Good morning!!!!
   / Good morning!!!! #151,381
Rigged the chipper, but the adjustable top link threads were frozen, so I couldn't get the QH upper hook engaged...bummer!! I used a helper (12" crescent wrench)...wouldn't budge. Soaked the threads with PB blaster and we'll try tomorrow (24 hour soak)"
Also happen to me couple time good heavy spraying of brake cleaner in short time free up.
"So, change of plans...mowed the lawn instead
Beautiful day..
Glad your getting outside enjoy yourself Roy, yup tad jealous here tho. ;)
I know what you're going through...my first pacemaker was 2009...replaced in 2016...
You'll be your old self within a week or two
   / Good morning!!!! #151,382
73F mostly cloudy nice breeze.
Decided give Ms. Kubota little exercise several buckets of dirt fill small holes here and there...not smart move on my part :rolleyes:,after lunch before putting Kubota under cover need good hosing from the heavy pollen in air :eek: gotter admit where wind blew pollen on hood rims etc. collected gave nice pin striping looks...John Deere pollen green. ;)
Plans..Mrs. like to stop at HD purchase handy size wax buffer for car,sooo I guess I'll tag along and bat my Bambi blues eyes she buy bucket KFC chicken 🤞 other than that on the deck smooth cigar waiting for mother gray fox couple deer and baby Boo come to visit.
Enjoy your evening all.
   / Good morning!!!! #151,383
Did my first regen of the tier 4 engine in the 4052R today. Soot percent was 79% and, I'd noticed the last day or two, once started, the RPM would not drop to idle (1100 RPM). My habit (for this tractor and and all previous tractors) is to increase RPM to 1500, once oil pressure was up.
I always dropped RPM to idle before shutting down...but as I'd written...it stayed at 1500
Anyway, I did notice the regen light was on (I had mistaken the indicator light for another function, previously)...cranked the RPM up to 2200 and went about my business.
Took 20 minutes or so (don't wear a watch, so that's an estimate) and the soot percentage went from 79% to 6%
A completely simple process, although I would think it's a bit more of a hassle for farmers and other "professional" tractor users.
My tractor has a vertical stack for regen...and I'd seen on YouTube the exhaust gets hot during regen...and I can attest, yes it does!!!
   / Good morning!!!! #151,384
Sky starting to clear, looks like sun might come out.
68° and only 68% humidity now. Only got .05” rain.
I stopped shed work at 3, came in for lunch and a shower. Did not get rotten piece of floor replaced, but did get the back left corner cleaned out, had raccoon crap. 2 bags stuff ready for trash pickup.
Burned a bunch of old osb siding, posts, scrap wood, cardboard. Had to stop piling more on fire when wind decided to kick up a little.
Moved old rain barrels to side of barn. Need to get rid of them.
Overall satisfied with amount of work I got done.
   / Good morning!!!! #151,385
My model plane experience was similar to RNG. As I recall, Cox gas engine as well. Saved up and bought a balsa wood kit that I enjoyed building. Not an RC type, but the kind at the end of some strings, 2 I think. Nice take off and almost immediate power dive into the ground. Did spend some time trying to fix. I remember buying different pieces of balsa, but it never flew again. Decided to use my meager resources elsewhere. Anyone catch a finger flipping the prop?
I almost lost a finger about 40 years ago when a glow plug igniter was stuck on the plug. It suddenly let go and my little finger went straight into the prop at full revs. About 30 stitches from memory.
Still have the scars to remind me.
   / Good morning!!!! #151,386
Absolutely !!
Most of the larger engines I spin up with an electric motor with a rubber cup on the spinner. Of course the battery to run that and fuel transfer pump is long dead like all the others.
   / Good morning!!!! #151,387
Heat works wonders freeing things up. A torch and Kroil are my go to tools for tasks like that. Soak it then heat it.
   / Good morning!!!! #151,389
Good Morning.
It’s 68, overcast and likely to rain soon.
With that in mind, I got going early this morning, got the mowing finished up that I started yesterday and got the rebuilt mailbox installed.
Yesterday’s trip to Concord was effortless, beautiful day, good views of Manhattan. We could see the Atlantic Ocean as soon as we took off. And the best part was that we were back by 10am and heading home.
I had the post hole auger on the loader, so I had to take that off, and rig up a 4 wheel dolly to store it, because I need a bucket on the loader to remove it from the tractor. Got all that done, and hitched up the Progressive mower and got everything cut with that. Parked it, refueled the tractor, and hopped on the Lazer until I got hungry. After a quick dinner I did the final assembly and graphics on the mailbox before putting my feet up.
Good flight!!!
Is your post hole auger hydraulic? Just curious...I have no need for one, but other than one rigged to a skidsteer, I've never seen one rigged to the FEL/bucket
   / Good morning!!!! #151,390
Good Morning all
I'm taking a day or two to load up my truck (with canopy) for a dump run ... exciting times :) Next week I'll add the new to me grille guard for the truck. New All Terrain tires, used rims are pending. It's raining, so too wet to do any yard maintenance, the brush cutter / weed whipper will have to wait for a dryer time. I put a deposit down on the Zero Turn while I wait for the fabricating to be done. Bit of a slow day, giving my knee some T3s and a rest - had the El Camino out last night, so the knee is a bit strained from getting in / out. Having a coffee, and checking emails, so I thought I'd respond to a few things here... (credit to MostlyGas for the idea). I'm skimming over the past 15 pages, so I will certainly miss a lot ... I really should be washing more eggs also, and checking the incubator.
Alien, LS, Popgadget, and others - I like the RC planes a lot (great photos) - friends, and my neighbour, were big into the planes. My hobby was always the Model Railroading, still with the local club, but my trains are in boxes yet again, while I find some new space to run them. The church is having a Trains theme for the week long Kids Day Camp
Buckeye - we had a mudslide here last week due to the rain, closed the hwy for 5 hrs
rswyan - I like gardening, but mostly from a greenhouse table height at this point. need to get a greenhouse yet
I'm joining in on the prayer concerns, it's tough to keep up sometimes, so that was a great summary for me. Strength everyone. Buppies - all the best with the surgery, today or soon.
Popgadget - love the mailbox, can't miss that one
wngsprd - reminded my wife to have the wheels re-torqued, i've seen too many roll aways
RedNeckGeek -here in BC it is $2.19 per litre for gas (over $8 per US gal) - uggh, but some travelling is needed
sodamo - my trips to town (20 min away) are less frequent, and loaded with errands, makes for long days
LS- I need to respond to the son (3rd child) comment :) I too have a BS in Psychology / Criminal Justice (not science), I had a good 26.5 yr career in Corrections ... Probation, Parole, Bail Supervision etc - hopefully he'll figure it out sooner.
Kyle - I REMEMBER that song, always made me laugh
newbury - take care
txdon - I recall fire and earthquake drills, no bomb drills
RoyJackson - sounds like a similar weekend over here, clean up and dump run
daugen - and I was just going to guess garlic scapes (haha, ya sure I was - nope) - had 2 boxes of them a few weeks ago, initially thought they were string beans - they were old, so the chickens enjoyed them
I think I caught up - PHEW !!! :) going outside with the dogs
   / Good morning!!!! #151,391
Well, so much for the high of 98°..... 102° as I type this.... just stifling when you open the door!
Drip irrigation done for all zones. I swear I heard the plants all sigh .....
Not leaving the cool sanctuary of inside now.
Doug, nice flight! I only have 2 'wings', a Pico jet and a "Blitz" wing. The Pico jet is only 30" and only weighs 1lb 11oz (.79kg) and I'm running a Jeti Phasor 30-3. It has been radar clocked at 96 mph. It will go vertical until out of sight. Fun to fly, but you better be paying attention!
I have yet to fly the Blitz. It's about the same size as yours. I don't know why I was afraid to fly it before when I really had the skill.
The newest version has twin tail booms now.... apparently to help stabilize the flight characteristics. I might have to add them. Maybe that's what I was afraid of?
   / Good morning!!!! #151,392
A couple of hours on Sophie’s BX, I’m impressed.
This is how I started, the swarth on right from flail yesterday.
Notice the 4 ft guinea grass
A bit of progress
Not a lawn, but good enough for a field
I’ll hit the next section before heading for town.
This isn’t a replacement for my flail, but would be nice in less challenging circumstances.
The guinea grass was a challenge but taking half bites worked. And I’m too lazy to do another pass.
   / Good morning!!!! #151,393
Ouch
   / Good morning!!!! #151,394
This is me test flying my old buddys FX 79 Buffalo. He later crashed it and gave it to me so I rebuilt it and flew it for quite a while eventually passing it on to another buddy. It is a very large wing. 79"
I still have a Bonsai as well. Here I am practicing low flying with my dogs watching on. They loved me flying. We only have the pug left now. The big ones passed away about 4 years ago It is great having the video of them. Not real good quality but it was late evening.
   / Good morning!!!! #151,395
Now 62° but back up to 92% humidity.
Recorded over 900° in the burn coals with my IR thermometer.
Dad said he trimmed the branch in front of my remote camera, with the FEL, took out the whole bush. Said I shouldn’t have any more problems.
When I was there 2 weeks ago I put the camera on a 12v power supply. Batteries will be backup. He had afternoon visitors.
This is the low resolution photo, I can have it send an HD one.
   / Good morning!!!! #151,397
Good evening all. 74ºF for the start mostly clear sky, light breeze. Light wind, mostly clear sky, and high temp was 99ºF, HI 110. Bike ride first thing, 65 miles, temp 95ºF HI 104ºF at finish. Drank plenty fluids rest of day, did get nap in, and grilled brat for dinner. Tomorrow hotter HI lower.
David sorry about shear bolt. nice find.
Drew hope you don't get too much rain.
Buppies know you like feeding the birds, sorry the bears are messing with it.
Drew hope you have good trip to Catskills.
Roy hope you get the chipper rigged
Thomas hope puttering was fun. nice pic
Oosik wish you could share some of the moisture.
Mike glad you got wall punched through,
Drew sorry about your ramps, no issues with my ramps (Rhino) Nice pepper.
RS plenty to do there.
Don sorry washing truck produced no rain. Yes bomb drills remembered.
Billy hope you got your rain. Sorry about losing your bears to Buppies bear buffet ;)
Mike thanks for sharing memories.
Ted hope breakfast went well. Happy birthday to GD and ex-DIL. Hope you got planters fix and irrigation run. Naps are always nice :)
Ken just what you need more rain. Got some chain lube in pedals and everything quieted sown for about 50 miles so mostly pedals. Jan did come loose on Bottom bracket.
RNG hope seat time was enjoyed, and got trees limbed. Hot afternoons good time for paperwork.
Paul great work on mailbox. Really nice collection of planes and old RC equipment. Glad flight to Concord good.
Drew do they taste like garlic?
David sorry the furry kids have to be so critical :(
Don that is hot. sorry about irrigation woes, 5 days till fix :(
Roy glad chipper is on tractor, and lawn got mowed. Good luck with frozen threads.
Thomas but you enjoyed seat time right?.
Roy glad regen uneventful.
Dennis good to hear quality day today.
Doug sorry about finger incident.
Doug thanks for video
Saredy nice post. we don't get much summer rain here so one just takes off :)
Ted sorry about the heat thanks for R/C pics
David mower working goo on that mess.
Doug enjoyed the videos!
Dennis good to hear branch not in front of camera anymore. nice pic of visitors.
prayer for all, especially Jay/Peg, Kyle's daughter/friend PT from Covid, Bird/aging issues/, Don /mom's pipeline process, Randy/FIL living alone adjustments /MIL Covid /son's heart issues, Roy /palpitations, /angina , Billy /wife fall, David(moss) /remodel, /divorce, Buppies /3 new skin cancer spots and treatment, /ultrasound of kidneys result /wife head wound healing, Thomas/gout, /operation and recovery, Phil /reflux, /wife's eyes, Steppenwolfe/son-auto immune disorder, Grev/wife's eye, Ted /knee recovery/retirement, / passing out issues, /family issues, /wife feeling bad, Doug and wife/health issues, /nerve and pain, / wife's hospital stay, /torn bicep, Ken /kids shot tragedy, David(sadamo)/Sophie's new eye surgery recovery, /cataract surgery, /Sophie's hand infection, Chris/neighbor's granddaughter and Covid issues, Scaredy/shoulder dislocation, Paul/ wife's disc issues, Gale and KY/ tornado victims, Mike /5 year plan, Dennis /retirement plans / brother "alligallyitus" and improving, Drew /foot heel issues, /friend cancer diagnosis and recovery, Helogabals /second opinion, /wife's friend situation, Ukraine war, mass shooting victims and family, and Country.
stay safe and healthy you all.
   / Good morning!!!! #151,398
thanks for the reminder mostly_gas, ... My shoulder dislocation is still on the mend, but my physio appts are going well and the physio therapist is pleased. he says the progress is good. I still notice a weakness, easy arm fatigue, and average at best grip strength (significant weakening at this point still) but it can take upwards of 12-15 months for general recovery, so we'll see how the next few months work out. the injury was Sept 2021, so by Christmas this year it will probably be at it's best. Three fingers, shoulder are still a bit numb. I thank the Lord that progress is happening. Thanks for the thoughts and prayers
sodamo - that is great fieldwork, excellent progress, thanks for sharing the photos
tonight I took our dog Minnu (an Anatolian Shepherd) for a walk on the property, we stopped at the spot where I buried Max (Golden Retriever), a little over 2 weeks ago. Minnu has been grieving for a few weeks, misses her friend, I think that Minnu knew that this was the spot, maybe that little visit will help.
   / Good morning!!!! #151,399
Good arvo. Somewhat of a mild night, temperature wise with a low of 6C... however the wind was gusty, which actually dropped the temp to -1.2C. Clear sky and the high has only reached 9C.
The wind was such that the local radio station was off-line all night. I had a 15 minute power outage prior to toddling off to bed, a couple of 'snap' outages whilst I slept and, annoyingly, 4 'snap' outages prior to heading off to Church this AM.
Everyone at Church this morning were wearing their coats, even with the heaters on. The Church never did 'heat up'.:)
   / Good morning!!!! #151,400
good morning all. Bunch of late sleepers this morning
Drizzling outside, looks like rain most of the day.
61 going to 77 with heavy rain tonight.
important day at church, as they try to find a replacement for me. No one has volunteered yet and my leadership ends
in two weeks. I've been to Meeting every Sunday morning, save one, for the last 8 months. I need a break...
late yesterday two small trees came in from Burgess, last of a very old order. Should have been here months ago. These are
cypress I think for a visual barrier, will find a place for them. The two trees I really wanted, the weeping willows, were both cancelled by Burgess.
Really is interesting seeing the different temps in different hemispheres. Wagtail is wearing his coat and we are sweating.
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A59230)
2013 International...
(2) 6 LUG WHEELS/GOODRIDE ST225/75D15 TIRES (A60432)
(2) 6 LUG...
PALLET OF (3) CABINETS (A60432)
PALLET OF (3)...
2018 New Holland C227 Compact Track Loader (A61306)
2018 New Holland...
UNUSED RAYTREE RMPP680 HYD POST POUNDER (A60432)
UNUSED RAYTREE...
Land Pride RCR1260 (A53317)
Land Pride RCR1260...
