Good morning!!!!
/ Good morning!!!! #26,481
34F and cloudy @ 20:00
Got a little clean up done in the shop and then got some stove wood split just before I came down for dinner.
Earlier I hosed off the regular loader bucket (upcoming mods and paint touch up), snowblower, and wood chipper and then moved the wood chipper into the shop for maintenance, modifications, and general TLC:
I'm going attach a couple pieces of 4" x 6" x 48" PT lumber to the bottom of the base to raise the unit up so that the PTO shaft isn't running at an extreme angle, cut off the feed roller bar and move it to the back and make it foot-operated, add a couple of pieces of plate into the throat of the feed chute to prevent small stuff from wrapping around the feed roller rod/axle, and, if I can scare up a suitable chunk of sheet/plate, modify the side wings on feed chute so that they angle outwards. Also need to modify the top link attachment point for clearance with the quick-hitch hook.
Might even have a look at modifying the output chute so it can be rotated ... :rolleyes:
And I need to grease the unit, check belts/alignment, sharpen the blades, and set the anvil/blade clearance ...
/ Good morning!!!! #26,484
2014-11-13, 0323
28 right now...high of 43 today...
/ Good morning!!!! #26,485
28F partly cloudy mid 40's for high.
Bet one could hear mouse burp outside the air that still.
Enjoy the day all.
/ Good morning!!!! #26,486
30 degrees and heading up to tee shirt temps, nearly 45 F
Another partly sunny day
/ Good morning!!!! #26,487
41 this morning high of 47 later tomorrow high in 30s. The ground is starting to get dry
Thomas great one about mouse
Good Morning
/ Good morning!!!! #26,488
Need to get second cup of coffee poured. 28° with cloudy skies this morning. Heading to 34° with possibility of some lake affect snow in the afternoon. Off to Dentist for 6 month cleaning and checkup. Neighbor has a 100' trench that needs filling in. May wait a day to do it. Should be a little warmer with sun tomorrow.
DABSGT, nice green tractor. :D
Good Morning All.
/ Good morning!!!! #26,489
44 out now headed to 46. Today will be shop cleaning day
/ Good morning!!!! #26,490
42 cloudy and breezy headed to 47. Rain/snow chances tonight now up to 60%.
Will try to mulch leaves (finally finished falling around the house yesterday) then change oil in 4Runner before rain starts this afternoon. I still need to take the bush hog off the tractor, so maybe the rain will hold up a while.
/ Good morning!!!! #26,491
31F, mid-40's today with chance of 1-3 inches of snow after midnight.
Plan to take the shop vac over to the fire house this morning and suck up dead flies. That building has a serious problem with cluster flies and has for years now. Last week I sprayed inside so the floor is probably black (literally) with the stupid pests.
/ Good morning!!!! #26,494
Happy Day, everybody.
34* headed to 46* today. Whoooeeee. And the wind is blowing, which makes it colder. Horses are staying blanketed today. I need to get little windbreakers for the chickens. Tomorrow is going to be much warmer. 52*. Ha. Cold and rainy on Saturday. This is taking a serious bite into my cycling time.
/ Good morning!!!! #26,495
Dabsgt, is that cab also air-conditioned? That is one nice mowing machine.
Good morning! This is the coldest morning of Fall 2014 at 33˚ :eek: with a brisk 14mph north wind making the chill factor 24˚.
I will have to do water line and plant preparations as we are right on the line for a predicted hard freeze tonight.
The inside temp dipped down to 65˚ over night and the heat pump is humming now. I'm almost starting to think about looking for the perfect dead tree to start feeding the wood stove.
/ Good morning!!!! #26,496
34 here too Don. Just stoked the fireplace. My wife gives me some brownie points for a warm fire.
Have to go to a review board meeting for my 7year old daughter this am. She has a touch of autism but all in all she is very high functioning. Most of the problems stem from other kids teasing her. She makes good grades in her 1st grade class.
/ Good morning!!!! #26,497
27 this morning and headed to 35 today. Windchill is 17. Ouch. Really need to finish winterizing. But also have a decent bit of mowing left. Had a new calf yesterday. Now if the other 2 stragglers would calve I would be done this year.
/ Good morning!!!!
Morning. I am waiting on a call from the plumber to install a meter at the wife's shop. The well failed and I am required to hook up to city water. Actually it will be a improvement, the water is better, no softeners or filters needed. Just takes $$$$ to make it happen.
I had my brother and
/ Good morning!!!!
Tried to edit my earlier post, and I can edit, but no save function? I do have a new laptop, running the IE8?
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
1667 (A57192)
1667 (A57192)
2008 FORD F-550XL SUPER DUTY INSULATED BUCKET TRK (A60430)
2008 FORD F-550XL...
404 (A52706)
404 (A52706)
2016 Freightliner M2 106 Ambulance (A59230)
2016 Freightliner...
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
