Good morning!!!!
   / Good morning!!!! #106,221
There was a video on YouTube of a guy building a pole barn. He did the preset measurements, using a builders level to fill the holes with concrete to a certain level. When he went to put all the posts in, only one was off by an 1/8 inch. He then used a string to keep them all straight, just as you described doing.
For the rebar, could you use, say a 6 ft section, and just push it down into the base amount of concrete? That way the posts have support all the way up out of the hole. Use the string method to line them up. Wire or heavy string could be easily anchored from the rebar to the surrounding surface to hold it in place.
yes, steel post for garage. I cut about 4" sections of a larger diameter pipe in half and welded a piece 3-5' rebar at angle. I set 3 around each post check and recheck level. Vision a tripod around the post.
Thanks for the ideas, guys. What about a mashup of them all?
Embed 3 rebars in that first foot of concrete, 120° apart, and long enough to come about a foot out of the hole. Let the concrete dry. Then install the post, wrap a ratchet strap around the upper ends of the rebar and tighten it so the rebars bear against the post. Leave the strap loose enough so that the post can still move, but not easily. Then use the level and string to get the posts in the right position and plumb. Tighten up the ratchet strap to prevent further movement. When all of them are in the correct position as verified by string and measurements, start pouring concrete, maybe just a couple feet in all of them at first, checking position and level during that pour. Once that hardens, the posts should be pretty much set. Check and measure again, and adjust rebar/ratchet strap if necessary. Save about a foot for the last pour, and cut the rebar off with a pair of bolt cutters a few inches below the surface. Then finish the pour.
Think that would work? It would be easy enough to try out on one post first to see how hard the rebar could be made to grip the post. Could be that the two pieces of steel just couldn't be made to not slide against each other. Or it could be that the rebar is too flexible to provide much support.
I think the first thing I need to do is get all the dirt piles from the augering cleaned out of the way so I can see how accurately the holes were placed. And I think that's the part that makes me the most nervous now, since I know that there were rocks in several of the holes that pushed the auger to the side. Once the dirt is gone, I can get the stakes and string out and see if I can get a grid centered over the holes with the right dimensions. That would be a good job for today.
Last status update from FedEx shows the generator in Portland, OR at 9:23 this morning. Google sez that's 8 hours and 36 minutes away, so there's almost no chance of them getting it here by their still projected 5PM delivery time...:muttering:
   / Good morning!!!! #106,222
If these were wooden posts, it would be easy to just nail a pair of 2x4s at 90° to each other, then stake the other end down so that the post is supported in the correct position. But it's hard to nail into a steel post. How 'bout this idea:
I've got a bunch of 90° shelf brackets laying around. If I screwed one to the end of a 2x4 and bent it to a 135° angle, I could use the ratchet strap to hold the pair of them to the post. Maybe even use a little duct tape to give them more grip. Then put a stake out near the other end of the 2x4, and use a drywall screw between the two to try different positions until the post is plumb and properly located. I'd still use the first foot thick pour to control the height of the post, and maybe use the rebars, too, so I could pour a little at a time and not worry about trying to do too much at once.
   / Good morning!!!! #106,223
Can you not 'light a fire' under their butts to get them to move a little quicker? Facebook posts seem to make things happen.
I've got a bunch of 90ー shelf brackets laying around. If I screwed one to the end of a 2x4 and bent it to a 135ー angle, I could use the ratchet strap to hold the pair of them to the post. Maybe even use a little duct tape to give them more grip. Then put a stake out near the other end of the 2x4, and use a drywall screw between the two to try different positions until the post is plumb and properly located. I'd still use the first foot thick pour to control the height of the post, and maybe use the rebars, too, so I could pour a little at a time and not worry about trying to do too much at once.
That might work. You could go the Red Green route and use all duct tape to hold them. :))
   / Good morning!!!! #106,224
The shelf bracket idea sounds relatively simple to use. It would get the job done and probably easier to adjust if needed.
   / Good morning!!!! #106,225
Here is a quick sketch:
I used my transit to leveled a piece of rebar in each of my pole barn holes, poured footer to same height for all holes. I also calculated based on top of pole being at correct height so I wouldn’t have to trim any off, and get maximum pole in the ground.
   / Good morning!!!! #106,226
Good morning. I thought I would let you all know that winter is still here. Eric asked for a snow picture a few days ago. This is looking out the gate, we have about 2 feet on the ground. The drift behind the fence is over 5 feet. The low this morning was -20 below with a 10 mph breeze. It's going to be sunny with a high in the low 20's today.
I have been staying busy doing a few things around here. I put a 2 and half inch pipe on the cutting edge of the snow blower. It has made quite a difference in blowing the driveway. Also put a thermostat bypass heater hose on the Polaris ranger. I should have done that when I put the heater in it.
I have kept up with everyone. Everyone with building projects, I hope everything goes well and doesn't end up in Seattle. I hope that everyone feeling under the weather gets better and stays that way.
Hope everyone has a nice day.
CWB.
Been wondering how you were doing. Thanks for popping back on!!
   / Good morning!!!! #106,227
I hope those who slept poorly last evening gets some nap time today and still pull off a project or two.
I would but management frowns upon it
   / Good morning!!!! #106,228
Thanks, Ted, I'd thought about doing it that way, but in this case, each pipe is either 10' or 12' long, and would need to be driven into the concrete 5'. But the biggest concern is that the rails being supported require fairly accurate positioning of the posts, both laterally and vertically. I can fudge the vertical by leaving the posts long and "adjusting" them with a power band saw once the concrete sets, but if they're off laterally, the rails won't run straight. So I was hoping to get all six of them set before pouring any concrete, using strings strung between stakes to ensure that they are all in the correct position.
I also gave some thought to an initial pour of concrete to pre-set the height, with a couple pieces of rebar left sticking up to tie them into the rest of the pour. Just not sure how to reach down into that hole 5' to place the rebar.:confused2:
Pipe with concrete just poured around it and nothing under it is not a footer. If a footer is required, it needs to be under the pipe before the pipe is placed. A pipe or pole with just concrete around it can push down with enough weight to overcome the side friction.
With that said, local solar farm just pounded pipe in the ground, no concrete at all as far as I know. Thousands of panels.
   / Good morning!!!! #106,229
Depending on what time you get up in the morning (my case it was 3), a mid-morning nap will do the same as a mid-afternoon nap. Supposed to reduce your chances of a heart attack by 50% if you do it twice a week. So using that reasoning I should NEVER have a heart attack because I have a nap every day.:D
good logic
   / Good morning!!!! #106,230
Wife just came home for doc appt and errands. Good news on her foot, torn tendon that is healing fine.. just takes time. She'll be good as new soon..
   / Good morning!!!! #106,234
How far apart are your poles going to be?
Are they in a straight line?
Possibly drive a t post past one then another t post 10 to 20 feet away,
wire a piece of pipe or angle to the t posts secure your posts to that pipe,
getting them square and level ?
   / Good morning!!!! #106,236
30 nuts and bolts, 816 self drilling screws later - 6 31ft trusses
   / Good morning!!!! #106,237
Not sure I quite understand, but it sorta sounds like stretching a fence.
It's a two row x three column grid, 7.5' x 36' in size.
   / Good morning!!!! #106,238
Good evening all. 44F at wake up this morning, .5 inch in the rain gauge, light drizzle and windy. overcast all day temp dropped till 10AM rebounded for a few hours then headed down again. High temp was at midnight 62F and low temp will be at this midnight, about 36F. Weather for tomorrow will be conducive to energy conservation, nay get some snow and sleet, changes every time time I look at forecast. Will get Eric a snow pic if it shows. Energy conservation today, cleaning lady prep and fire and are my only accomplishments.
Drew sounds like nice day, good luck with awning repair.
Rich, sounds like a lot going on in your forecast.
Eric good luck with your sludge sucker :)
Roy good luck with the battery swap, have you checked for parasite power draw?
Ron hope you "pass" your test.
Billy hope you did not get too wet putting feeders back up.
Buckeye, hope timer fixes your dishwasher.
Don, sorry about card standings, have fun at firewise, how did you get so many batteries?
Drew, went to an independent Christian church for 30y, changed name on front of building, made 1 family mad (relatives of founder) and preacher happy, otherwise could not tell difference.
RNG glad you caught errors, hope you get get people moving in productive direction.
Rick nice setup for pressure washer.
Randy, you might try some high nitrogen fertilizer, wood decomposing can mess with nitrogen in soil.
PJ thanks for update :(
Ted thanks for slowing wind down, nothing like your report here.
prayers for all.
   / Good morning!!!! #106,239
57 high of 60 today rain developing lasting thru Thursday will put a damper on outside clean up. Skid loader mini ex dump truck here ready to go lots to do very little time
Prayers for all
   / Good morning!!!! #106,240
good morning all. Warm cloudy day, high of 70, big system moving in tonight with lots of rain.
Headed out when sun comes up to Apex, other side of Raleigh to rv dealer to get my awning fixed, I hope.
Not leaving in dark again, that's when I didn't see the lowered tree limb that is causing this trip to begin with.
No more big crashes in the dark...
If they have time, got a pair of 16" long LED brake/turn light strips, having them install them above existing turn signals for better safety. First I have to stop downtown and fill up with diesel, this time I have rag out to hold nozzle, avoid the inevitable getting slimed.
Feeling good this morning and all is well with the world.
Hope you all have a nice day and careful in the snow Ted.
Good news Hawkeye, happy wife, happy husband...
UNUSED FUTURE FT-CL100C HYD CLAMP GRABBER (A52706)
UNUSED FUTURE...
2019 Ford F150 XL (A57148)
2019 Ford F150 XL...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
2017 CATERPILLAR 420F2 BACKHOE (A60429)
2017 CATERPILLAR...
2264 (A60432)
2264 (A60432)
2018 Freightliner M2 106 Cab and Chassis Truck (A59230)
2018 Freightliner...
