Good morning!!!!
   / Good morning!!!! #49,841
67 going to 81.
"Gone Fishing" - 'nuf said.
Worked on digging out sand that has accumulated on and around my bridge yesterday afternoon. I need to return downstream and break up a log jam again - I may be able to get close enough with the tractor to wrap a chain around the big tree that is clogging things up and pull it out.
Lots of apples ripening now, but most have worms or cedar apple rust, since I don't spray. I need to take lessons from Drew.
   / Good morning!!!! #49,842
hey Billy at least you have apples; I lost just about every one to the late freeze. But I did get one apple, one little green apple that was sweet and juicy when I ate it right off the tree. That one apple made it all worthwhile.
Growing up in PA we used to spray the orchard four or five times a year. When we stopped, those apples got so buggy they weren't good for much except apple cider. We did that several years, took our own apples down to the cider mill and had them pressed. Yummy bugs!
Fireman helper coming over mid morning to help me get the pto shaft on my finish mower so I can go try out my new tractor. I struggled for hours on that yesterday, first using the expensive LP quick hitch on an LP mower, and for the second time, on a second tractor, I could not get it to work on the top link. So off comes the quick hitch, and on goes the mower with totally manual links. Boy I missed those Kubota extendable links; luckily the mower has four wheels and rolls on the concrete, so I got it done.
I decided that while the $415 to get a horizontal muffler on my Massey instead of a vertical was pretty expensive, my first fueling experience put my shoulder right up against that hot vertical muffler. Fill pipe is a foot away. (?)
That wasn't fun but it did remind me I need to run the muffler down low. Any of my fruit trees and certainly going in the woods would rip that muffler right off.
66 going to 85 today. Have a great day guys, be healthy and enjoy life.
   / Good morning!!!! #49,843
44F now clear sky 70 for high...taste of autumn.
Soon to the grind than hopes mowing the lawn after work before darkness arrives.
Enjoy the day all.
   / Good morning!!!! #49,844
60 this morning high of 80 after 92 yesterday. In this NW flow our rain went poof again
   / Good morning!!!! #49,845
First cup of coffee has been poured. 56°with clear skies this morning. Heading to 76° with mostly sunny skies. Having a good time making new friends and visiting with old friends.
Eric, good luck.
Good Morning All.
   / Good morning!!!! #49,846
50F @ 06:15, could dip into the 40's before the sun makes it up. High today predicted to be 75.
Deliver refrig to daycarethis morning then haul tools back on the return trip and pick up my new (to me) furnace.
Later this afternoon pick up steel at my suppliers down in Canton.
   / Good morning!!!! #49,847
Ron, travel safely and fair, and very light winds directly behind you.
RS, Canton somehow brought up the thought Rust Belt to me.
particularly since you are likely to go buy some rusty steel today...
What's Canton like?
am off to MF dealer to order seat arm rest kit and lowered muffler kit.
Buddy coming over mid morning to help me get mower going.
Life is good.
   / Good morning!!!! #49,848
Good morning! 70˚ heading into the 90s. Still dark outside.
I have one dead limb hanging over the paver drive about 30' in the air. Now I have to figure how remove it using the new 8' HF electric pole saw without spilling blood.
Looks like we go into the 60s again at the end of the month.
   / Good morning!!!! #49,849
... RS, Canton somehow brought up the thought Rust Belt to me.
Yup ... the Northeast, OH would surely be considered part of the rust belt.
LOL ...
Nah, this is all new, virgin steel ... if anything, it's likely to be oiled ... and have cutting fluid dripping off the ends where they ran it thru their Marvel saw to cut the stock lengths (20', 21' and 24') in half.
It's always a real treat handling it - until I get it cleaned off ... particularly with no gloves.
What's Canton like?
Pretty typical mid-size midwestern city ... smaller than Akron ... but home to Timken and the Pro Footbal Hall of Fame.
Canton, OH - Wikipedia
Life is good.
Indeed :thumbsup:
   / Good morning!!!! #49,850
Cruising down the Danube:
Wine country
   / Good morning!!!! #49,851
Good Morning! 59F @ 5:00AM. Sunny. High 86F. Winds light and variable.
Wng, it's possible to mix chains and snatch straps to extend your reach; I've gone 60' a time or two with good results. Don't forget to hang a heavy tarp or blanket half way out just in case the far end lets go or breaks, though.
Drew, if you can get the Massey to a muffler shop it's likely they can alter the exhaust plumbing for a lot less than the cost of that kit. But the Massey dealer likely has the easiest solution, and I agree that an upright muffler has no place on a woods tractor.
Let's see, 8 from 30 leaves 22, and Don can probably reach 7' so we're down to 15, but that's still pretty high. My pole saw came with strong cautions about using it from a ladder; something about not being able to get out from under falling limbs. Didn't mention anything about bucket trucks, platform lifts, or jet shoes though, or even standing in your bucket with the wife at the controls. :laughing:
How my day started yesterday. Wood in sections too heavy to lift scattered all over the hillside. Several trees worth of debris was also left higher and to the right on the hill. It all rests on a 36% gradient, which makes walking fun, pushing logs uphill a great workout, and driving a tractor pretty much a continuous butt pucker. None the less, working slowly and carefully, I was able to clear the the smaller piles of wood from around the big pile, which at one point meant using a chainsaw to cut some logs up so I could lift them into the bucket on the front of the tractor. That was a lot of fun, too, since every time I put the chainsaw down it vibrated itself down the hill a foot or three, and at the end of each cut there was no telling where the piece would go. I'm happy to say that most did find their way into the bucket, but one particularly thin slice headed down hill like a loose wheel on the freeway and disappeared into the brush. Apparently it liked the situation even less than I did, and just wanted to get somewhere else, fast.
Only two trees survived the previous day's chainsaw massacre. I'd rather the inmates had left all the trees in this condition rather than hacking them up into random lengths and leaving them on the steep back slope. But then what fun would that have been? Obviously they saw that I was getting something of a paunch, and even more obviously needed something of a workout.
About the only good thing about yesterday was that the wood pile is growing again. But even with that, it'll take lots of work in the wood gym to buck, split, and palletize it before it's ready for the wood stove. But with a tractor and a good chainsaw, I supposed anything's possible. Maybe even unavoidable.
Closer than I thought. These are burned manzanita leaves that drifted over from the other, toasted, side of the canyon. A little closer and they would have still been on fire when they landed. And yeah, that's dry grass, just down slope from the back patio. Burning grass wouldn't have carried enough heat to catch the house on fire, but it sure would have made a lot of smoke and caused a lot of excitement among both myself and the two firemen that were here at the time. Especially since all of our attention was focused on the fire that had spotted across the canyon a ways down below the house. The OTHER side of the house, so who knows how long it would have taken us to figure out we were watching the wrong side of the house?
TGIF is comin', Thomas, hang in there you all!
   / Good morning!!!! #49,852
Good afternoon from Vienna. 81°F and partly cloudy - gorgeous day.
Already been on tour thru town and suffered thru lunch.
Taking a break before dinner and evening concert,
Great looking tractor, Drew
Be safe
Have a great day.
   / Good morning!!!! #49,853
Good morning all, 65 going to 79 wit a 20% chance of showers after 2 pm. Went to bed last night at 9:30 and slept till 8:00, had planed to get up between 4:30 and 5:00 as usual but I guess I was tired. Have a meeting this morning and mother in law coming around noon so will likely not get much done today.
Drew Those mufflers are pretty tough but they do let go of limbs perfect for face slapping.
Eric Wish I could say that, my grandfather walked on crutches for over 70 years and made his living trapping & fishing the rivers of central Virginia. I was his oldest grandson so I spent a "few days" on the river bank. Miss those quiet days on the river bank with him. He had a worm bed and would have enough worms to fish all day in about 2 min. Eric have fun.
RS like the looks of the splitter. Looks like it is very well designed.
Have a great day Ed
   / Good morning!!!! #49,854
Progress made - backwards.
Here is a pick of the dead limb. The green is just a grapevine, the limb has been dead for months.
To control the fall I need to get a rope up high around the limb. I tied a rock on the rope. now the rock is stuck in the tree limb.
Plan B
coming soon . . . as I think of it . . .
   / Good morning!!!! #49,855
A few pics:
Pears growing ( using heat from the wall
Church by lake
French monument in wine country
St. Stephens in Vienna
   / Good morning!!!! #49,856
Forgot to post a tractor pic
image-1142390641.jpg Sent from my iPhone using TractorByNet
   / Good morning!!!! #49,857
77 this morning and headed to 92 today. Rain on its way. A 20% day.
Hay is still on the ground. Dad moved tractor back yesterday and forgot the monitor for the baler. Baler won't tie without it. Had to wait for him to get off school bus to bring it back. Hay was damp by then.
Will work on something else. Maybe grain bin pad.
Boy is getting over the flu. Tough on a 6week old.
Don. Second rope? Smaller with a baseball. Throw over and out. Then pull larger rope up.
   / Good morning!!!! #49,858
Well Don, that looks interesting.
   / Good morning!!!! #49,859
Commercial refrig, convection oven, and stainless steel racking delivered to the daycare, van reloaded with excess building materials and fencing parts and delivered back to their house.
Picked up my free furnace for the polebarn while I was there ... it's an 80% efficiency, 66K btu Lennox ... should be good enough to heat at least one bay mebbe ...
Steel order is ready to be picked up :thumbsup:
2003 TRAIL KING TRI-AXLE BELLY DUMP TRAILER (A58214)
2003 TRAIL KING...
2021 CATERPILLAR RM500B ROTARY MIXER (A60429)
2021 CATERPILLAR...
Bulk Lot of over 600 NEW Motorcycle Sprockets - 1980s to Present (A61306)
Bulk Lot of over...
2007 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2007 Ford F-150...
2013 Felling Trailers T/A Side Dump Flatbed Trailer (A56857)
2013 Felling...
INGERSOLL RAND WL-440 WHEEL LOADER (A60429)
INGERSOLL RAND...
