Good morning!!!!
   / Good morning!!!! #106,234
Thanks, Ted, I'd thought about doing it that way, but in this case, each pipe is either 10' or 12' long, and would need to be driven into the concrete 5'. But the biggest concern is that the rails being supported require fairly accurate positioning of the posts, both laterally and vertically. I can fudge the vertical by leaving the posts long and "adjusting" them with a power band saw once the concrete sets, but if they're off laterally, the rails won't run straight. So I was hoping to get all six of them set before pouring any concrete, using strings strung between stakes to ensure that they are all in the correct position.
I also gave some thought to an initial pour of concrete to pre-set the height, with a couple pieces of rebar left sticking up to tie them into the rest of the pour. Just not sure how to reach down into that hole 5' to place the rebar.:confused2:
How far apart are your poles going to be?
Are they in a straight line?
Possibly drive a t post past one then another t post 10 to 20 feet away,
wire a piece of pipe or angle to the t posts secure your posts to that pipe,
getting them square and level ?
   / Good morning!!!! #106,236
30 nuts and bolts, 816 self drilling screws later - 6 31ft trusses
   / Good morning!!!! #106,237
Not sure I quite understand, but it sorta sounds like stretching a fence.
It's a two row x three column grid, 7.5' x 36' in size.
   / Good morning!!!! #106,238
Good evening all. 44F at wake up this morning, .5 inch in the rain gauge, light drizzle and windy. overcast all day temp dropped till 10AM rebounded for a few hours then headed down again. High temp was at midnight 62F and low temp will be at this midnight, about 36F. Weather for tomorrow will be conducive to energy conservation, nay get some snow and sleet, changes every time time I look at forecast. Will get Eric a snow pic if it shows. Energy conservation today, cleaning lady prep and fire and are my only accomplishments.
Drew sounds like nice day, good luck with awning repair.
Rich, sounds like a lot going on in your forecast.
Eric good luck with your sludge sucker :)
Roy good luck with the battery swap, have you checked for parasite power draw?
Ron hope you "pass" your test.
Billy hope you did not get too wet putting feeders back up.
Buckeye, hope timer fixes your dishwasher.
Don, sorry about card standings, have fun at firewise, how did you get so many batteries?
Drew, went to an independent Christian church for 30y, changed name on front of building, made 1 family mad (relatives of founder) and preacher happy, otherwise could not tell difference.
RNG glad you caught errors, hope you get get people moving in productive direction.
Rick nice setup for pressure washer.
Randy, you might try some high nitrogen fertilizer, wood decomposing can mess with nitrogen in soil.
PJ thanks for update :(
Ted thanks for slowing wind down, nothing like your report here.
prayers for all.
   / Good morning!!!! #106,239
57 high of 60 today rain developing lasting thru Thursday will put a damper on outside clean up. Skid loader mini ex dump truck here ready to go lots to do very little time
Prayers for all
   / Good morning!!!! #106,240
good morning all. Warm cloudy day, high of 70, big system moving in tonight with lots of rain.
Headed out when sun comes up to Apex, other side of Raleigh to rv dealer to get my awning fixed, I hope.
Not leaving in dark again, that's when I didn't see the lowered tree limb that is causing this trip to begin with.
No more big crashes in the dark...
If they have time, got a pair of 16" long LED brake/turn light strips, having them install them above existing turn signals for better safety. First I have to stop downtown and fill up with diesel, this time I have rag out to hold nozzle, avoid the inevitable getting slimed.
Feeling good this morning and all is well with the world.
Hope you all have a nice day and careful in the snow Ted.
Good news Hawkeye, happy wife, happy husband...
John Deere HPXD (A57149)
John Deere HPXD...
Bucket Truck (A59230)
2012 Ford Expedition 4x4 SUV (A56859)
2012 Ford...
New/Unused Electric Golf Cart (A57453)
New/Unused...
New/Unused Quick Attach Pallet Forks (A57454)
New/Unused Quick...
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58216)
RIPPER ATTACHMENT...
