Good morning!!!!
   / Good morning!!!! #176,661
90/99 overcast and grey
118V showing at outlet, grid must be getting quite a workout
Don, have you checked your voltage?
I have several of these little readouts in the house, one in garage
lot easier than sticking a VMM in the hole...
Thanks for the link Drew, ordered one. Do you ever get 120v?
108˚ at the beginning of the witching hours (5-9PM) Grid is holding.
   / Good morning!!!! #176,662
   / Good morning!!!! #176,663
Don, normal is 120 or 121
except on a number of outlets when either an electric heater or major kitchen appliance
is turned on. Then voltage drops to 118. Old house and wires...
Highest I've seen is 122
Lowest is 113
Anything below 116 gets my attention, increased amp draw is never good
At 113, I think I'd start turning things off....or....turn on the generator.
Mine puts out 118 under full load
nice having this little readout right next to my desk
even better would be to have one with an alarm at a settable point
Don, I think 108 is not good for your hvac compressor.
anyone else have thoughts? (although maybe it's running on 240...that reading would be interesting)
   / Good morning!!!! #176,665
Don,
you might experiment by turning off any high consumers, like your a/c, for just a little
and then recheck the voltage
but your place is new with fully to code wiring, mine is not.
I did see Romex in the basement, don't think that goes bad quickly.
I can see voltage sucking down under load a little.
some things like electric heaters seem pretty unaffected by voltage.
I thought low voltage was death on certain compressors.
Most electronics are pretty lenient and allow a wide range of input voltage,
but again pays to be safe
are there any things we normally own that should get turned off before
a low voltage situation continues?
we all have houses and we all have wiring and appliances and we all need power
so this affects all of us
Chris, good point, never thought about my big APC UPS, but don't know what the low voltage threshold on that is.
that might be worth looking up
back down to 118 right now, so clearly lot of voltage swings here.
   / Good morning!!!! #176,668
77F dark clouds rolling in good chance couple t storms...high for today 93.4F :(
Another keeping low and cool day...grocery shopping done for the Mrs.,critter food stop, octan for pickup down 14 cent drop $3.58,basement good old fashion sweeping.
Not much plan for the evening,share bowl ice cream watch some Chiefs and Lions game.
Enjoy your day all.
   / Good morning!!!! #176,670
Got Deco mesh system installed. Not too bad, but still can’t connect one thermostat and the weather station.
It did default to an IP that I had to change. Actually it says weather station is connected, but it’s not updating info.
Other thermostat took many tries for it to work, but I’ve messed with upstairs for over an hour with no luck.
Will have to see how it works long term. Put the Starlink router in bypass, so don’t really need the new one they are sending, but I’ll swap them. If something fails on deco, that will be the backup.
Got wind, thunder, but NO RAIN!!
   / Good morning!!!! #176,671
Well, the guessers are saying Monday the temps will drop to "normal"...... seems the normals are getter hotter for longer periods. Hope they are correct, I'm tired of the heat!
If a greenie news agency tries to put a spin on it, never trust that news source.
Good Evening Guys,
LS, I am with you on that note ! Definitely ready for some cooler fall weather !
TxDon, no truer words were ever spoken !
Have a nice evening TBNers !
   / Good morning!!!! #176,672
   / Good morning!!!! #176,674
Good (Friday) morning. Overnight Low of 8.5C and it's presently 17.7C, clear with increasing wind. There was 1.7mm in the gauge @ 0900.
Gorgeous day yesterday with a High (@ Wagtail Park) of 25C. I decided to nip into town for a quick visit to the Newsagency... then I swung by the local shoe shop to get a set of boot laces as one of my existing laces is starting to fray. Basically a 'stitch in time'/'have a spare standing by' sort of thing. Whilst there I also bought some new shoe/boot polish.
Once home I then decided to actually polish my R.M.Williams boots, followed by a dubbin treatment for my work-boots.
Today I'll probably make another quick run into town to the hardware shop and pick up a 30m length of water hose to replace an old section of the horse trough system. Preventive maintenance, but the pump seems to be 'working' more than usual so there may be a leak in that old section.
   / Good morning!!!! #176,675
Buckeye, that made me check mine and now voltage has gone up to 122 on that and 123 on wall.
I wonder what PECO does to accomplish that.
Don, I'd like to give you some rain and some voltage...
after looking at the UPS pic, decided about time to peel off the plastic cover, which I did
   / Good morning!!!! #176,677
Yikes I keep violating the forces of nature. 90˚F and in 10 minutes we will be out of the conserve electricity time zone. To save electrical energy I cooked dinner on the gas stove. I think that was a bad thing because gas stoves will soon be outlawed because they are bad for the climate. Next I mowed with my battery lawnmower (which was good for the climate) but then without thinking I put the battery in the charger during the conserve electricity time, can't win for lose, hope someone bails me out of climate change jail.
   / Good morning!!!! #176,678
Interesting item on power usage this year Country is down on gas usage and power we are being lead down a bad road. Follow the money gents
.25 in of rain under servere thunder storm warning now
   / Good morning!!!! #176,679
7 days Don your troubles begin to disappear cooler wet weather. Gulf begins to open up with moisture, LS 11 days for you look west to California and Pacific. ElNino begins to throw moisture your way. Who do we thank Lee in Atlantic Ocean ElNino in Pacific breaks the pattern fall coming gentlemen
   / Good morning!!!! #176,680
Good evening all. 73ºF for the start, partly cloudy sky, light breeze. Light wind, partly cloudy sky, and high temp was 105ºF, HI 108ºF. Friday last hot day in 10 day, rain starting Monday night :). Had to track down beeping to start this morning, Was convinced it was UPS unit, was bad smoke alarm in office I had forgotten about, 1.5 hours down the drain. Chat system for APC had issues and made things worse :(. Got bike ride in, SIL checked out Volagi, broken cable on rear derailleur, trip to Sherman tomorrow to get it fixed. Did get nap in.
Dennis congrats on site success.
Kyle the Husky looked up again. Waiting for cooler weather to work on it. The garage sale special runs ok but has a surging issue. Thanks for asking.
NHBX I understand about waiting for cooler weather. Hope you get mowing done before winter hits.
Ron glad dentist not too bad. I have needed to redo most of my 20-30 yo fillings. That is one big bird :)
Buppies glad heat is over for year. prayers sent.
Don where do you get the power alerts from? Hope you got enough watering done.
Billy glad you got the spraying done.
Drew hope you get the forecasted rain. Hope the fiber install goes smoothly. When was changed from coax to fiber, Internet was done only 5-10 minutes, computer was plugged in directly for initial testing then router brought back up. Hope chair assembles easy enough.
Mike sorry about drought, hope you cool off with storm front.
Kilroy sorry about shop not catching back brake may be iffy as well. Hope woodlot time was better.
Drew problem with wind turbines is no wind, no power. Wind slows down here in summer and winter, when you need it most. Grid issue is more conventional power plants.
Thomas hope dump run went well. Hope you stayed cool. Nice Boo pic. Does it mean anything when Boo walks like that.
Dennis sorry about the over active pic taking.
Mike well said.
James glad your hot days are over. Basement turned out great. Hope you can get the little details done soon. Thanks for pics
Ken hope no excitement at day job. Hope mini-split work went well.
Don well said.
Paul that was polite way of saying make work. Hope you are done with TSA/FAA for a while after this. Smoker looks yummy.
Drew cool map.
Don the climate is going to change. If CO2 management was critical to humankind, they would be working on China, and they are not.
Ted hope you get a cool off. Hope you made good progress on prep work for addition.
Gstrom glad you got a cool off. sorry about minimal rain. Shop looking good.
Chris on paper we have energy choice in Texas. I not sure hoe much choice there is, beyond who sends you the bill.
RNG loved your soapbox. Glad trip to new house went well. Dinner sounded nice and hot does help the kinks.
Scott(vt) glad you have pool to cool off in. 94ºF for a high would be much better here to :).
David good to hear Sophie's eyes are doing well. Hope BX finished up and mowing today. Sorry about H&F loss.
RS sorry about minimal rain yesterday. Hope you can finish the strawberry work soon. Good to hear monofilament line working.
Ted I hear you on the heat, bet Don and Kyle are as well! Hope the dismantling goes well and materials can be reused.
Dennis sorry about friend's mom, my condolences. Hope mesh sets up in straight forward manner.
Frits sorry about the intensity of storms while you were out in them, glad you got home ok. Politics have changed power choices, and not sure for the better.
Drew glad fiber install very ho-hum.
Frits Union Electric was fighting in Missouri for rate increases to work on capacity issues. That was years ago.
Dennis glad mesh install not a lot of curves. Hope you can get the last few devices working. Sorry about no rain.
Mike sorry about no rain.
Randy(wag) glad you had nice weather. Polishing footwear sounds like work.
Don don't want to charge it over night could overheat and burn house down.
Buppies yes bad road.
Buppies good to hear fall coming, want to fish and play golf :)
prayer for all, especially Jay/Peg, Kyle /Daughter, /mom's breathing, /friends upcoming new baby, /son's migraines, Bird /aging issues, Ron /heart, Billy /mom hypertension & congestive heart failure, David(moss) /remodel, /divorce, Buppies /sleeping, /wife healing, Thomas /gout, Phil /reflux, Frits /veteran son with mental issues, /granddaughter with Evans Syndrome, Ken /dad possible dementia, Steppenwolfe /son-auto immune disorder, Grev /wife's eye, Ted /knee recovery, /retirement & disability red tape, /family issues, Lou /eye issues, /heart issues, Doug and wife/health issues, / hand nerve and surgery, /fall and recovery, / wife headaches and heart eval, / David(sadamo)/Sophie's hip or leg pain, Scaredy/shoulder dislocation, /marriage dissolving, / friend stop drinking, Dennis /retirement, /neighbor issues, /land development, /favorable winds not in the forecast there "alligallyitus" and back in hospital, Drew /back operation issues, /friend's wife cancer diagnosis and recovery, mike /wife's healing from surgery, Scotty /back pain, Helogabals /second opinion, /wife's friend situation, Fatjay /father broken hip, Ukraine war, and Country.
1980 Gleaner F2 with heads (A56438)
1980 Gleaner F2...
2021 Takeuchi TL10V2-2 Track Loader with 76in Tooth Bucket (A56438)
2021 Takeuchi...
2020 Westfield MKX 100-83 Auger with Swing Hopper (A56438)
2020 Westfield MKX...
Sakai SW354 (A60462)
2013 Ford C-Max Energi Hybrid PHEV Hatchback (A59231)
2013 Ford C-Max...
UNUSED FUTURE WALK BEHIND POWER TROWELL (A52706)
UNUSED FUTURE WALK...
