Good morning!!!!
/ Good morning!!!! #131,381
No power last night thru this afternoon no more rain till Wednesday, tree took out lines down the road
Yes Drew very nice got over $10000 off when we got it now very hard to come by very nice 25mpg with six cylinder
prayers for all Mostly wife our Country
/ Good morning!!!! #131,382
2021-04-11, 0954
58 right now...high in the mid-60's today...
Got the EGO chainsaw's trigger functioning better, but not 100%. There was some crap in there, but the real problem is a sticking switch. The trigger pushes a spring loaded plunger and that plunger isn't always returning to the full extension which results with the sticking trigger.
The switch is hardwired, so I'll take the saw to Home Depot (an EGO repair facility) for a repair...
But, it did work well enough yesterday for trimming some branches. I used the chainsaw and the pole saw. Didn't drop any trees though...might not have to after trimming but we'll see after the leaves appear.
As I was hooking up the chipper's PTO driveshaft, I found it's a little too long...maybe an inch or so. The driveshaft fit the 4520 OK, so it appears the 4052's draft links are a little shorter. I could probably get it on, but that would be pretty risky since the distance between the tractor's stub and the chipper's stub is a little shorter as the chipper is raised. If you have a PTO driven implement, you know what I mean.
SO, I'll take the drive shaft to my local dealer to shorten it by about 2 inches. One reason I want the dealer to do the job is I want both yokes replaced as well. These yokes are the type take require me to retract them so they'll slide on the stub. I despise this type of set up...a real PITA to retract the ring while pushing the yoke on to the splines. Making things worse is I just don't have much strength in my right hand (result of the stroke many years ago...). I use more foul language when hooking the chipper up then any other implement...and as an ex-Navy guy, I sure know how to use foul language!!
If the dealer can get them, I want the old push-pin type of yokes, but I'll settle for the type the has a ring you rotate. Either would be better then what I have now.
So, a semi-successful day...
One nice thing...although it was in the mid-70's, the tractor's cab got pretty warm with all that glass. So, tried the AC and that was quite nice. Since the only implements I use during the warmer weather are the chipper and flail mower, I don't think the power drain (when using the AC) will will be too bad. Obviously, I won't need AC when chipping but will when mowing the field
My stepdaughter want to rake the flower bed out front....asked me where the rake was (in the garage, dear). After she asked, I thought the only rake in the garage was an ancient fire rake that my father had when he worked for the Maryland Dept. of Forests and Parks. Thing's got to be at least 60-70 years old. Anyway, I went to the smaller shed to grab a regular springy type rake I knew I'd put in there last fall (after raking leaves). I found another one in there left by the previous owners of our house. This one has a curved handle so one doesn't have to lean forward as much when using it...never saw one like this before, but it sure is comfortable to use
I watched "Hacksaw Ridge" last night....for those of you not aware, this is a biographical movie about Desmond Doss...the only conscientious objector to be awarded the Congressional Medal of Honor
Good flick and I'll watch it again sometime, but my favorite WW II movie is still "12 O'clock High" (made just after WW II)
As far as today, I think I'll get the zero-turn out of the garage...probably have to give the battery a charge first though...then tow the lawn roller and aerator both out of the larger shed
I guess that's enough typing today...
Hacksaw ridge was good.
/ Good morning!!!! #131,383
It was light rain when we left for service this morning, got .6” overnight. Then turned into an absolutely gorgeous sunny day for our little date out alone (anniversary dinner a week late), already posted about the great place we ate.
Then took a drive thru pine grove furnace state park, the place I got GBS almost 2 yrs ago.
One of the restored iron furnaces and 2 old timers. This is the halfway point of the Appalachian Trail.
Then drive thru the Gettysburg battlefield before coming home.
Then mowed the yard. As soon as I finished it started getting dark, storms are rolling in.
/ Good morning!!!! #131,384
Good evening. 53 and it was never much warmer today.
spent all day outside yesterday. Hauled a load of free firewood and stacked it, mowed, did assorted yard clean up. We were tired last night. Made rigatoni for dinner.
Today was first race of the season in Ohio. We had a good day. We did almost nothing to the bike, kid was loose and riding well. He won both the Open Amateur and 450 Amateur classes convincingly.
Everyone stay safe out there
/ Good morning!!!! #131,385
Good evening all. 41 F for the start, clear, light breeze. Wind 14-19 mph early afternoon, clear, and high temp was 83F. Chapel to start, Pancakes for breakfast, bike ride today, may not get to ride tomorrow. Neighbor and fellow biker car would not start, took my old Schumacher to jump it and smoke came billowing out of the Schumacher :(. Truck got him going, going to need a need starter box :(
Covid update: Cooke, Montague, Grayson unchanged, local not updated.
RS hope you wanted the rain.
Bill never seen BP that low, glad it was caught. good luck with conveyor
Eric glad they found the warm spot, nice pics
Drew that was an ugly pic.
Thomas god to hear trees popping
Paul the coyote remained me of seeing then at the VIH airport. bet you are glad manure is done. Hope recording session went well
RNG neat pic of the tree cutting, nice score on the firewood, hope you can get the tank permitted soon and have it ready to catch rainwater.
Drew hope you have some indoor to-do's
Billy sorry about the hunting luck, glad the apple blossoms smell good, I could never smell mine
Bird understand your feelings on dishwasher, ours is not as good as yours, need to setup an hot water recirculate for the dishwasher.
Roy I really liked the Hacksaw ridge movie, amazing story. Have you seen Undefeated, about the WWII POW?
Kyle thanks for the prayers.
RS Hope your day goes well
Drew nice pics good catch on the Studebaker
Dennis nice to hear you have anew place nearby to replace the old favorite.
Buppies sorry no power, thanks for prayers
Dennis is that a cold blast furnace?
Rich good day racing, nice score on firewood
prayers for all, especially Jay/Peg, Kyle's daughter/sister & family Covid/friend's grand baby/son&wife Covid, David(moss)/remodel/divorce, Ron/hearing/son/aunt, Phil/reflux/wife's eyes, Dennis/older brother/son, Grev/wife's eye, Randy/family, Bill/DIL cancer, Ted/knee recovery, Doug and wife/health issues/nerve and pain/ wife's eyes, Ken/uncle and low blood O2, Drew/tendon, and Country.
stay safe and healthy you all.
/ Good morning!!!! #131,386
Sounds like a great time BEF
/ Good morning!!!! #131,387
Very tired. Trying to get caught up here.
have to get up at 5:15am.
Prayers for our team, especially Mostly's wife.
/ Good morning!!!! #131,388
2021-04-12, 0252
44° right now...high now, high in the mid-50's today...
Mostly_gas, no, I haven't seen "Undeafeated". Couldn't find a synopsis online...when was it made?
/ Good morning!!!! #131,389
49 high of 72 today pollen getting bad
Prayers for Mostly wife, our Country
prayers for all
/ Good morning!!!! #131,390
Good morning, apart from the cool temperature this is about as good as it gets for spring- little wind, no rain expected just patches of light fluffy cloud and birds singing away. First swallow of the year has arrived.
The hydrostatic transmission has a mode called Auto Throttle, which lets you operate it pretty much like a car. Push the go pedal down and it moves, push harder and it goes faster. As I tried to pick up the first trunk yesterday, the tractor wouldn't move, and the RPMs wouldn't rise above idle.
RNG, my Iseki has a similar "auto throttle" function (it is always operative - no off switch). It works well, however the user manual warms that if using other hydraulic functions such as the loader, then set a minimum of 1500 rpm with the handle throttle. Could it be something similar on yours ?
/ Good morning!!!! #131,391
good morning all.
Damp cool day, showers have stopped but likely some later, 1.1 inches of rain so far.
not much planned for today
Toppop, sounds like a wise decision
/ Good morning!!!! #131,392
63 degrees this morning, going for 83 with a 10% chance of rain late in the day and a 20 to 50% chance of rain every day this week, We really do need the rain, and my yard needs mowing, so I reckon that's what I'd better get to doing as soon as it's daylight.
/ Good morning!!!! #131,393
44F mostly cloudy day low 50's for high chance showers on/off into evening.
Plans for today...wash the other half outside of our house,wash pickup,and putter.
Enjoy the day all.
/ Good morning!!!! #131,394
One of the "poor" cars my mom bought when I was young, was a used Studebaker Lark. I was young, but I believe it had a straight 6, 3 on the column and overdrive. No A/C.
Mostly, hope your wife's condition can be treated for the better. Prayers.
Hope Ron is OK.
I got the kawasaki mule done for my wifey's uncle. Rebuilt both front CV joints, troubleshot the fuel pump, changed oil. Charged him 9 hours @ 30/hr. He was glad to get it back. Most mechanic work is taxing on the body, if you're not in the best of shape.
Steiner Beast: changed the long v belt on the 72" deck. Belt size: A180. So now all the belts in the system are replaced. I had to take off some brackets to change it out. If you remember, I brought it back from near our salty coast. The deck has some rust spots. I just treated them with rustoleum rusty metal primer for now. Hope the fish oil slows the rust. I saw on FB, where a guy in my old hometown has a similar Toro mower for sale....$3500
I bought the belt for much less than a dealer. Dealer price about $45, V belt guys online price $7.99 plus 6.99 shipping. I ordered a belt for the Speedaire too, to defray shipping costs. If you need belts, I recommend the Vbeltguys V-Belt Guys Search - Replacement Belts, Quick & Easy
There is a pressure washer recall, mostly sold at Lowes. Turns out the green units, and some red, have plastic parts in the high pressure end that are exploding. One Million Greenworks and Powerworks Pressure Washer Spray Guns Recalled Due to Impact Injury Hazard; Distributed by Hongkong Sun Rise Trading
It might be the wand where the hose attaches???
Our area is dry.
I let my daughter's boyfriend do some shredding on my 4310. He went slow. Nothing broken. Whew.
We had beautiful weather for the weekend, but we desperately need rain. We are in exceptional drought condition IIRC.
prayers for our team, and for America.
/ Good morning!!!! #131,395
Good Morning
It’s 44 with a high of 50 forecast. Cloudy with intermittent rain
Got just over an inch of rain yesterday and overnight.
Yesterday I didn’t accomplish much other than to go play music for a recording session. That went pretty well, I didn’t know any of the other musicians other than the piano player, but they were all excellent players.
Today I’ve got to get back into the shop, another speaker order rolled in over the weekend, and I’m still finishing up the last one from the previous round. However the weather won’t try to lure me outside today.
/ Good morning!!!! #131,396
Good morning, the temperature is 51 and going to a high of 64°F. Wind E 13 gusting to 20 mph. 40% chance of showers.
Wow, did it ever rain yesterday evening. The rain on the tin roof was really loud. Scared the cats and they all were in the basement.
I got nothing done yesterday except for putting the box trailer under the window so when the time comes to clear out this place, most of the stuff that is dump bound can go straight into the trailer.
Of the two kittens I acquired in December, there is only one left. The gray one got out and left. His brother has been wandering around all day yesterday and this morning 'calling' for him. They were really close and slept together most of the time. He has either gotten 'got' by a predator or he got himself lost.
Watched the Sinking of the Royal Oak yesterday. Good movie. Of a crew of 1200, 833 lost their lives.
It is on youtube if you are interested.
I don't know what I will get up to today, but rest assured it will not be too productive.
I've already got my summers worth of work mapped out, 7,000,000 Litres (1,851,851 US Gallons) of oil to deliver in total at 11,000 gallons/load. There will be three of us for the first 529,000 gallons, then the two of us for the rest of it. It's gonna be a busy summer.
Have a safe day all
/ Good morning!!!! #131,397
Good Morning!!!! 4F @ 5:00AM. Partly cloudy. High around 85F. Winds NW at 10 to 15 mph.
Yesterday and today was/is a no burn day due to winds and low humidity. I'm also limiting my work with ground engaging implements to the morning hours before the humidity drops down into the teens.
Yesterday I got the hot water pressure washer out and gave the tractor a bath. All of the FEL and grapple pivots were caked with old grease that had collected a lot of dust. It's been a while since the PW ran, and one of the safety switches was acting up, stopping the flow of propane to the burners. I wiggled wires and cleaned contacts on a few things, and it finally started. But the pump, at least according to the on board gauge, was only registering 200 PSI, about half what it should. I think it still works better than a regular pressure washer, but I'm thinking it's time to move on to something more reliable that works better...
Found a nice pile of oak logs just inside a neighbor's gate yesterday, but got permission to snatch them too late in the day to do anything, so that's on the agenda for today. Don't know how that will go with the logging company, as it looks like they'll be taking trees down on that part of the road.
Ended up at a neighbor's yesterday evening to pick up some old fire hose to slip over the grapple hoses to give them some protection. He was complaining about the 3PH on is JD, which wouldn't let the implement come back down once lifted. That and the actuating lever wouldn't stay in place. The lever was held on its shaft with two nuts, and tightening them solved the slipping problem. The valve that controlled the descent rate of the 3PH had a ball bearing/spring assembly inside, and when we took the ball bearing out the descent problem went away. So something about the seat in that valve is bad. But at least he can use it now. The tractor is pretty old, and parts are getting expensive and hard to find, so he may just leave it that way.
Hope everyone's week gets off to a great start!
/ Good morning!!!! #131,398
Good morning! 63˚F heading to the upper 80s, cloudy, dry. The lawn sprinkler system is set for twice a week, 6 zones about 15 minutes each. Hope to get a little rain this week since I fertilized Friday.
I put compost around the now foot high potato plants and sprinkled some vinegar to increase the acidy, I hope I did not kill them. This is the first time I tried increasing the PH with vinegar.
Mostly, hope the cardiologist can diagnose your wife this morning, those trips to the ER are not fun.
Kyle at $30 an hour for mechanic work your uncle got a good deal and you have a bigger slush fund for the "Beast".
A neighbor is selling his golf cart after selling his house. I'll see if I can talk mom into getting it to get her mail. His house sold in 3 days and over the asking price. The covid has reduced the available houses on the market and and some big companies are relocating from other states which is really making this a sellers market. Our neighborhood started building roads in its last phase last year and this year they are pouring new sold slabs every few days.
/ Good morning!!!! #131,399
Bill, is an 11,000 gallon load considered oversize where you are? Are you maxxing around 50 tons?
that's a whole lot of oil
I think most big tankers in the US are 8000 gallons.
Does the operation of the various pipelines have an impact on what you do or haul?
Sure is a political and ecological football now, but I'm only interested in how it affects you.
And then you have a vision of a giant Mack pulling a triple through the Australian outback
raising a huge dust cloud
/ Good morning!!!! #131,400
daugen; The truck (class 8) is licensed for 63,500 kg or 139,997 lbs. on 8 axles. That includes my butt in the seat.
The truck is a standard tandem axle truck and the semi trailers are a 3 axle and a tandem axle behind it. 'B' train configuration. Empty the whole unit weighs in at 20,000 kgs/44,093 lbs. I try to weigh in as close to empty of fuel as I dare. Approximately 90 - 95000 lbs of liquid in every load.
It is all fun and games until you try backing up, then it gets real interesting. I tell anybody that asks, if you can back up a farm tractor with a hay wagon behind, then you can back up a 'B' train. Instead of kicking the tires I carry a tire billy to check them, all 30 of them. The tandems/drive axles on the tractor and the trailer axles are all duals as opposed to super singles.
Pipe lines have no bearing on my job at all. The product I haul is made from tar, it is called High Float (how it is made is beyond my pay grade) and is sprayed on gravel roads, covered with gravel and rolled and packed. It is real dusty for about two weeks and after a good rain the dust is gone and you have a hard topped road that is way cheaper than a hot mix asphalt road. These roads will stand up to medium traffic including trucks as long as you don't try turning tight 'U' turns on it.
Case Titan 3530 (A61307)
Case Titan 3530...
2014 Freightliner M2 106 Palfinger PK22002EH 6 Ton Knuckleboom Flatbed Truck (A55973)
2014 Freightliner...
2025 ZJG ZJ-380 Mini Stand-On Track Loader Skid Steer (A59228)
2025 ZJG ZJ-380...
2017 Chevrolet Equinox SUV (A59231)
2017 Chevrolet...
2011 MULTIQUIP LIGHT PLANT/ FUEL TANK TRAILER (A58214)
2011 MULTIQUIP...
2023 Ford Expedition SUV (A59231)
2023 Ford...
