buckeyefarmer
Epic Contributor
Mostly, that is WiFi printer that is dropping out.
You can also look at the magnetic or if aluminum gear case the glue on heatersIt is going down to -24°F tonight and a high to -9F tomorrow. I will plow the 6" we got after I get the tractor back tomorrow. It is all fixed up for now. In the spring it will go back up there for a full service all oils, all filters (fuel too) and valve adjustment.
I think I am going to acquire a dipstick heater for the hydraulic oil, IF I can find one that is small enough to go through the dipstick hole and long enough to actually get into the oil without bottoming out. Amazon has a couple of them, but I need to measure the dipstick I have first.
.... I headed to the mountains. Wasn't sure I was going until the last minute, so did an out and back, rather than asking for a shuttle...big mistake. I bit off more than I could chew and hiked the last hour in the dark through some steep rocky sections.
Can you give the printer a fixed IP rather than using DHCP? I have found that with many things that makes them more stable. Do the devices that print to it connect directly to the printer or though your network and router? That can cause issues sometime as well.
First time I hiked the AT in West Virginia.View attachment 782096
Also look into “static” hydroponics, without pumps…67°F and no rain.
Could be interesting day ahead. Need to get back on the laundry remodel. Neighbor has given me his aquaponic setup he quit using a few years ago. 4 tanks, a bunch of pvc piping, a pump, and I don’t know what. Some disassembly required. Whether this will take a hour or several I don’t know. Hoping this can be the start of my own hydroponics I set aside last year due to price of pvc.
Prayers for all
Be safe
Have a great day
That’s not for hikes - it’s for canoe trips. . .Was there banjo music?
