well.
Case 585E Forklift (NOT RUNNING) (A50774)
Case 585E Forklift...
BUNDLE OF USED GALVANIZED CORRUGATED METAL SHEETS (A51244)
BUNDLE OF USED...
Kinze 3500 8 Row Vac Planter (A52349)
Kinze 3500 8 Row...
2005 KUBOTA L39 BACKHOE (A51242)
2005 KUBOTA L39...
Freeland 100 gal Water Trough (A50515)
Freeland 100 gal...
2015 CATERPILLAR 745C 6X6 OFF ROAD DUMP TRUCK (A51242)
2015 CATERPILLAR...
