Good morning!!!!
   / Good morning!!!! #176,142
Morning all, 72 going to 83 and raining.
Got a few of the little side lawns mowed yesterday before the rain started.
so one quote yesterday to replace oil burner told me $20,000 - $25,000 !!!
Anyone can tell me what a 180-200K btu oil burner install cost you as this seems like nice used car money.
Waiting for 2 more quotes. So much for saving for my sons college.
Got a nice large bowl of figs from the tree yesterday, seems they are finally ripening, all at once.
Be well,
   / Good morning!!!! #176,143
That is a lot money for furnace replacement for sure. How much will the furnace cost without installation?
I replaced a Yukon furnace of similar size multi fuel type furnace.
   / Good morning!!!! #176,145
Good Mirning Guys,
61 with rain going to 75 !
Ken, the top of the line oil burner with all the bells and whistles should be between 15-18K tops with instillation included ! I still drive part time for an oil company and just asked the owner of our company , that is the answer he gave me !
All have a blessed and safe day ! 🙏
   / Good morning!!!! #176,146
   / Good morning!!!! #176,147
It's currently a Tarm 50Mcal (about 200K BTU) Heat and domestic water Oil boiler.
It is also connected to my solar hot water storage tank.
The Tarm is huge and has an oil burner and has wood/coal capability on one side.
It is quite a system and I will be sorry to see it go, but it has rust around the top of the boiler and who knows how much it is rusted inside.
   / Good morning!!!! #176,148
Our furnace had overheated and the flue side was leaking flue gas into the forced air section. I bought the same model furnace for about 5000 bucks and replaced it myself. It was not that difficult because all interfaces were the same. It was heavy and handling it in and out was a challenge for sure. A boiler system is more complicated for sure
   / Good morning!!!! #176,149
Waiting for Subaru to get worked on, hopefully it is just a simple rotor replacement and not a major job.
that reminds me, my Subaru still have original brake pads at 158k miles.
I bought new pads a couple years ago, but didn’t need them yet when I checked. Guess it’s getting close now.
   / Good morning!!!! #176,150
   / Good morning!!!! #176,151
Around $5k today for a replacement boiler. Shouldn’t have to mess with too much to change out, oil only will be smaller. Will have to adapt to the old in and out pipes, exhaust and the fuel line in.
I have an old one sitting in my basement. I replaced it with geothermal, still need to remove the boiler taking up space. On my list of rainy day projects, and fortunately the sun came out today.
77°, we got .26” rain around 4-5 am. Woke me up. Once I got back to sleep I slept pretty good till 9:30. 😂
   / Good morning!!!! #176,152
Good Morning!!!! 79F @ 6:45AM. Sunny. High 99F. Winds WNW at 5 to 10 mph.
Yesterday's Fire Weather Watch has escalated into a Red Flag Warning, but still for areas west of here. Northerly winds and low humidity, the usual recipe. Those same winds have funneled in the smoke from the lightning fires north of here, giving the sunrise an orangeish pink glow this morning.
...Is there a term right below drizzle but above fog?
Mist?
Got the eight mounting holes for the tie down anchor plate in the van drilled yesterday, and rivnuts installed in four of them. The other four holes ended up over some kind of steel support piece, about 8.5mm behind the holes, too close to let the M8 rivnut seat in all the way. Looks to me like a barrier put in place to protect the fuel tank. Sure don't want to drill through that barrier and into a plastic gas tank, so I'm wondering if there's some kind of toggle bolt or expanding anchor I could use instead. The drilled holes are a little over 12mm in diameter, and they're through 1.5mm thick sheet metal.
Deliveries came in all day yesterday from US Mail, FedEx, and UPS, and even an OnTrack driver all the way from Sacramento with tires for the new trailer. The rest of the stuff is mostly for the new house. Need to get moving this morning before it gets too hot to work in the garage.
Happy Hump Day, folks!
   / Good morning!!!! #176,153
Ever heard of base jumping? Fell down a Facebook Reels rabbit hole just now and came up with this guy. If you're on FB, check out this link:
He catapults himself off a cliff and somehow gets video of the ride. Mind blowing!
Otherwise, here's a YouTube short of him skydiving in a pretty unconventional way:
   / Good morning!!!! #176,155
RNG, a pic of your tie down would be helpful, curious how you design it, thinking about my little motorhome on travels across tornado alley.
   / Good morning!!!! #176,157
Check out Wingsuits. Most fascinating.
   / Good morning!!!! #176,158
Here's a photo of the two types of anchors that RAM uses in the van. both use nut plates welded to underneath the sheetmetal for anchors.
I'm trying to mount a pair of the larger ones where I don't have access to the back side of the hole, so I'm trying to distribute the load over more holes using a steel plate on the outside of the sheet metal bulkhead. I'll try go post some photos of what I've got later today, OK?
   / Good morning!!!! #176,159
The sprinter tie downs look like this in the passenger version
There are about 10 of them
John Deere 7410 (A53317)
John Deere 7410...
2008 Ford F-250 Lariat 4X4 - 303,424 miles - 6.4L Powerstroke -Automatic (A61306)
2008 Ford F-250...
2022 John Deere 1025R (A53317)
2022 John Deere...
UNKNOWN  20 FLATBED GOOSENECK (A58214)
UNKNOWN 20...
2019 CATERPILLAR 326FL EXCAVATOR (A60429)
2019 CATERPILLAR...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
