Good morning!!!!
   / Good morning!!!! #113,981
66 and sunny, headed to 82 today. We got about an inch of rain yesterday, and it was needed.
Headed out to get bloodwork shortly, have a good day all.
   / Good morning!!!! #113,982
Coffee is done brewing. 50° with light fog this morning. Heading to 87° with mostly sunny skies. Still no weed killer down. Top of list today. Did get lights fixed. Had 10 lbs of apples that I bought to dehydrate. Got 7 lbs of them in dehydrator. Still have about 4 hours to go in oven.
Maybe this is why Hummingbirds are staying off perch on feeders.
Wngsprd, thanks, It's on Junetheeth. Hope Coco is going to be OK.
Drew, glad treatment went without to much side effects. Bagels for breakfast. :thumbsup: Special prayers on the way.
RNG, lots of electronic boxes to investigate. I am sure you will have your own document on how the system works soon. My 48 volt golf cart charges at 53.4 volts.
Riptides, I know that feeling of not motivated. Dr, wants me to take meds to overcome it. Not going to do it. Having my place look nice is enough motivation to get over it eventually. Lots of support from family and friends.
Bird, thanks for the compliments. I get lots of opportunities to take pictures here at my place. Taking camera on walks gives me many more opportunities for more picture. I like sharing them. No other plans.
Buppies, sure wish you could share some of that rain.
PJ, I tried Melatonin for a couple of months. Still only got my 5 hours of sleep each night. Wish could get more without taking any meds. But Dr's all seem to think another pill is the answer.
Jay, another person that misses your post. Please check in.
Everyone be safe and healthy.
Good Morning All.
   / Good morning!!!! #113,983
Good Morning!!!! 75F @ 4:00AM. Sunny to partly cloudy. High 98F. Winds NNW at 5 to 10 mph.
The Red Flag Warning continues until 8PM; a wildfire in nearby Oroville yesterday burned three homes and damaged two others. It was a grass fire that was blown into a neighborhood by the wind. That same wind has been crashing and banging all night, not much sleep as a result. Gonna be a long day.
Looks delicious, Eric. I bet those strawberries taste especially good since they came from your own garden.
Sorry about the speaker and the false alarm, Drew, but at least it sounds like your day is off to a good start. Hope the chemo effects stay manageable.
Good luck at the specialist's with Coco, Billy.
Still sounds like a delicate operation, Bill. And a whole lot of momentum going down the road!
CV19 numbers continue to climb here, too, Bruce, but so do the numbers of the recovered. Something like 90 confirmed cases county wide. Could the vent into the fuel tank be blocked?
Your guess is only off by a factor of 15, Kyle, but I bet the inspector gives it a lick and a promise type look see.:confused2: Is the spike due to more cases or better testing?
Sometimes we all just need a day off, RS. Or two or three...
Here's a shot of the battery bank, David, with the cabinet door open. Still can't see much, but there are two bins full of the cells, and a battery management system in there, too. For some reason, the installer disconnected the local display, preferring instead to use the one on the Mate3. No mention was made that local Optic access was read only; sure hope I can find a way around that. Just don't trust the 'net.
Got a call back from the building department, along with a link where I could download the signed off copy of the building permit. Eighteen pages later, I have a printed copy for the inspector when he comes out next Tuesday. I've also been told that the login info for the Optics system has been emailed to me, but I've seen no sign of it. They said they'd try again, but the salesman/project manager's computer skills aren't the best.
Had a new error show up on the van last trip to town. For some reason, the Vehicle Speed Sensor stopped reporting, and the engine controller decided to limit RPMs to 4500 by retarding the ignition. Yesterday I verified that the VSS is working by disconnecting the speedo cable and spinning the speedo with a screwdriver, and the LED on the VSS flashed and the diagnostic software on the iPhone reported a speed, so it looks like it fixed itself. So I cleared the code, but I'm not confident it won't come back. While I had the instrument cluster apart, I did a better job of the mounts around the radio, and now the cover closes all the way. Was gonna try to hook up a magnet/relay based Neutral Position Switch, another attempt to get rid of that other persistent error code, but ran out of steam.
Remembered that the one sprinkler pipe that got cut off in the trench still needed capping, so got that done. Rigged two sprinkler circuits to one set of contacts in the controller, and it worked fine. I was worried that the valves would draw too much current. The controller can only run three valves at a time, and there are four in the whole house sprinkler system. Now it's wired with two valves on two circuits, and there seemed to be enough water pressure with all four valves open to keep everything nice and wet. The wind had a lot of fun blowing the mist around, though.
Came in and figured out what I needed for a hydraulic cylinder for the auger and put together an order for it and a couple hoses from Surplus Center. Pretty sure I need to go pick up some steel for it, too, so might swing by the junk yard today to see if they'll let me wander around a bit. Then on into town for some groceries.
Hang in there, gang, Friday's comin'!
   / Good morning!!!! #113,984
Jay, we are all thinking about you and hoping you are in good health.
Ron, nice looking rodent...very destructive animals and scare the nice birds away.
still waiting on breakfast, glad I had that bagel...
   / Good morning!!!! #113,985
66 outside this AM. Rain from Buppies finally showed up here. Should put the next four days down as inside work. According to the weather people here.
Wife took apart pantry last night. So I'll be painting it today. Of course it is one room away from my nemesis - The Front Porch.
LOL
Have a great day all. Be safe, and hope all are getting healthy.
   / Good morning!!!! #113,986
Good morning! 70s to 90s dry, 50% humidity. A little sore this morning from the trashing about under the oaks, but already looking forward to next week when we can tackle them again. The Park is scheduled to open in October and we have miles of oaks to free. The park buildings, playgrounds, roads and RV spaces are starting to take shape in this 1,000 acre park.
Mostly, I do not know the size of the bike how do you measure to determine the size?
   / Good morning!!!! #113,987
Good morning. It was 68° at 5 a.m. and going to only 91° this afternoon.
I did get the four dead trees down and now the cleanup begins.
The first three were close enough together that I pushed them over together.
The 4th and by far tallest one, went down easier than I expected.
I was able to get an approach with the big tractor to miss the power pole guide line and two nearby live oaks. I was still concerned about overhead branches and even to whole top of the tree coming down on top of the tractors. I moved forward to get my grapple just touching the tree trunk, about 6' above the ground. I put it in low range / 1st gear, engaged the 4WD, and engine just above idle. I let out the clutch .. and pushed the tree over so slowly that the top didn't break as it gently came to ground.
I can't get the entire tree out of there, in one piece, because of all the other trees .. so this mornings plan is to cut it and the other ones into about 10' sections. Then off .. to a burn pile.
I did a bit of mowing in the same pasture where I dropped the four trees. With our recent lack of rain .. it presets dry and dusty. They're forecasting rains here .. beginning Sunday. Fingers and eyes crossed.
Drew .. glad to hear you're moving towards "normal".
Jay .. check in and let us know you're okay.
Hope everyone has a safe and productive day.
Prayers to all.
   / Good morning!!!! #113,988
"size of the bike"
Tire size?
   / Good morning!!!! #113,990
By your pictures Rick it sure looks dusty
I believe tire size is correct
Sun came out for a minute now gone
   / Good morning!!!! #113,991
Good morning to all! Low to 50, high today should be 88. No rain forecasted in the near future.... only smoke from the wildfires to the west of us.
This morning, we can hardly see the mountains due to the smokey haze. My son told me this morning that a very nice large log cabin burned down a few miles away from us, which caused a large brush / small forest fire. They must have gotten it under control since we have not heard anything on the local news.
Do not know if the smoke is from that fire or not. Bad news is that it is windy here this morning, expecting to gust around 25-30. Not good for firefighters.
Billy, hope Coco is ok, let us know what is found...
Drew, glad to hear you finally got your bagel fix....keep on plugging away at recovery, you are doing great!
Ron, another great pic... keep em coming! Look forward to see them every morning!
Eric, yes, there is a very large percentage of residential homes that have solar, the state owned buildings (fire, police, maintenance, and other state buildings) all have Solar systems. The main power company in the central part of the state has giant solar farms, along with wind farms, producing 39-40% of the energy produced for customers.
Unfortunately, the companies selling the solar systems for residential use are so high priced, most people cannot afford them. A lot of companies have started 藜*ease programs that essentially cost as much as just paying the electric company.... makes no sense except for being green.
Here is a pic of the smoke in the area.
   / Good morning!!!! #113,992
Very dusty Buppies. Sandy soil and no recent rains.
   / Good morning!!!! #113,993
They ask if my router is WPS supported. It's the facilities, have no idea but I'll try that method first. Never had luck with wireless printing, but need to this time as I'm running out of receptacles on pc.
I would get a router that supports WiFi as wan, (make the facilities WiFi your wan source) then isolate your stuff on your own private network.
Amazon now has a new Gigabit version of gl Ar router
GL.iNet GL-AR750S-Ext Gigabit Travel AC Router (Slate), 300Mbps(2.4G)+433Mbps(5G) Wi-Fi, 128MB RAM, MicroSD Support, OpenWrt/LEDE pre-Installed, Cloudflare DNS, Power Adapter and Cables Included Amazon.com: GL.iNet GL-AR75S-Ext Gigabit Travel AC Router (Slate), 3Mbps(2.4G)+433Mbps(5G) Wi-Fi, 128MB RAM, MicroSD Support, OpenWrt/LEDE pre-Installed, Cloudflare DNS, Power Adapter and Cables Included: Electronics
   / Good morning!!!! #113,994
It's not my router, it's the facilities, headed down there now to see if they will give me password. Otherwise I'll just use the printer cable for what little printing I do.
but thanks, good to know when I'm back in my own place.
   / Good morning!!!! #113,995
Good morning 64 going to 79 - needed rain has started but does not look like it will stop until....Next Thursday !
Worked on the stump some more, found 2 big roots under the top 3 roots. But still have at least 2 roots holding it down, it moves but won;t drag out.
The Doe that lives on the property had some visitors yesterday in the form of another Doe with a fawn just about void of white spots.
Drew - Bagel Time! hope you get that walk in. For the feedback make sure the mic is turned down and the internal (if any) speakers are off.
RNG - that is some setup. I have solar hot water, so during the summer we have lots of hot water, Winter not so much.
Top-I need to get bloodwork too, hope yours comes back clean and healthy.
Ron, Squirrels always play dodge car at the top of the hill in our area, Vultures always check each late morning for breakfast.
Stay Safe and be well
   / Good morning!!!! #113,996
62°F and clear skies this morning, going up to 89° today. Rain was off for the weekend when I checked early this morning, but now it's back on again.
Made the trek to Carlyle after work last night to get chicken feed from Tractor Supply. Tried to swing by the Highland Rural King for some other things after that, but got there about 7:15, which is 15 minutes after they closed. May stop there on the way home tonight.
Traffic around here is starting to return to its pre-panic pandemonium. I sure didn't miss those drivers.
Those berries look delicious, Eric.
I'm not a pill person, Ron. I rarely even use pain meds like aspirin and the like. It's taken some time for me to get into the swing of taking two melatonins and a multivitamin every night before bed. I still don't like it, but it's better than sleeping on the couch. It does seem like the medical profession has an almost unhealthy addiction to prescribing a pill for pretty much everything. I have no desire to walk through life in a chemical haze (did more than enough of that during my partying days), and always look for more natural solutions.
   / Good morning!!!! #113,997
Tire size and length of seat tube to pedal crank center would be a good start. My bike is 29 tires and 15 frame.
The seat tube is around 23" and the tires are 27".
(have clip on pedals and have extra "triathlon" handlebars, new tires and cables and refurbished)
   / Good morning!!!! #113,998
75F and mostly cloudy @ 11:45, high of 80F predicted and chance of rain now 70%.
WB 10 Day Forecast now has 6 out of 10 showing rain.
Need to go run up the windows in the van ... :D
Someone is having tree service work done, can hear the incessant drone of the chipper off in the distance.
... now hear something a little closer ... looks like the neighbor is down here bailing up the hay ... :thumbsup:
Hope everyone has an enjoyable, productive, and safe day.
   / Good morning!!!! #113,999
I was taught to measure from the center of the crank axle to the top of the seat tube.
That looks like a 24" or 25" frame to me...
   / Good morning!!!! #114,000
I had a Peugeot racing bike back in the late 70's , loved that bike, but it got stolen, at which point I got a Fuji (not like the new mas produced Fuji, this was the late 70's)
I had to repack the bearings on the Fuji and it was literally a race with a mess of ball bearings in it , unlike todays sealed and integrated ones. I remember I had to buy an aftermarket hardened crank for it as I kept snapping them. Was a bit stronger back then.
5' MOWER (A52706)
5' MOWER (A52706)
2008 MACK CHU613 TRI AXLE 16FT DUMP TRUCK (A58018)
2008 MACK CHU613...
2016 John Deere 35G Mini Excavator (A55973)
2016 John Deere...
2011 KOMATSU D65PX-16 CRAWLER DOZER (A60429)
2011 KOMATSU...
2018 CATERPILLAR 12M3 MOTORGRADER (A52709)
2018 CATERPILLAR...
2007 Volvo VNL Truck Tractor (A56438)
2007 Volvo VNL...
